Question about Microsoft Office Standard for PC
Function how use vlookup in excel
I wanted know how to use Vlookup & Hlookup in excel sheet.
pls send with details to mail ID( with attchment if possible).
Thanks & Regards,
Srikanth
9885988557
Posted on Nov 19, 2008
Please give with examples .
Posted on Dec 03, 2007
    Master:
    Sergeant:
  • 461 Answers
VLOOKUP is to Searches for a value in the leftmost column of a table, and then returns a value in the same row from a column you specify in the table. Use VLOOKUP instead of HLOOKUP when your comparison values are located in a column to the left of the data you want to find. The V in VLOOKUP stands for "Vertical." Syntax VLOOKUP(lookup_value,table_array,col_index_num,range_lookup) Lookup_value is the value to be found in the first column of the array. Lookup_value can be a value, a reference, or a text string. Table_array is the table of information in which data is looked up. Use a reference to a range or a range name, such as Database or List. If range_lookup is TRUE, the values in the first column of table_array must be placed in ascending order: ..., -2, -1, 0, 1, 2, ..., A-Z, FALSE, TRUE; otherwise VLOOKUP may not give the correct value. If range_lookup is FALSE, table_array does not need to be sorted. You can put the values in ascending order by choosing the Sort command from the Data menu and selecting Ascending. The values in the first column of table_array can be text, numbers, or logical values. Uppercase and lowercase text are equivalent. Col_index_num is the column number in table_array from which the matching value must be returned. A col_index_num of 1 returns the value in the first column in table_array; a col_index_num of 2 returns the value in the second column in table_array, and so on. If col_index_num is less than 1, VLOOKUP returns the #VALUE! error value; if col_index_num is greater than the number of columns in table_array, VLOOKUP returns the #REF! error value. Range_lookup is a logical value that specifies whether you want VLOOKUP to find an exact match or an approximate match. If TRUE or omitted, an approximate match is returned. In other words, if an exact match is not found, the next largest value that is less than lookup_value is returned. If FALSE, VLOOKUP will find an exact match. If one is not found, the error value #N/A is returned. Remarks If VLOOKUP can't find lookup_value, and range_lookup is TRUE, it uses the largest value that is less than or equal to lookup_value. If lookup_value is smaller than the smallest value in the first column of table_array, VLOOKUP returns the #N/A error value. If VLOOKUP can't find lookup_value, and range_lookup is FALSE, VLOOKUP returns the #N/A value.
Posted on Aug 30, 2007
3 Suggested Answers
Sudrajat
  • 20 Answers
SOURCE: about function
Dear sourabh, lookup function is used, when you're trying to use some calculation using a small parameter, vlookup = vertical lookup, so when you're using a vertical parameter you must use vlookup and hlookup for using horizontal parameter,so you act as if you had a small database which is used to help your formula.
Posted on Aug 27, 2007
CNewton2
  • 27 Answers
SOURCE: M.S. Excel , vlookup formulla tell me use
I love vlookup!
Suppose you have 1 worksheet with song numbers and titles in Row 1, Cols A:B:
Song# Title
123 Love Me Tender
234 Blue Suede Shoes
345 Dixie
Another worksheet has song number and performer in Row 1, Cols A:B
Song# Performer
123 Elvis Presley
234 Carl Perkins
456 Cher
Notice there is NO performer for song number 345 in the 2nd worksheet.
Now in the 1st work sheet, cell C2 insert this LOOKUP function: =LOOKUP(A2,Sheet2!A:B)
Copy that cell to row 3 and row 4 in Col C. You should get a Performer for all songs even though there is not a song number 345 in the performer worksheet.
Help me out Mr. VLOOKUP.
Insert this VLOOKUP function in cell C2 of the first worksheet: =VLOOKUP(A2,Sheet2!A:B,2,0)
Copy that cell to row 3 and row 4 Col C. You should get the performer names for the 1st 2 songs, but not for 345 Dixie. The result should be #N/A.
That means VLOOKUP could not find a DIRECT match for song 345 in the second worksheet.
That is why I prefer VLOOKUP over LOOKUP.
I have found this explaination of the VLOOKUP parameters helpful:
1. Needle (A2)
2. Haystack (Sheet2!A:B)
3. RELATIVE Col containing result (2)
4. Need DIRECT MATCH ONLY (0)
Hope this helps.
Posted on Oct 10, 2007
What is vlook up & what is hlook up?
