AQUACAL KRUSIN KOOL - Heating & Cooling
How do i wire an aquacal 155 heat pump?
Contact a pool supply store or the manufacturer for manual.
If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
Jun 03, 2014 | Aquacal Heat Pump Pool Heater 155
Leak in heatwave aquacal
replace aquacal exchange or where leaking
May 20, 2014 | Jandy LXI 300 PROPANE POOL HEATER -
The fan on the AquaCal heatpump stays on when the water pumps turn off.
check pressure switch should work when pump on then off when pump off if ok bad control board
Dec 28, 2017 | Aquacal Heat Pump Pool Heater 120
Need stroller manual
Either call Kool Stop in Oregon and ask for the Kool Stride manual you need or download this online one which is similar...
http://ebookbrowse.com/kool-stop-kool-stride-sr-paramount-series-jogging-stroller-owners-manual-pdf-d359030674
Apr 10, 2012 | Baby Gear
AquaCal Model 120 AHDEBNC message on panel wont clear. Message is FLO. There is water flowing thru the heater and the filter is clean
If you have a by-pass, (This will be a pipe that runns in between the in and out pipes on the heater) The valve must be almost closed in order to get enough volume through the heater to get it to run.
Make sure that heater has enough time to respond to this adjustment. It will take up to five minutes to start.
Oct 27, 2010 | Aquacal HeatWave
HEAT PUMP SAYS WATER TEMP IS 99 DEGREES WHEN ITS 82 CAUSEING PUMP NOT TO TURN ON WHATS THE REMEDY NOT SURE ON BTUS MODEL NUMBER IS 120AHDEBNC AQUACAL kind of in a bind thanks
This is a bad temp sensor or an open by-pass. You would have to go to your book to find these though. I'm not sure where you would find them.
Oct 13, 2010 | Aquacal HEAT PUMP 120,000 BTU H135 -
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
