Bosch model # 0601476260
SOURCE: Table Saw blade
Did you remove the center plate? It has to come out before you can remove the blade. Also make sure that the saw is unplugged before you go any further. If you still have questions contact me and I will do what I can. Also if you would like you can download a schematic of this tool at Makitatools.com just type in your model and look at the schematic. Good luck
SOURCE: I purchased the Bosch saw blade on Ebay
If the arbors the same and you're running with in the RPM rating, it will be fine. But ALWAYS wear your safety glasses.
SOURCE: I'm looking for a manual for a Craftsman table saw model 137.2488
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0606545.pdf
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
SOURCE: Bosch 4000 table saw. The saw stopped while
If you are mechanically inclined and it sounds that way do you have a volt ohms meter?? If so start at the cord and check the continuity to the brush holders. Why did you replace the field? You might have had a stuck brush or some other problem. Make sure the brushes move freely in the tubes and also look for discoloration on the commutator of the armature. Let me know what you find and I will try and help you thru the rest of it.