The VLOOKUP and HLOOKUP functions contain an argument called range_lookup that allows you to find an exact match to your lookup value without sorting the lookup table
I have posted below link to know more .Please have a look..
http://www.howtodothings.com/computers-internet/how-to-use-the-vlookup-and-hlookup-functions-in-microsoft-excel
http://support.microsoft.com/kb/181213
http://office.microsoft.com/en-us/excel-help/vlookup-HP005209335.aspx
http://www.timeatlas.com/5_minute_tips/general/learning_vlookup_in_excel
Please rate & vote if you like soution..
Thanks
Sandeep
Mar 14, 2011 | Microsoft Excel for PC
What is vlookup in ms excel
It is a function in excel that will look up to a value or data located in different sheet or in different cells. It is very helpful function to look for a bunch of data and compair and extract the exact information. syntax: =vlookup(lookup_value,table_array, col_index_num,[range_lookup])
Aug 27, 2010 | Computers & Internet
What is the use of vlookup in excel?
The VLOOKUP function is a handy one to know when you want Excel to lookup a value in one place and insert it in another. For example, let’s say you have a list of all of your customers on a sheet named “Accounts” and an invoice on another sheet named “Invoice”. When you type in their account number on the Invoice, you want Excel to fill in the name of the customer and their address (and this information is included for all customers on the Accounts sheet). A VLOOKUP will do this for you.
Here's a tutorial that will help:
http://www.timeatlas.com/mos/5_Minute_Tips/General/Learning_VLOOKUP_in_Excel/
Jun 12, 2009 | Microsoft Excel for PC
Dont understand how to use vlookup in excel 2007
This tutorial also helped me much to understand how vlookup works:
http://www.myhowtoos.com/en/excel-howtoos/84-how-to-match-values-in-excel-using-vlookup
Feb 18, 2009 | Microsoft Computers & Internet
What are uses of vlookup n hlookup?
An implementation of the vlookup in Excel could be:
You have an Excel table with student names and their grades.
You wish that you could somewhere in the sheet type a student name, and immediately retrieve his grade (based on the data in the table).
To achieve this, you can use "Vlookup": the function will look for the student’s name in the first column in the table, and will retrieve the information that is next to his name in the second column (which is his grade).
Hlookup is the same excpet it is for data arranged by rows instead of columns.
Dec 29, 2008 | Microsoft Office Home and Student 2007...
What is vlookup & hlookup?
1024x768 Normal 0 false false false /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} These are Excel functions for Lookup tables. The purpose of Lookup tables is to bring a value to the table, find the closest (or exact) match, and then return another value.
An example is the federal income tax table. On your tax return you get your gross income and number of dependents, go to the Lookup table, and find your taxable income.
The V in VLOOKUP means that the table is vertical; HLOOKUP has a horizontal orientation.
If you use the Insert Function button in Excel and paste either function, the dialog box will explain each required field separately with examples.
Dec 02, 2008 | Microsoft Excel for PC
EXCEL VLOOK Function
Just noticed a small syntax problem, try this:
VLOOKUP(S9,$S$14:$T$18,2,0)
I always add the last parameter of "0" to insure that that an exact match is found.
Jul 27, 2008 | Computers & Internet
I love vlookup!
Song# Title
123 Love Me Tender
345 Dixie
Song# Performer
123 Elvis Presley
234 Carl Perkins
456 Cher
1. Needle (A2)
Hope this helps.
Oct 10, 2007 | Microsoft Office Standard for PC
About function
I love vlookup! Suppose you have 1 worksheet with song numbers and titles in Row 1, Cols A:B: Song# Title 123 Love Me Tender 234 Blue Suede Shoes 345 Dixie Another worksheet has song number and performer in Row 1, Cols A:B Song# Performer 123 Elvis Presley 234 Carl Perkins 456 Cher Notice there is NO performer for song number 345 in the 2nd worksheet. Now in the 1st work sheet, cell C2 insert this LOOKUP function: =LOOKUP(A2,Sheet2!A:B) Copy that cell to row 3 and row 4 in Col C. You should get a Performer for all songs even though there is not a song number 345 in the performer worksheet. Help me out Mr. VLOOKUP. Insert this VLOOKUP function in cell C2 of the first worksheet: =VLOOKUP(A2,Sheet2!A:B,2,0) Copy that cell to row 3 and row 4 Col C. You should get the performer names for the 1st 2 songs, but not for 345 Dixie. The result should be #N/A. That means VLOOKUP could not find a DIRECT match for song 345 in the second worksheet. That is why I prefer VLOOKUP over LOOKUP. I have found this explaination of the VLOOKUP parameters helpful: 1. Needle (A2) 2. Haystack (Sheet2!A:B) 3. RELATIVE Col containing result (2) 4. Need DIRECT MATCH ONLY (0) Hope this helps. Let me know if you have any questions.
Aug 27, 2007 | Microsoft Office Standard for PC
Microsoft Office Standard for PC Logo
235 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
