Question about Dryers
Inglis dryer error code E5 or t5 - what does it mean
Someone leaned against the dryer door/start button. It started buzzing and then the error code came up
IFIXALL
  • 868 Answers
SOURCE: Dryer will not start when start button is pressed, makes a buzzing noise
Mode land serial number?
Posted on Jun 02, 2008
localwonder
  • 6784 Answers
SOURCE: when you push start button, it makes noise but won't start.
This is a A.C. hum that you are hearing. this is a warning sign. You are experiencing motor failure. the actual windings inside of the motor are losing their potential to hold an even current due to breakage. the shutdown is a safety feature built in the control panel to prevent electrical spark/fire.
Posted on Feb 14, 2009
ButtFuzz
  • 463 Answers
SOURCE: General Electric Heavy Duty Dryer willnot start when start button
WARNING: High Voltage may bzzt you... careful.
Your dryer thinks that it is at the end of a dry cycle.
First thing to do is disconect the dryer from the 220v mains and let it sit for about 10 min.
then, spin the timer four or five times around and then stop it at a TIMED dry cycle, not an automatic cycle. (example: 60 minutes).
Plug unit back into the wall.
SLAM door on unit and press button again...
Posted on Mar 12, 2009
SOURCE: My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Posted on Apr 11, 2009
Greg20
  • 149 Answers
SOURCE: kenmore he2 electric dryer error code f-01
always unplug for 10 minutes and retry first.
Posted on Jun 12, 2009
Press start switch and dryer turns but will not latch on.
try leaning against door when pressing start .if it runs move from the door and see if it quits , if it does the door switch is going bad , or needs adjusted .
Oct 23, 2015 | Dryers
I have a code error on my fisher & paykel front loader washing machine code C on can someone advise how to fix. cheers in advance
try leaning against the door when pressing the start button. door/lid switches have a habit of failing or getting out of adjustment
Sep 06, 2015 | Fisher Washing Machines
Dryer wont start just clicks what can be wrong
may be a bad thermal shut off , any error codes like F1 may also want to check ur push start button or dial with a multimeter, if its bad can get a buzzing and maybe a clicking
Sep 15, 2014 | Dryers
My dryer initially makes a buzzing sound and will not begin the cycle until I give it a few turns manually...
you have a bad motor,if you open the door,hold the door switch in with one hand and spin the drum with the other and have someone else push the start button on and if by helping it to spin it starts usually the motor is bad but i did find on the maytag neptune style dryer that the belt cut into the belt pulley and was holding up the drum and the motor was buzzing like it was bad but like i say usually it's the motor.next time send the brand name and model number and i can help you out better.
Jan 25, 2014 | Whirlpool LER5636P Electric Dryer
Dryer makes a buzzing noise when I turn it on but it doesn't come on, just buzzes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
What is the model number?
Nov 06, 2012 | Dryers
When we press the button to start the dryer, we hear the buzzing but the dryer does not move.
assume the buzzing quit when you release the start button. Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Jan 09, 2011 | Frigidaire Electric Dryer
T5 error code
e5 code have replaced thermister
Jul 24, 2010 | Maytag MDE9700AYW Neptune 174 Electric...
Dryer has a t5 error code and won't start.
There should be two or three screws at the back holding the top on. Take these out and slide the top back and off. Inside should be a service tech sheet that will tell you what the code means and what to replace or check. Once the top is removed it shouldnt be hard to see how it is disassembled.
Jul 08, 2010 | Maytag Neptune MDG9700A Gas Dryer
Dryers Logo
Top Dryers Experts
