Question about Canon IR 2535 Copier
How to adjust margin ir2530
I want to adjust margin on ADF ir 2530
2 Suggested Answers
SOURCE: problem ir 5570
we have ir 5570,the problem is that it is not detecting papers in
cassette. i have paper filled in the cassette but nothing is show that paper is present
Posted on Jul 08, 2011
E-000711-0001 in canon ir 3300 xerox
The connector has poor connection. The ADF controller PCB is faulty. The finisher controller PCB is faulty. The DA unit PCB is faulty. The card reader PCB is faulty.
Connector, ADF controller PCB Is the interface cable between the ADF controller PCB an the reader controller PCB normal? NO: Correct the cable. YES: Replace the ADF controller PCB.
Dec 31, 2017 | Canon Office Equipment & Supplies
The copier Ir 2570 its Opc drum in which copier is Equiverant to
The drum for Canon Ir 2570 is also equivalent to this machines: Like Canon IR 2230
Like Canon IR 2270
Like Canon IR 2530
Like Canon IR 2570
L ike Canon IR 3530
Like Canon IR 3570
Like Canon IR 2830
Like Canon IR 2870
Like Canon IR 4530
Like Canon IR 4570
Like Canon IR 3030
Like Canon IR 3025
Like Canon IR 3035
Like Canon IR 4035
Like Canon NPG 25
Like Canon NPG 26
Jul 30, 2017 | The Office Equipment & Supplies
When I try to make copies using the ADF the screen tells me to remove documents and place on glass.Can you explain why. I have sveral pages
Automatic document feeder requires you to insert files into holder and let the machine scan through the pile providing you have not over ridden settings to manual.it sounds as if you have switched off adf to manual which would require you to place each document onto glass one at a time.see if you can switch it back to auto in the screen menu.
May 04, 2015 | Epson WorkForce WF-2530 All-in-One...
I have coystar ir 2530 I have error C4200
This error isin referencetoa bad laser unit. The only way around this issue is repair, replacment of that unit will be my recommendation. Do not hard reset this unless you have the new part in. Now while the tech is in there you might want him to check the DC board for issues. A bad laser unit can be the result of a bad dc board.
let me know if you have any more questions rulds2008@gmail.com
Jan 12, 2012 | Copystar Ri-2530 Printer
Bottom half portion of the paper horizontally gets black (dark)
I would presume that somwheare beneath adf is light coming to scanner. Try to adjust height and possition of adf on adf hinges.You have two screws, one for height, and other for left or right possition.
May 25, 2010 | Canon imageRUNNER 5000 Copier
Black vertical line along left margin when using the adf to scan.
Check both the Fuser Unit and the Cartridge for lines . In any of the rollers are found with a line that means it needs to be replaced.
Jan 26, 2010 | Dell 1600n All-In-One Laser Printer
Colored Vertical Lines when ADF Scanning
the scanner system using ADF is not the same as in using from the platen glass, (CIS usually called contact image sensor) reads your document and sends the info to be printed, chances are your CIS assembly could be dirty and have some dirt on its surface, try opening this area on the top of ADF and clean with a moistened cloth, especially the affeced left margin, it should work!
Jul 14, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Auto paper feed jamming
clean the rollers with alcohol. this will renew the rubber and clear up the problem
Jun 27, 2008 | Kyocera Mita KM-2530 Laser Printer
Canon IR 2535 Copier Logo
49 people viewed this question
old marine
old marine
