Eclipse portable media player 2.8v
How to fix eclipse mp3 player keeps saying generate database
5 Suggested Answers
SOURCE: my mp3 player doesn't player
If you are using the Sony Sonic Stage software, then it might be
a good idea to just format the MP3 player and start over downloading music to it. You have to use the Sony Sonic Stage software or else it gives you the NO DATA BASE error, even if
you have music on it.
Posted on Aug 31, 2008
SOURCE: sansa mp3 player freezes at refresh database
The Same thing happened to Me once. All you have to do is reformat it. You can do this by first putting the player in recovery mode. You can do this by putting the hold button on the side where you can see the orange and then plug the device into the computer while holding the power/Menu button. Then go to my computer to Verify that it came up as 16MB-Format. Then you can type into the address bar and type in http://mp3support.sandisk.com/firmware/rhapsody-1.0.2.165.zip. then once you do that right click on the file you downloaded and select open with compressed folder and drop and drag to the 16MB-Format drive. In the 16MB-Format drive folder select file menu and select New - Folder and rename it sansa.fmt then press enter to save. Finally move the hold switch back and disconnect the device and look at the screen and verify it is formatting and resetting once it's done and finishes the updates restart and if needed pick your language. check and see if you can use your player.
Posted on Aug 31, 2009
  • 6 Answers
SOURCE: I got a cheap Eclipse portable media player for my
Use a USB cable and connect it to your PC's USB connection
Posted on Jul 29, 2010
Thompsons196
  • 350 Answers
SOURCE: my windows media player won't sync with my mp3 player
Go to Run enter regsvr32 wmp.dll RUN AS ADMINISTRATOR if needed if the problem is there it should fix it.
Posted on Jan 27, 2011
How do i reset my eclipse fit clip plus 8gb device it keeps freezing
That could be a short in your mp3. You should be a small hole somewhere on it that says reset. You would need to get a needle or something that thin and push the button inside the hole and hold it for ten seconds. That should fix your system.
Feb 26, 2015 | Eclipse Fit Clip Plus 8GB* MP3 Player
I when i turn on my 4 gb eclipse portable media player it gives me an error and wont start or charge please help me?!
If the player itself works OK, then it's most likely a damaged USB cable or port that is the casue.
May 13, 2014 | Eclipse 180 BL 8GB 8 GB Portable Media...
My mp3 player does not oplay
My player will work as long as it is plugged into adapter. Once I remove from charger or adapter, it will not play or work. What can I do to fix this problem. It is brand new.
Dec 28, 2013 | Eclipse -180 Pl 4gb 4 Gb Portable Media...
My Eclipse Mp3 Player Wont Play
1) There's a difference between "support" and play directly of video mp3 player.
2) It's not just about the format, but also screen size and resolution.
You need to run the music through the converter tool that is on the player itself (like a portable dirve, look into it's directories) or as a small CD that came in the player's kit.
May 11, 2012 | Eclipse -180 Pl 4gb 4 Gb Portable Media...
My eclipse portable media player is frozen it turns off **** it stays on a blue screen dat says eclipse
I need detailed instruction on how to put a Eclipse V215 mp3 player back together. The warranty already expired so I'm fixing it on my own.
Jan 12, 2011 | Mach Speed Eclipse V215 (2 GB) MP3 Player
I I have an Eclipse Portable Media Player 180BL 8GB and i was wondering what formats this media player plays
Please rate me for this free answer
Mach Speed Eclipse 180 8GB MP4 Player
gfx-blkbullet.jpg Type: Other MP3 & MP4 Players pixel-clr.gif pixel-clr.gif pixel-clr.gif gfx-blkbullet.jpg Supported Formats: WAV JPEG MP3 WMA TXT AMV pixel-clr.gif pixel-clr.gif pixel-clr.gif gfx-blkbullet.jpg Internal Storage: 8GB pixel-clr.gif pixel-clr.gif pixel-clr.gif gfx-blkbullet.jpg Condition: New pixel-clr.gif pixel-clr.gif pixel-clr.gif gfx-blkbullet.jpg Display Type: LCD pixel-clr.gif pixel-clr.gif pixel-clr.gif gfx-blkbullet.jpg Display Size: 1.8" pixel-clr.gif pixel-clr.gif pixel-clr.gif gfx-blkbullet.jpg Interface: USB 2.0 pixel-clr.gif pixel-clr.gif pixel-clr.gif gfx-blkbullet.jpg Video Playback: Yes
Dec 26, 2010 | Audio Players & Recorders
My mp3 eclipse is stuck is not working i dont no what to do
My player won't turn off and it keep saying "please wait"
Sep 20, 2010 | Eclipse TCH828 Digital Media Player
How do i delete songs off of the eclipse cld mp3 player?
you hook up your mp3 player up to your computer, go to window media player, go to portable device, and right click whatever song you want to delete( :
Feb 07, 2010 | Eclipse CLD2 MP3 Player
362 people viewed this question
 Grubhead
Grubhead
