Question about Crane Humidifiers
Manuals Where to place Humidifier in the room for best results, near the bed or few feet away?
2 Suggested Answers
SOURCE: Aprilaire 600 only operates in test mode...
Thank you, got my problem fixed, after spend $275.00 call the service man to come. it come up to all about wrong wiring.all working and happy:) now.
Posted on Jan 05, 2008
What to Look For when buying room humidifier?
When going to buy a humidifier always check these points:
Technology used: Ultrasonic is good and inexpensive
Performance: The area it covers
Features: Does it offer both cool mist or hot mist
Design: compact and sleek design
customer support: The process of servicing and maintenance etc.
Read these top humidifier reviews to get the best
GroomNStyle Top 5 Best Humidifiers 2015
Jul 31, 2015 | Humidifiers
Why does my Honeywell HMW450 humidifier keep shutting off?
Here are a few things to check:
-make sure the heating element is clean. If there is a thick layer of scale (mineral deposit), then the unit will not turn on.
-there are magnets on the water reservoir that allow the unit to turn on. If these magnets are not lined up properly, then the unit thinks there is no tank, and thus, not turn on.
-turn the humidity up past your target point. The humidity near the unit could be a lot higher than the rest of the room, causing it to shut off prematurely.
Hope this helps!
Apr 29, 2012 | Honeywell HWM-450 4 Gallon Humidifier
I have a Humidifier and it used to provide my room with steam, know the water is warm but doesnt seem to produce steam like it used to...any suggestions?
i will like u to go through the manual and check the settings of the humidifier, if no change take place, look 4 a good repairer to fix it up 4 u
Apr 07, 2010 | Humidifiers
Won't humidify past 30% in a 90sf bedroom
The most probable reason that the humidifier does not reach the levels you describe is because you said you had the unit in your bedroom.
Bedrooms typically contain materials that are known as "hygroscopic." What that means in plain English is that items such as the bedding, mattress, any carpeting, wood, curtains, you, etc. all absorb moisture , kinda like a sponge. Since that moisture is being held by these materials, the air itself contains less by percentage. 25-30% humidity is actually pretty good for any room, especially in colder climates and higher humidity levels can lead to the production of mold, condensation on windows, etc., which are not good things. The good news is that reasonable humidity levels are healthier for textiles such as carpeting, cloth, and so on because the fibers won't dry out and crack. Dust is also reduced, but again, only to a certain level.
If your humidifier is reaching 30% it's probably working ok.
Mar 27, 2009 | Hunter 33201 Humidifier
Humidistat installation question
I suppose you are looking at the do-it-yourself model. Depending on the wire that is run up to you Regular Thermostat from your furnace. You may have to run a seperate line for the Humidistat. A digital thermostat that does Humidity and Temperature is recommended. Or you could just place a Humidistat near the furnace room. A wiring diagram will come with the Humidifier discribing the different ways to wire it.
Jan 09, 2009 | Honeywell Power Humidifier: Furnace...
The humidifer on the Sunpentown SH-1500 heater
what country are you in... winter time is low humidity to begin with.
Robert
Jan 06, 2009 | Sunpentown 1500W Heater Fan Humidifier...
Sunbeam Ultrasonic Humidifier, model: 697-6
Located My Manual:
Hope this helps!
1. Remove tank from base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled, or tap water. Water temp should NEVER be too hot or too cold. Return tank to base and let sit for a few minutes. Be sure the filling cap of the tank is tightened firmly.
2. Plug power cord into a 110-120V AC wall outlet only. Turn power switch to "on" position. Power light will illuminate. Turn mist nozzle until desired level is being released. Aim nozzle away from furniture and walls.
3. Always turn humidifier off when water runs* out. Unit will continue to operate when tank is empty.
*Humidifier will run up to 12 hrs on low; 6 hrs on high.
DO NOT LET WATER SIT IN TANK FOR LONG. THIS CAN ENCOURAGE BACTERIAL GROWTH.
Place unit on level surface away from direct sunlight.
DO NOT ADD MEDICATION OF ANY TYPE INTO THE NOZZLE, BASE, OR WATER TANK.
ALWAYS LEAVE ROOM DOOR PARTLY OPEN. DO NOT MOVE, TILT, OR EMPTY WHILE OPERATING.
Mild bleach and water solution for cleaning, never detergent.
Clean every 3rd day during use. Clean after long storage
Humidity varies from room to room. Aim for 30 - 50% relative humidity. If windows/ walls fog or frost, reduce mist intensity. If room too humid, ventilate by opening door or window; adjust mist intensity.
Sep 22, 2008 | Sunbeam Ultrasonic Humidifier
Thick Cloud of Steam
I would say that the beauty of steam is that it has to get through the 100 degree temperature to leave the aqueous state - i.e. to move from a liquid to a gas.
The benefit of that is that any organizums in the water should be killed as a result of that process. Its possible that it smelt musty or old stagnant water smells but to be honest there is little change of harm to the little ones.
Best wishes
Aug 08, 2008 | Vicks Ultrasonic V5100 Humidifier
White dust
Suggest you try using distilled water in the Humidifier in the baby's room. If your seeing that much dust you must have heavy hard water in your borough, suggest you replace the filter more often & or Demineralization Cartrid if your not already doing so.
Hard water is tough on many things in your home. Washing clothing can produce dark & light spots, some rust in color. Build up of rust & minerals through out the water lines in home. Bad taste. Build up of white stains in glasses & the list goes on.
The best choice would be a filtering system to remove most if not all hard water as it enters your water lines. Many companies near you can help you remove this problem. Listed below is one such company.
http://www.raindancewatersystems.com/maxicure.html
CPSC Issues Alert About Care Of Room Humidifiers
http://www.cpsc.gov/cpscpub/pubs/5046.html
Goog luck & Best Regards.
Thanks for using FixYa
please vote...
Jan 28, 2008 | Vicks Ultrasonic V5100 Humidifier
Humidifiers Logo
73 people viewed this question
Top Crane Humidifiers Experts
Danny Kuhlmann
solver2010
Tom Chichester
Are you a Crane Humidifier Expert? Answer questions, earn points and help others
