Question about Intel Desktop Board DG41WV Motherboard
Continuous reMy brother uses DG41WV desktop board with Intel Dual Core 3.0GHz E5700 processor & 2 GB DDR3 RAM. The PC has SMPS of 450 Watt ATX-P4.When turning on the machine by pressing Power Swi
My brother uses DG41WV desktop board with Intel Dual Core 3.0GHz E5700 processor & 2 GB DDR3 RAM. The PC has SMPS of 450 Watt ATX-P4. When turning on the machine by pressing Power Switch, the processor fan, on-board LED & HDD LED of chasis is turned on but there is no beep sound in in-built speaker & also there is no video in Monitor whether it is connected to VGA port of the board or to the VGA Card. I found all other components like HDD, RAM, Processor, VGA Card & SMPS are in ok condition. The PC was running till last Monday. I checked the parts in different machines. Then, I cleared the CMOS but the problem still exists. Now, what should I do to solve this problem? Please help...
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Intel Master
  • 2,226 Answers
It could be the board
Posted on May 21, 2014
SOURCE: Intel D850MV motherboard
This is Old problem with this mother board, Check u r dummy ram stick, if its fixed properly, and if possible get bios upadates, Check u r smps, it should be above 400watts. this can probably solve your problem.
Posted on Aug 16, 2007
  • 44 Answers
SOURCE: No video & 3 beep sound
Hi Sharang -
Here are the steps to take for that specific motherboard according to Intel
  • Reseat the memory.
  • Make sure that the contacts on the memory and the socket are clean.
  • Try removing one bank of memory modules at a time. Note: Some systems might need to have a memory module in Bank 0.
  • Try using RAM chips from the same manufacturer with the same part number and speed.
  • Check for a faulty memory module by trying the memory in a known good system.
  • Trying known good memory in the system.
  • Check the power supply and check for power fluctuations.
  • Swap the motherboard.
Hope that helps,
Take care,
Michael
Posted on Nov 14, 2008
SOURCE: new asus m3n72-d motherboard bios will not post
If you don't already have a case speaker hooked up to the board, you might want to connect one since there isn't an on board speaker and you will not hear error beeps otherwise.
Also, if you have another non-phenom AM2 processor handy you should really update the BIOS to latest release. Many late model Phenoms will not work on motherboards that have earlier BIOS releases and you will not be able to post. You should then choose "Set Optimized Defaults" and save the bios without any changes then shut down (not reset). When you power on again it should post and you should be able to get into the BIOS.
A third thing you can try (after you get a case speaker hooked up) is using a cheap pair of ddr2-6400 RAM to get the board to post so you can get into BIOS and change the voltage to the correct settings for your RAM if it requires a higher voltage than the bios expects.
Posted on Nov 17, 2008
Dissolu
  • 221 Answers
SOURCE: Nothing happens when I press the power button. No
What about the power supply? I bet it's supply's issue. Otherwise make sure that PWR button wires are connected properly and to the correct terminals of the motherboard
Posted on Jun 29, 2009
  • 832 Answers
SOURCE: I have a problem with Intel D845GVSR Motherboard
You have a busted M/B. Please change it,
Posted on Sep 21, 2009
Can a inspiron 570 motherboard replace the inspiron 560 motherboard?
From the looks of the mobos this is a possibility. One uses AMD processor, while the other is Intel. The 570 board appears to be small form factor. I make no guarantees though.
What's the reason for using a different model? I saw a lot of each for sale on Amazon
Oct 31, 2015 | Dell Inspiron 560 Desktop Computer (Intel...
My desktop PC with Intel DH61WW mother board, Intel i 3 processor, 4 GB DDR3 RAM, Windows 7 OS Intel HD Graphic S/W has auto restart problem while shutdown is attempted. The UPS power is to be switched...
Disconnect all peripherals, except keyboard, mouse and monitor. Try to start the machine in safe mode and if it comes up okay, then try to restart it into normal windows. If the problem continues, remove all but one stick of ram, and try again. if it happens again, change out the stick of ram with one of the other ones. IF this fails, and the problem still exists, try to boot from a usb drive. If it boots normally then you may have a problem in windows, and that may need a re-install.
Sep 29, 2013 | Computers & Internet
Display off after some time
As you have checked all of the removable components. That only leaves one bit left. The motherboard. Check the capacitors around the CPU socket and the Power connector. There is a common problem with Socket 775 CPU it is that the contacts on the CPU socket can be badly connected even when the CPU is fitted and locked in.
Jul 26, 2013 | Intel Essential DG41WV Desktop Motherboard...
Which is the best graphic card for intel DG41RQ mother board
I have a motherboard intel dg41rq and intel core 2 duo E7200 and nvidia geforce 9500 GT and 4gb ram (DDR3).It will work with call of duty black ops 2 and FIFA 13.So your done.
Oct 02, 2012 | Intel DG41RQ Motherboard CPU Bundle - ...
Does asus p5n73 am mother board support asus ati radeon HD 6450 graphic card? my smps is 450 watt also let me know which graphic card support my mother board
your power supply is at the edge, so i'd suggest going for 650W power supply. your mainboard will support the graphics card but as i said - you need better PSU
Mar 13, 2012 | ASUS HD 6450 DDR3 PCIE Native HDMI SILENT...
Which laptop for 3d animation .use softwares maya,max ,video editing dell's config: Intel® Core™ i5-460M Processor (2.53GHz, 2Core/4Threads, turbo up to 2.8GHz, 3M cache) 1GB NVIDIA®...
dell\'s config: Intel® Core? i5-460M Processor (2.53GHz, 2Core/4Threads, turbo up to 2.8GHz, 3M cache) 1GB NVIDIA® GeForce® GT 420M graphics with Bluetooth (with WIDI) 4GB 1333MHz DDR3 SDRAM (1 x 4G) (operates at 1066MHZ for Core i5 processors) with increased RAM will work fine
Dec 16, 2010 | eMachines M6811 Notebook
I brought a new Intel H55Tc Mother board, Core i3 Processor, 2GB DDR3 Ram. Now my system fan and smps fans spindling is not continue. But My SMPS is working well with other mother board.
Dear vijay, Please check your power ic of mother board there is problem. When you change it then your cpu and processor fan will be working.
Thanks. Rakesh.
Nov 26, 2010 | Intel H55TC Motherboard Core i5 650...
I want to buy a laptop. Please suggest me which processor is best? ie. Intel pentium processor or intel pentium dual core processor? Will intel pentium dual core processor overheat easily?
hello,,,,,,,,,,,,,
First you need to be clear that dual core is the family of Pentium series. so there is no processor called Pentium.............. now regarding your question i would suggest you do not go for dual core... Take core 2 duo or I3 /I5/I7 series of processor..............
I am giving you a configuration in a good budget
Rs 50,800/-
Intel 3 GHZ Core2 Duo Processor,3 GB DDR2/DDR3 RAM, and a 250/320/500 GB HDD. DVD writer, 15.4-inch display with a resolution of 1280 x 800 dpi. integrated Intel Graphics Media Accelerator X3100 video card, integrated modem and sound card, Wifi, Touchpad mouse and in-built speakers. It has interfaces like Express Card slot, S-Video port, 4 USB ports, Firewire port, bluetooth and a 6 in 1 Digital Media Reader. The laptop comes with an inbuilt camera .
It would be better if you can tell me your budget ............... So that i can give you a good configuration ......................
Jun 14, 2010 | Computers & Internet
Intel Desktop Board DG41WV Motherboard Logo
95 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
