Hello, have you checked to make sure your washing machine is level ? ,and yes the arm is a possability thay also help support your drum. for the cost of labor i agree far cheaper and not a hard fix for the do it yourselfer. it does'nt sound like you need a neew drum just need to fix the one you got.
. Manually turn the motor and drum and listen for the
noise, if so the motor bearings, the drum agitator shaft and fittings must be
checked. Also the suspensions which include the shock absorbers and springs,
the body clamps must be checked to be in correct alignment and not changed in
position. Tightening of the mounting is
also very important. Finally in most cases a drop of OIL or smear of grease on
the moving parts cane solve most issues.
Check this link :
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Thanks for the advice. The inner drum is moving and I know it should not. I guess we will call sears to look at it.
