Fuji xerox c250 paper jam
And something noise inside the machine
SOURCE: fuji xerox document centre C250
Press machine log in button, enter 11111 confirm, this will take you to sys admin mode, from here you can navigate into sys settings to configure network,copy and fax defaults, and also auditron admin if this is the password mentioned, if the 11111 password has been changed hold the zero button for a few seconds then press start while still holding zero enter 6789 to get into diagnostics, and you can navigate through to the above settings caution be careful what you change in this mode.
Posted on Sep 04, 2008
  • 37 Answers
SOURCE: xerox phaser 8560 DN is
There is mostlikey a scrap of paper that you can not see still in the machine. You can gently walk a thicker piece of paper through the paper path and see if it pushes out the obstruction. Be very careful not to scratch the drum when you try this.
Hope this helps
Posted on Dec 04, 2008
yooperbud
  • 8637 Answers
SOURCE: Xerox WorkCentre PE120i - Paper Jam 1
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 28, 2009
  • 13433 Answers
SOURCE: Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 11, 2009
SOURCE: Fuji xerox won't pick up paper for printing.
Managed to get it going ,pulled all the toner cartridge out and reset and all is sweet.....!
Posted on Aug 31, 2009
Xerox workcentre 5765 paper jam message but no paper is jammed
Check all the paper detecting sensors once more, may be there is something over the sensor.clean all the sensors with VIDEO 90. if after that problem persist please restart the machine and go for software and firmware upgrades.
GOD BLESS YOU
Oct 20, 2012 | Xerox WorkCentre 5765 5775 5790 Fuser...
I have a Fuji Xerox 525a colour laser printer which is giving a phantom paper jam message (error message indicates paper jam in cover E, but it is clear) What can I do to clear this message as it...
I beleive there are only two paper sensors for that machine.
1- in the tray there is a paper empty sensor which hangs down,
make sure you take out the tray and look for any pieces of paper stuck.
2- open right door and look as if your looking inside to where the paper is supposed to end up. The sensor is in that black unit, is there any paper there, can you see a black lever, if you pull on it gently and let go does it snap back in place?
Jun 21, 2008 | Fuji Office Equipment & Supplies
Fuji Xerox cm205fw keep getting paper jam message
Just for any others with this question, I have been plagued with the same problem with my CP205 and CM205 printers, and discovered with the CM205 that it does still have a small scrap of paper left in the end of the paper path, near where it ejects. This can't be seen if you are looking inside the printer from the back door, hence anyone thinks it's clear, but if you open the main top door, by lifting up the control panel, and shine a torch down there, that's where you will probably find the small scrap of paper, which is stoping the printer from working. I managed to remove mine with a set of small tweezers. It would help if the machine could give you a more accurate error message, eg, lift the TOP door and remove paper jam.
Cheers, Vaughan
Jun 25, 2012 | Xerox Office Equipment & Supplies
Drivers for Xerox C250
Hi, if you click on the below link -
Xerox C250
it will take you to Fuji Xerox driver download page, just select your operating system and langauge, click go and it will take you to the correct driver you need to download.
Thanks, if this solution helps please rate :)
Feb 21, 2011 | Computers & Internet
Aug 30, 2009 | Xerox DocuPrint 203A Laser Printer
Clicking sound and crumpled paper
Bad heat roll drive gear in the fuser. Very common problem.
Look up on google a business called "The Parts Drop". Ask for Britt, part is $13 or $14.
Aug 31, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Fuji xerox document centre C250
Aug 02, 2008 | Xerox WorkCentre M123 Copier
Xerox PE 220
first with any jam message, identify if you have actually had any paper jam in it in the first place, especially if you are turning up to site and you're getting 2nd hand info. IE "oh no it just said that ...one day"
so assuming it actually had jammed paper in it that was removed at some point, find out where it was jammed...front or back. how it was removed...via front or back. note! many printers dont like having paper pulled out in the reverse direction to which the paper normally travels, this sometimes catches little flags and breaks them or pulls them out of position and the little photo sensor that is normally closed is then left 'electrically/optically' open so the printer sees this as a jam as soon as its finished booting up.
okay assuming you have gathered reliable info re the above.
check that area of the path for what looks like a small swinging flag, or maybe a little black 'U' shaped sensor that looks like it should have a flag in it.
remember the print will/can only say there is a jam if a sensor is stuck..open/closed or how it 'shouldnt be normally.
if you're out of luck you may find the pieces of a flag loose in the unit.
ideally they have a bit of flexability and just pop out.
BIG rule...dont force 'remove' jams. if it wont come out, contact someone with a bit of mechanical ability, even if they arent a printer tech, (like myself) then at least they have an 'intact' unit to work with so they can see how its supposed to work and just pull it apart to clear the prob area.
ok...so assuming you've found the area, if the flag is broken i wouldnt try making bits up to do the job, timing is critical, unless you can glue it back together exactly right then dont bother, you'll likely get timing related jam messages. just contact the manufacturer, see i you can get a part number. it may cost you a few bucks for a bit of plastic but its the best way trust me.
HP, lexmark, and fuji xerox i have found pretty good with parts down to a small level. some other brands i wouldnt touch with a barge pole.
after all this. most jams are in the fuser and most people are rough as guts and usually break something in the fuser by yanking it cos they're angry.
most fuser can be sort of pulled apart into sub components (although its not expected in my industry) so if you have an intact fuser but its got a heavily 'fanfold' paper in it so tight you dont even know its there, dont dig it out with a screwdriver, if you score or scratch the surface of the rollers then you done your money there. better to look at it for a bit, try to work out how to loosen it apart and remove the jam, inspect the rollers for scratchs or damage, andreassemble it.
(15 years repairing this gear, the methods are pretty much similar thinking for most printers when physical issues are the prob.) best of luck. - keith
May 14, 2008 | Xerox WorkCentre 220 All-In-One Laser...
GRINDING NOISE or PAPER JAM
If you are not a technical person best thing to do is to show it to an expert. grinding noise means some part in the machine is running with the friction. and might brake something or scratch something. Find out persons who work on photocopiers in your area either samsung or Xerox. as this model comes with both the companies and Xerox people are generly better than samsung people.
Apr 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
15 people viewed this question
k24674
jasbo
jasbo
