Amana ace 156e
I unplug the unit and plug it back in and the com preserve seem to be still running with no lights on the panel
3 Suggested Answers
louislevel_2
  • 374 Answers
SOURCE: ac wont power on amana ace 156e 15000 btu
hi there,
depend on how does this affected by higher voltage induced on your ac,there are overload protection,first check circuit breaker if the lever was on the middle have it cool and then push upward to power on,check the control panel open cover,if you see the relay there is a overload lever reset or push it on,then try to switch on your unit.if run its fine.
but if not call your service center to check this out,several circuit has partially burn out,have the warranty if you could claim
it.have a nice day,rate me if your satisfied to my suggestion,thanks a lot
Posted on Apr 28, 2009
  • 2006 Answers
SOURCE: i cannot locate my operating
The Amana website has manuals to download but when I put in Amana ACE156E they said I had the wrong model number.
Suggest you go onto the Amana website and plug in the model exactly has it says on your unit id plate.
Posted on Jun 03, 2011
I cannot locate my operating manual for my 2 year old ACE 156E 15000BTU A/C from Amana. How can i get another copy of it?
Jun 03, 2011 | Heating & Cooling
Nothing running in refrigerator. Unplugged unit for 2 hours then pllugged back in. unit ran for about 30 seconds then stopped again
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
try this
Mar 10, 2011 | Amana Refrigerators
The oven control panel won't let me push light and work. Even when putting in the times for microwaving, the start button won't work. The panel seems to not be working. Do I need to replace the panel?
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it is just failing to start when you press "Start", it may just be a door switch or mount. See this file.
If several keys are not working, it is almost certainly a bad keypad.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Feel free to contact me directly (and mention your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jun 14, 2010 | Amana ACO1840A Microwave Oven
Amana ARB2257CW...bottom freezer stopped working overnight...ice and ice cream found in liquid form...refrigerator seemed OK... this evening I unplugged unit for 25 minutes and plugged it back in...now fan...
Sounds like a defective thermostat or it could be a defective defrost heater. If freon has not leaked from the frig its gonna be one of the two. BB
Dec 16, 2009 | Refrigerators
On an Amana ARS2661BS Unit does not cool on either side
Pull it away from the wall and remove the cover the covers the compressor. Unplug and tell me if the compressor is too hot to touch or if running or any signs of life. If not running and cool I want plug it back in, and open the fresh food door and and look for a hole in the control panel where you adjust temperatures. The opening is about the size of a pencil eraser. Sometimes this hole is covered by a plastic plug. Stick a small flathead screwdriver slowly clockwise until the compressor restarts. If this works the refrigerator needs a new defrost timer. Sometimes the defrost timer will stick in defrost and stop. Let me know, Thanks Sea Breeze
Jul 21, 2009 | Amana ARS2661BS Side by Side Refrigerator
Amana Quiet Zone air conditioner 12m12ta
Try setting the Unit to run full out, set unit at 66* it maybe the lights flash to let you know the save ( power) is on ?. Otherwise look for the manual and troubleshooter page .
Jul 17, 2009 | Amana Quiet Zone 12M12TA Air Conditioner
Ac wont power on amana ace 156e 15000 btu
hi there,
Apr 28, 2009 | Haier Heating & Cooling
Moved oven. Keypad can not set time. Amana RRL 9TC
After so many years, the electrolytic filter capacitors dry out and these become more susceptible to disruptions and glitches.
If that doesn't work, I would say your control unit (called the "net module") needs to be repaired or replaced.
If this item is available anywhere, it may take several weeks to get and will likely run well over $150.00.
If you decide to look for parts, the proper model number format is RRL-9TC and it also has one of four manufacturer numbers on its tag: P7553302M, P7553303M, P7553304M, or P7553306M.
Be sure to have both numbers handy.
The original part numbers for the net module seem to have been R0163049 and then R163079A.
Good luck.
Feb 02, 2009 | Amana AMV5164 Microwave Oven
Keeps resetting back to dynamic
I understand that you dont want to run your LCD in 'Dynamic' mode all the time! I don't! Its a great way to preserve the life of the backlight... All I can suggest is unplugging the Set from the wall outlet for 10 seconds, then plug it back in-- hopefully this resets the unit -- otherwise this is a defect and hopefully you have a warranty that is still valid!
Good Luck!
Aug 16, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Amana XRSS287BB side by side fridge freezer (3 years old)
you may try hard restart by shuting the fridge off and unplugging it from the wall . plug in back in and after 5 min turn it back on . close both doors and wait one hour . check the temp. if the unit still will not respond calll the local woranty amana repairman only. hope this helps you
Jul 01, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
