Question about Mitsubishi WS-55908 55" Rear Projection Television
Help with bowing
I own a ws-55908 mitsubishi hd tv and it bowes from the top and bottom of the screen. If I smack it, will go back to normal and then go back to bowing after a few minutes or it just will not do it all. Plase help me it drives me crazy
    Genius:
  • 1,694 Answers
Usually consumer described bowing is bad solder connects
on pins of convergence IC's. If the effort is made to pull the center PC board out,then replace both Stk392-570 IC's for
durability.
Note: V-Pin amp and pin out relates to left/right side bowed-in
  issues,a problem not usually found on your model.
Posted on Oct 20, 2007
  • 398 Answers
If the picture bows in from the top and bottom, the V-PIN amp has stopped working. If you smack the set and the bow goes away, it means that the V-PIN circuits are intermittent because of a cracked solder joint, most likely on one of the 2 output transistors. The set needs to be disassembled, the chassis pulled out and flipped over and the solder joints of all parts on heat sinks must be resoldered. If you have never done anything like that before, allow a qualified tech to handle it for you.
Posted on Aug 30, 2007
Picture Bowed towards the center
It is a convergence problem, probably one of the convergence ICs has blown and must be replaced. Call the number in the last pages of your user manual to get repair service in your area.
Jul 25, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Picture is bowed and colors are not aligned
This called Projection TV convergence. Take a look on this site for a tip on Projection TV convergence.
Apr 19, 2010 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-55805 CRT projection TV with
This problem is most likely caused by damage in the convergence output amp IC's; this model uses STK392-040. Fairly common for various fuses that protect the DC supplies for these amp IC's to open as well.
Mar 03, 2010 | Televison & Video
Misubishi Medallion 1080
If this is a ws-65411: it sounds like one of the two STK-392-110 convergence IC's is bad; you need to have both replaced at the same time; I do this type of repair(done hundreds of them) and most can be done right in your home.
The two ic's can be purchased on Ebay for about 12 dollars plus shipping.
This is the slow time of year for TV repair shops--find someone in your area who knows how to do this kind of repair---here shops charge 3-4 hundred but I charge 200-250 total depending on brand of set.
Shop around and if they insist on "taking set to shop" keep looking---any good tech can do this repair in your home---MAKE SURE HE CHANGES BOTH of the IC's!
I do this here for free so if this has been helpful give me a vote here.
Aug 24, 2009 | Mitsubishi WS-65413 65" Rear Projection...
Convergence problem
Hello Pherpher85:
The convergence needs to be realigned it will need to go to a repair shop.
Aug 05, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi TV Picture Bowing
You will find a very good guide here and here to fix your TV.
This might not be a DIY if you do not feel comfortable. The repair shops charge about $350.00 to $400.00 for this type of repair.
Apr 19, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Bow like image
You likely have bad convergence output ic's type #STK392-570.  These can be purchased at UED 800-648-6657.  You will need to remove the board they are mounted on to be able to usolder the old ones and resolder the new ones.  These will be mounted on heat sinks.
Sep 08, 2007 | Mitsubishi WS-65819 TV
Mitsubishi WS-55908 55" Rear Projection Television Logo
275 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
