Question about Boating
Johnson outboards model# RXE 10C serial#352125
captainjeffq
  • 52 Answers
SOURCE: 1974 60hp johnson outboard won't run on full throttle.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
Posted on Apr 13, 2009
  • 6 Answers
SOURCE: 1974 johnson outboard motor 25hp stalls when hiting high end
Not familiar with that specific motor but had similar vintage smaller HP Johnsons. From my experience it sounds like it could be that the high speed carb adjustment is too lean. What I would try is running the backing off the high speed screw 1/4 turn to 3/4 turn, then test. If works better, screw back in in 1/8 turn increments until the problem recurs, then back out 1/4 turn and leave it there.
Posted on Jun 30, 2009
SOURCE: Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Posted on Jul 25, 2009
SOURCE: Does an 85 johnson outboard motor 15 hp have
breaker/maker. set @ 020" @ the highest point but what is you're real problem. Run only champion spark plugs. We spenta dAY @ omc'S SERVICE CENTRE BEING SHOWN WHY. tHEY KNOW BEST!!
Posted on Oct 20, 2009
  • 406 Answers
SOURCE: what is the year model of a evinrude outboard motor with the serial number 1503201749
try reading this on ehow http://www.ehow.com/facts_7292301_evinrude-year-identification.html
Posted on Jul 27, 2014
How to find the model number for my johnson outboard from serial number
On the port side where the outboard attaches to the boat there is a plate that has your engine model and serial number.
May 07, 2017 | Johnson Boating
Year of manufacture of Johnson 40Hp outboard Model No AJ40BALE1A Serial No. G02651879
Ed,
Near as I can tell, it's a 1979. As of 1980, Johnson/Evinrude used two LETTERS at the end of the model number to designate the year. (See attached) Your model number ends in a number and letter (1A) which leads me to believe it's earlier than 1980. Prior to 1980, the last two numbers of the serial number were the year. That's how I surmised yours is a 1979, by the last two of the serial. G02651879
Hope this helps.
Fred-
Outboard Engine Serial Number Year Match up
Dec 05, 2016 | Boating
What year is a evinrude outboard with serial number 1451821
The motor HP is critical in such searches. Here are all the resources you need to find the information yourself.
About this result
How To: Outboard Engine Serial Number Year Match, iboats.com How ...
www.iboats.com/basics/serial_number_year.html
  1. Cached
  2. Similar
For engines prior to 1969 refer the the Johnson 1960-1979 serial number year chart located here. If you have a commercial model refer to the Johnson commercial serial number year chart located here. Evinrude changed how they indicate year in the model number in 1980.Mercury Outboard · ‎Evinrude Outboards 1950-1979 · ‎Johnson Evinrude Commercial
[PDF]5006145_Model Number Reference.fm - Evinrude
shop.evinrude.com/media/document/ModelNumberReference.pdf
  1. Similar
MODEL NUMBER DESIGNATION - OUTBOARDS. Model Years 1980-1998. V E 70 T L ED A. MODEL VARIATION. A = Australia. B = Belgium. C = Canada.
Evinrude Outboard Motor Model Numbers & Codes - Marine Engine
www.marineengine.com/manuals/evinrude/
  1. Cached
  2. Similar
The nameplate should contain a model number and a serial number. The model number will identify the year and certain details of that motor. 1980-Present: Evinrude outboards from 1980 to the present use a model number that can help determine the year and features of the motor. See the model number code here.0.5HP · ‎0.9HP · ‎1HP · ‎1.1HP
Marine Motor Look-Up Guide - Auto Repair Manuals
www.autorepairmanuals.biz/page/599222
  1. Cached
  2. Similar
keywords: Find year, serial, number, model, number, #, outboard, motor, marine, motor, look-up, Johnson, Evinrude, Mariner, Mercury, Force, OMC, Yamaha, ...
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE ...
www.maxrules.com/models/OMC_models_files/EVthru79/ev_index_79.html
  1. Cached
  2. Similar
WHAT YEAR IS THAT OLD EVINRUDE? FIND OUT HERE ON OUR MODEL YEAR LOOKUP CHART! evinrude outboard with serial number Google Search
Nov 29, 2016 | Boating
HOW DO I TELL THE AGE OF MY EVINRUDE OUTBOARD
get the serial number then go google and type in -- serial numbers of evinrude outboard motors-- and select a site where you enter your serial number
or you take your serial number to an evinrude/ johnson outboard dealer and have them look it up
Sep 19, 2016 | Boating
Johnson V4 outboard #C0020325 I'd like to know the year and hp of this engine
call your local outboard dealer . they will help you figure it out
Sep 12, 2016 | Boating
What year and model is a Johnson outboard serial number MN02705CN0121. The model number tag is missing.
That serial number doesn't seem to match any of the formats I have found. The "CN" could indicate the year 1982. The "MN" could indicate manual-tilt and counter rotation.
From this resource: http://www.maxrules.com/OMC_models.html
Oct 06, 2014 | Johnson & Johnson Health & Beauty
What year is a johnson 4 hp outboard serial number b 7643180 model number bj4brccs
To get the year of Johnson and Evinrude outboards use the word "INTRODUCES". Each letter corresponds to "1234567890" respectfully. It's best to check with a model year reference book, but this motor's model number contains "CC" which would indicate it's a '88.
Sep 21, 2014 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
Can i find the year of of manufacture of my old johnson 25 hp outboard motor by its serial number?
yes if yuo go to iboats.com the forum will allow you to search by serial number and give info on your outboard.
Aug 17, 2013 | Sierra International 18-4310 Marine...
Boating Logo
26 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
