Question about Dryers
Inglis dryer error code E5 or t5 - what does it mean
Someone leaned against the door and start button it won't start
Jimster
  • 240 Answers
SOURCE: Parts for old inglis dryer
http://www.myapplianceparts.com/index.asp
These people can find a lot of hard to find parts. I know Inglis is owned by Whirlpool now, but dont know the age of yours, or how long ago this happened. Door switches were pretty much the same, so it shouldnt be to hard to find what you need. Let me know if you need any further help. Jim
Posted on Nov 22, 2007
blueextc3221
  • 15935 Answers
SOURCE: t5 error code comes in my amana dryer ned 7200tw
That is actually a Ts error.
Thermistor Short Sensed
The Thermistor resistance is very low.
Check for:
- Clogged lint screen.
- Restricted vent system.
- Check Thermistor resistance.
Thermistor is Item #27 HERE
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Mar 07, 2010
Testimonial: "very very good"
heatman101
  • 43501 Answers
SOURCE: Inglis dryer does not start. Light comes on
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 03, 2010
  • 53 Answers
SOURCE: dryer has a t5 error code and won't start.
There should be two or three screws at the back holding the top on. Take these out and slide the top back and off. Inside should be a service tech sheet that will tell you what the code means and what to replace or check. Once the top is removed it shouldnt be hard to see how it is disassembled.
Posted on Jul 08, 2010
heatman101
  • 43501 Answers
SOURCE: when we push the button
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on May 20, 2011
Press start switch and dryer turns but will not latch on.
try leaning against door when pressing start .if it runs move from the door and see if it quits , if it does the door switch is going bad , or needs adjusted .
Oct 23, 2015 | Dryers
I have a code error on my fisher & paykel front loader washing machine code C on can someone advise how to fix. cheers in advance
try leaning against the door when pressing the start button. door/lid switches have a habit of failing or getting out of adjustment
Sep 06, 2015 | Fisher Washing Machines
E5 error code on sportcraft tx400 treadmill
E5 erorr code for my gait keeper treadmill ,it starts up after few seconds ,it stops
and error code appear.Can you tell me what this means? How to solve this problems?
Nov 24, 2011 | Exercise & Fitness
When I turn the dryer on and push the start button it won't start but it sounds like it's getting power
heatman101
Aug 30, 2011 | Whirlpool Inglis IP8200 Dryer
Dryer won't start when start button is pushed.
you might want to check the door switch , its possible when the door switch is open the unit will not start
Aug 04, 2011 | Whirlpool Inglis IP8200 Dryer
Fridgidaire dryer aeq6000es. won't start, beeps 3 times with error message dr
Hello
This code means the dryer door is not closed or the door safety switch is not making a good connection at times. The dryer door safety switch is in the opening of the door and when the door is closed the switch button is depressed. If the control circuit board doesn't get a signal that the dryer door switch is closed it will not allow the dryer to start.. Try firmly closing the dryer door a 2nd time when this happens, if that cures the problem you are good to go, if that doesn't cure the issue you must remove the front panel of the dryer and replace the switch. If you need a switch they are available from Sears Direct for about $15.00 Below is a picture of the switch that most likely used in your model and make, the button on top is what the dryer door depresses when closed..
Jul 12, 2011 | Dryers
Truck wont crank. we have put new distributor cap, rotor button, coil pack, plugs, wires, and fuel pump. we also checked our firing order.
you said you repl dist cap that means you don't have a crank sensor you have electronic ing module. remove your elec ing module have it tested most auto parts stores could test your module, or check your coil at the neg terminal. should have power. if not you lost your primary volt from your batt.your secondary power is coming from your electronic ing module from the module to the pos terminal on the coil, when the eng cranks,from the coil to the dist cap , from the dist cap center to the rotor then out to the plugs,this all happen pervided the timing belt or timing chain is ok. the cumbustion chainber needs 3 things , thats fuel, air, and spark.
Apr 17, 2011 | 1996 Chevrolet K1500
T5 error code
e5 code have replaced thermister
Jul 24, 2010 | Maytag MDE9700AYW Neptune 174 Electric...
Dryer has a t5 error code and won't start.
Jul 08, 2010 | Maytag Neptune MDG9700A Gas Dryer
Dryers Logo
225 people viewed this question
Top Dryers Experts
