Question about Remington MB-300 Beard Trimmer
Trimmer Not Charging - No CHARGE Light too.
I bought this titanium mb 300 just recently, almost 3 weeks now. I recharged fully twice i guess during this period. And this time when the battery was almost getting over i kept it for charging but there is no CHARGE light and it doesnt charge. Any idea whts the problem?
  • 2 more comments
  • Anonymous Apr 11, 2008
    I have the MB-200 and it is not charging.
  • jithin_m Apr 12, 2008
    i found out the solution..
    its the issue with the adapter..
    mainly due to voltage difference...coz i bought this in usa and i was using it in uae..
    even though i used a voltage converter, it didnt work.
    @suni1911 : try changing the adapter, it should work perfectly fine.
  • Anonymous Nov 29, 2008
    remington mb-35, same problem. no charge light. no power
  • Anonymous Mar 13, 2014
    I received the Shaver Model MB-975 for Christmas. I went through the charging period and the Shaver worked great, but now the Shaver will not hold a charge. After a day the Shaver does not work! What can I do! [email protected]
I have the same problem using Remington MB 200
Posted on Apr 11, 2008
I had the same problem, I suggest that you go to your local WAL-MART and return it. Just tell them you want to exchange with a different one and forgot the receipt. This works because I did it with my Remington MB 300 Beard Trimmer.
Posted on May 21, 2008
SOURCE:
Battery not holding charge very long
I've written up a complete step-by-step tutorial on how to replace the battery on a Remington MB-300 Beard trimmer: John Fixes Stuff How to Replace the Batteries in Remington MB 300 Beard...
Apr 06, 2014 | Remington MB-300 Beard Trimmer
Troubleshoot/Repair Remington MB-1000 Beard Trimmer
If you leave the batteries in the charger with the mains power turned off then the batteries are probably being drained by the charger. Get new batteries and when flat (only flat not just used or part flat) recharge fully then remove from the charger unit. Rechargeable batteries have a habit of developing a memory as if you recharge a part charged battery then it will only recharge to that flat point
May 30, 2013 | Remington MB-1000 Professional Beard and...
Remington mb300 battery replace how
The rechargable nickel-cadmium is hard-wired and not replaceable.
Instructions for removing the battery from the user manual:
1. Make sure your groomer is unplugged from any outlets so you don't risk an electric shock.
2. Remove side panels/grips
3. Remove the 4 housing screws
4. Pull or gently pry the clipper halves apart, exposing the batteries.
5. Remove batteries from the unit.
6. Twist batteries to break wires. Wires may also be cut.
I also own an MB-300. The battery still works good and I loved this trimmer but I need a new cutter blade for mine.
Jan 01, 2013 | Remington MB-300 Beard Trimmer
How do I make the new iPad's battery recharge faster?
There are many things you might be doing wrong but slow battery charge is a problem with the new iPad. The battery is actually a lot bigger than the iPad 2 which means it is going to take you much longer to charge.
Use the provided charger and don't charge from your computer. It is almost twice as slow to do it plugged into a computer. Charge it at night to give it the most time to charge as possible. I usually turn it off so programs don't run and slow down the charging speed. Every little bit helps.
I can help you with other things too if you ask.
Mar 27, 2012 | Apple iPad HD
Tried to charge my Coleman Retro Lantern, the red light for charging is on but after 24hrs charging, I take the charger off and try to turn the lantern on, it wont work. How can I fix this...
I just bought a retro rechargeable sealed battery,recently. I charged it for 18 hours,the lights all worked,but I don't remember the green light comming on.i put the lantern away for 3 months or so.i decided to check the the battery light out first week of june, the light was there,then I said let me charge it up again, I never seen any green light come on showing it was fully charged. I took the battery out and checked the wires to see if there was a break. None that I could tell. After you take the battery out ,there is another section square that covers where the bulb is located,but I didn't touch that part yet. Stuck" on this one. Help"
Sep 15, 2011 | Coleman Retro Rechargeable Battery Powered...
My Remington Titanium MB 35 beard trimmer has a rechargeable battery, but the charge now lasts for a very short period of time. I can't see how to change the battery. Is it possible to change the...
Yes you can have the battery replaced. This however needs to be done by an Authorized Service Dealer. To find your nearest dealer in the USA, use the online search function here:
http://www.remingtonproducts.com/ConsumerService/AuthorizedServiceDealers.aspx
If you are in another country, go to the top right of the screen, mouse over the Country and select your country. Look for a tab for the Authorized Service Dealer search function.
Feb 27, 2011 | Remington MB-35 Beard Trimmer
I recently purchased the G370 Norelco hair trimmer, I used it only once after a 4 hour recharge, then when came the time to recharge it again, the light on the charger didnt glow and the machine wasnt...
S.O.B! Just bought the bastard 3 weeks ago after I had another one before it that didn't last even a month. THEY WON'T CHARGE A BIT!!! The damn light glows as if it's charging but the device never turns back on. This damn company can GO TO HELL!!
Apr 18, 2010 | Philips G370 Hair Trimmer
Can't charge the battery anymore (device was not used during couple of months)
pls first confirm the charger is working or not and then kindly leave the pda for like 2 hours on charge it will start charging , when u store these devices for longer period kindly fully charge the battery and then store , when battery drains during non use it drops to a certain level from where it might come back or might not , pls leave the battery on charge for like 2 or 3 hours first and then u will see charging signs or light
pls rate me well !
May 17, 2009 | HTC Qtek 9100 Smartphone
Remington MB-300 Beard Trimmer Logo
3,638 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Robert McClure
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
