Question about LG 60pk200 60 1080p Plasma Tv 60pk200
Sound no power for 60pk200
I turn the tv on I can hear the sound but I have no picture. I changed the power supply board and I still dont get anything. I think the other board was bad.Can someone help me?
  • 5 Answers
SOURCE: LG 47LC7DF Green Light Blinks 16 Times - No Picture or Sound
The lights indicate what the issue is. Kind of like your check engine light in your car tells you something is wrong with the engine.
Posted on Aug 31, 2009
SOURCE: LG 42PX4MVH PLASMA TV - Sound but no picture.
I have the same issue with my LG 42PC3DVA and I narrowed it down to the Y SUS board. After a little research there are a few items that are prone to go. The ceramic fuses (as you found), sometimes the capacitors on the Y SUS, Z SUS, and power supply go along with them You can tell because thy will be bulged at the top instead of flat. I replaced a few of my capacitors - they are only $0.89 each so it was MUCH cheaper than a board.
The other thing that is common on the Y SUS in particular are the FETs (also called MOSFET). They can be replaced if you are good with a soldering gun but they are static sensitive so be grounded. They are also a bit tricky to test so you may want to do some research on how to determine if this is the issue... or you can just replace the whole board.
Posted on Oct 28, 2009
  • 380 Answers
SOURCE: to make a long story short originally bought the
Sounds like the y sus was blown out but what cause it. Were you careful when you were checking voltages? As long as you didn't short 2 components together, your y sus should be fine. Unless the y buffer up and/or down blew them out. Even the panel could blow it.
Basically you need a scope to adjust the ramps and everything. You can adjust VA and VS with a meter. If you don't have access to a scope, then just start changing the ramps etc by eye. It might take a little bit to get but eventually you'll get it.
Posted on Mar 14, 2010
  • 222 Answers
SOURCE: Need a new power supply. Where?
Try E-bay
Posted on Jun 06, 2010
Testimonial: "THanks."
SOURCE: while checking Vscan voltages on my LG du-42px12x picture died.
I have the same problem the pic went out but have sound. where do i go to get the Yboard? do i need a special number off of it or something? I took it to repair shop and he said it would be like 500 dollarss to repair. but i see all kind of yboards on ebay for like 150?? how do I know what one to buy?
Posted on Aug 08, 2010
No picture only sound.
Engineers are right, you need a new LED panel., or the component that supplies the light to the screen.
Mar 18, 2016 | Philips 55pfl4706df7 4000 Series Lcd...
My tv had a few small vertical lines for year, then went black completely. Sound still works, but no picture. What part/board am I looking to replace?
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 17, 2015 | LG 60pk200 60 1080p Plasma Tv 60pk200
I have Sony tv kdl50xbr4 , had sound no picture.the tv had to turn on,off several times to have the picture!any help please
Dont know how much you like to tinker but or if you know someone. A TV has different circuit boards. One for power one for picture, one for sound, one for tuning. Power board works everything, picture board goes to to the tube, sound board connects to the speaker. Probably gettin kinda complicated all else fails have it repaired or upgrade.
Hope you find a solution that works best
Feb 04, 2015 | Sony Televison & Video
Have a vizio vx 42l on the bench. amber light only no power up have my standby 5vdc and my 3.3vdc power button is sending a high pulse to the main mod but i dont get pson to the power supply mod suspect...
This is your mainboard needing replaced! Simple as that!
The main sends the pson signal and without it...you have a dead tv.
Please rate if this helped :)
Mar 10, 2011 | Vizio 42 in. LCD TV
Popping sound and then the picture went out no sound makes a crackling sound and the blue led light just blinks
Hello
The sound you heard is probably a cap that has blown on the power supply. On plasma tv's some times you can hear the buffers pop but you said this is an LCD and that is USUALLY a blown cap.
The good news is power supply boards can be found on ebay. Or if you have a local electronics guy he can replace them. Sometimes a blown cap just happens, and sometimes its a sign of bigger problems so I tend to replace the board.
If you are comfortable you can take the back panel off, find the power supply board and look for caps with DOMED TOPS or BLOWN OFF TOPS. And then you can be sure. In most cases the power supply board is easy to find, the power cord plugs in to it.
PLEASE PLEASE dont put your fingers where they dont belong, and if you dont know what you are doing call someone who does. No tv is worth calling 911 to get your heart restarted.
Best wishes
Nov 25, 2010 | Televison & Video
When I went to turn on my 20 month old 46in LCD LN46A500 it made the loudest high pitch screeching sound that no one would like to hear and the picture was black. The remote buttons and the TV control...
The power supply board have fail badly,all that high pitch screeching sound,it came from those high voltages gaps from those tranformers,that giving ur tv high voltages.The power supply board,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 25, 2010 | Samsung LN46A500 46 in. TV
The tv isnt turning on at all what is the problem
Targa 32" LCT TV, No picture/ sound only can hear clicking sound from Kisan KP-301R Power supply board. Have checked output voltages and they are a little out i.e. 16v instead of 17.5v and 10.5v instead of 12v.
Has SAMWHA capacitors but cannot see any bulging or leakage anywhere like other users have suffered so dont know if changing all the caps will solve the issue.
Before it finally went dead LCD TV would switch itself off after some time and just a few days before it dies it started the clicking sound but would then start up okay.
Jun 18, 2010 | Sylvania LC225SSX LCD TV
Tv sound but no picture
The backlight inveter board may have gone out ,or the power supply is not working to supply power to the inverter board, those are the two places to look.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 08, 2009 | Televison & Video
TV turns itself off after a few seconds, no picture at all
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Mar 28, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
LG 60pk200 60 1080p Plasma Tv 60pk200 Logo
75 people viewed this question
Computer Repairing
Computer Repairing
