Question about Kenmore 3.5 cu. ft. Front Load Electric Washer
Model970-C4810600 this is a front load washer = i do not know if it is the control board, the machine will not drain - when i use the dial on and change the dial from heavy load to drain and spin it only humms, but nothing happens.
  • 213 Answers
SOURCE: front load washer wont spin
yes. the solinoid or wax motor (depending on which switch you have) has fail and is not telling control that the door is locked. replacing the switch will fix it
Posted on Nov 20, 2007
SOURCE: kenmore he2 front load washer
Open the panel with 1/4 in socket. Turn white plastic cap filter counter clockwise. remove debris. replace. Run rinse and spin cycle. reopen cap and check for any new debris. replace filter cap and put cover back on. put $65 in bank. Send note to Eddie Lampert and tell him that Sears sucks and he'll never save it as long as they keep screwing their customers by not telling them about a simple fix like like this to an obviously common problem.
Posted on Jan 28, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: washer will not do a spin cycle for rinse or end of cycle
you can check two things,. One is, is the belt broken or stretched, the other is the motor, is the motor turning if the motor is turning then replace the belt. If the motor is not turning replace the motor.
Posted on Feb 08, 2009
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
  • 1294 Answers
SOURCE: kenmore front load washer wont drain gives F2 error
There is an awesome guy on fixya with this:
http://www.fixya.com/support/r622155-kenmoreelitewhirlpoolduetdoorjammed
http://www.fixya.com/support/r615354-fherrorcodewhirlpoolduetkenmore
Posted on Mar 28, 2009
I have a Frigidaire FTF530FS washer with a problem. The Timer gets stuck in between the drain and the spin cycle. It occurs when the timer dial is about 3 o'clock. I replaced the drain pump, the door...
Good Morning kvojik, thanks for your post!
From my understanding your Frigidaire front load washer is getting stuck between the drain and spin cycle. I noticed that you have replaced many components within your washer and continue to experience this issue. I would not advise to manually advance any part of the washer because this could cause issues within your washer. It could be a potential issue with the motor. At this point you may want to reach out to a technician for proper diagnosis and repair. This will help you to avoid any further part purchases. -Matt
Feb 21, 2015 | Frigidaire FTF530FS Front Load Washer
Wash machine quits mid cycle
Your Circuit Control Board is starting to Fail.... The Electrical Reset is the give away....
Mar 03, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Error code 20 will not drain water and don,t know how to open washer to check drain
What is your tecnical ability? According to the manual, it could be faulty wiring between the pump pressure switch and the control board. If the connections are corroded, or loose correct the wiring. If the wiring is good replace the pressure switch. If that doesn't work then control board needs replaced.
Let me know
Jan 09, 2011 | Frigidaire Affinity ATF7000E Front Load...
When time to drain pump drains water then just hums and it wont spin, get error code f01. when i turn dial to drain and spin pump just hums drum might turn a little but it never spins. i have emptied...
f01 is main controller (board) failure.
Replacing it is the only solution.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does the code nd stands for on the maytag front load washer?
ND No Drain Machine control board monitors water level in washer during and at the end of pump out. If wash level does not reset pressure switch, it will see water left in the washer. 1.Check for pump/drain restriction. 2.Check pump operation.
3.Check pressure switch for open contacts.
4.Check inputs and outputs at machine control board.
5.Replace responsible component.
May 28, 2010 | Maytag EPIC MFW9700S Front Load Washer
Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer runs when timer dial turned though ON button not pushed
Problem solved by ourselves! It was NOT in the circuit board (brain) of the machine. It was NOT in the door locking assembly as others would lead us to believe. It WAS the on/off switch on the control panel--part number 22002560 - a $22.00 problem fix.
Jan 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
Tub won't move
could be motor, control board, motor controler
Apr 10, 2008 | Frigidaire GLTF1670A Front Load Washer
Wont complete final spin and drain
Ok you need another repair man this is a simple timer problem since you said dial I take it as timer machine if so it has a dead spot in that cycle. although if it is a electronic control replace the control board and this will be the cure good luck and Merry Christmas
Dec 21, 2007 | Maytag MAV7600 Top Load Washer
Loud spin, doesn't fill, dial doesn't move.
yes you do have to remove the top off the washer and the washer should come with a mounting kit that must be used when stacking this unit. as far as your filling and draining problem i have had this problem several times before you have to replace your speed control board or sometimes called the speed control unit in the lower right hand corner of your washer
Sep 08, 2007 | Kenmore 43142 Front Load Washer
Washing Machines Logo
98 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
