Question about Sanyo Katana SCP-6600 Cellular Phone
Battery removal I am trying to pair scala 700 bluetooth to kitana. previously had scala 500 with no problem. Kitana will not recognize scala 700, unable to find owners manual,as to how to remove kitana battery as per troubleshooting tips, plz help!
  • Barb Gregg Mar 16, 2009
    It won't release. HELP!
  • 21 Answers
Okay here's how to remove the battery:
1.Lay phone back up on a flat surface
2.You will see a tiny little tab that you can with your nail pull back that is like a safety release.
3.Then with your other hand grasp the two sides of the back and pull it off
Ta dah you did it
Posted on Nov 14, 2007
SOURCE:
Not pairing with other devices
Have you turned blue tooth settings on your phone? Also you can pair your phone if the Bluetooth is working. Otherwuse you may be out of range. If that does not work have someone else try the bluetooth to eliminate the problem is with your phone.
Nov 15, 2013 | Cardo Scala Rider Teamset Pro
How to unlock kitana in story mod
When you are at the Evil Monastery, find the area with 2 statues with a portal behind it. Jump on the broken pillar on the left, then onto the platform. Go left some more to find koin.
I found this on the GameSpot website, if that didn't help, they have another explanation. If this doesn't help, go to http://www.gamespot.com/xbox/action/mkshaolin/hints.html
May 10, 2010 | Midway Home Entertainment Mortal Kombat:...
How do I get my contacts off My Kitana if the phone wont power up? I am unsure of why it quit working. (Yes I tried charging it) and I received a replacement Kitana today.
without power, you cannot retrieve the contacts. I assume it's sprint or a cdma carrier that does not use sim card. If for some reason you have a sim, then they might already be on it.
May 04, 2010 | Sanyo Katana LX Cell Phone
What is the passcode for the Scala LX700 bluetooth?
Four zeros is the PIN you want to use for pairing
  • 0000
That's also the default code for a majority of bluetooth headsets.
Here is the entire pairing process broken down:
1. Turn on your phone and make sure that its Bluetooth function is activated.
2. While the Headset is turned off, press the Wheel inwards for at least
8 seconds. The Status Light will begin rapidly alternating red and blue,
indicating that the Headset is in Pairing mode.
3. Using your phone, search for Bluetooth devices by following the
phone’s instructions.
4. After a few seconds the phone will list the scala-700LX as a “discovered
device”. Select it and follow your phone’s instructions to accept the pairing.
5. When prompted, enter 0000 (four zeros) as your PIN or passkey.
6. Your phone will confirm that Pairing was successful and the Headset’s
Status Light will begin flashing slowly in blue.
Apr 22, 2010 | Cardo scala 700LX Bluetooth Headset
How to connect with bluetooh
You need to:
  1. ensure the bluetoothicon1.png setting is turned on on the handset
  2. switch on the scala 500
  3. press and hold the scala 500 power button until the red and blue lights are both flashing (you have to hold the button in for quite a few seconds)
  4. now you can search for new bluetooth devices from your handset and it should find it to enable you to connect
  5. if it asks you for a code/passcode the default is 0000 for this headset
Sep 20, 2009 | Motorola Mobility Cardo Scala 500...
How do i pair it wiyh my phone?
Try these:
  1. Turn your phone's bluetooth on. Maku sure your phone is discoverable.
  2. Press and hold call button on bluetooth headset until prompt appears on phone telling you to enter pairing code.
  3. Enter 0000 as default pairing code.
Sep 04, 2009 | Cardo scala 700LX Bluetooth Headset
Can't get existing bluetooth headset to work with new phone
I had that problem when I changed handsets. You need to:
  1. ensure the bluetooth setting is turned on on the handset
Jan 27, 2009 | Cardo scala-500 Wireless Headset
HOW TO PAIR A BLUETOOTH HEADSET WITH A SAMSUNG YPP2 MP3 PLAYER
You have to go in to the blue tooth option on the menu of the p2. Then click search. Hit the sync button on the headset. It should find it in less than 20 seconds.
Jan 19, 2009 | Samsung Cardo Scala 500 Hands-free Headset...
Wont work on my phone
The PIN is 0000 (four zeros). I own one of these devices and you will need to enter four zeros when prompted. Make sure you have the Bluetooth function enabled on your phone, then turn your wireless headset on. Select "Add New Device" from your cell phone Bluetooth menu and it should work. Hope this helps you.
Nov 24, 2007 | Motorola Mobility H300 Wireless Headset
Sanyo Katana SCP-6600 Cellular Phone Logo
859 people viewed this question
Top Sanyo Cell Phones Experts
Ekse
Steve Allison
Steve Allison
Wess Rohadfox
Wess Rohadfox
Level 1 Expert
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
