Question about Garden
Cox Stockman cutter deck adjustment
Cutter deck wont raise when blades disengaged
  • 246 Answers
SOURCE: I need instructions for the assembly of the cutter deck components etc for this machine.
Hello:
A Breakdown should Assist you in Assembling the Deck Components.
The Following Site Addy has a Breakdown of this Unit. Simply use the Site as if you are Looking for a Part for the Mower and then go to the Breakdown for the Deck.
http://www.partstree.com/parts/
Hope this Helps.
Good Luck
Respectfully
John
Posted on May 10, 2009
  • 22 Answers
SOURCE: stalls when engaging cutter blades
The shaft that holds the blade could be rapped with something or needs a new bearing. Check again next to the deck, try a little WD 40 on the bearing.
Posted on Jul 09, 2009
  • 133 Answers
SOURCE: ride on Mountfield Lawn mower 1228H - engine cuts out
Check to make sure there is no obstruction in the blades or on top of the deck where the belt goes. Also check that your pulleys turn freely and that a bearing didn't freeze up.
Let me know if this helps.
roundo4
Posted on Aug 08, 2009
The GR8 1
  • 7 Answers
SOURCE: Craftsman 42 inch deck mower.
That model number des not show up as a good number on the http://www.searspartsdirect.com site. Are you sure you have the belts on correctly? If it has 2 belts on the deck & 1 is not installed correctly they work against each other. Safely make sure that each blade will turn by hand. did you take the blades off? If they are too long by just a fraction, they will hit ach other, but that usually makes quiet a noise. Get your book out & systematically go over everything you touched or changed. It sounds like something really simple you have overlooked. you can go to http://www.searspartsdirect.com & enter a good model number & view all of the parts diagrams. Sometimes they are a big help, & at other times they just confuse you more:). Let me know what you find!!
Posted on Aug 13, 2010
  • 36 Answers
SOURCE: Hi, I have a westwood
Sounds like the cutter is not turning free causing the engine to drag down and stop, I do not think the B&S engine is the problem. I have rebuilt dozens of these engines and most of the problems with a Briggs engine was dirt in the gas or carburetor that needed needle valve cleaned . If the cutters turn free, check for a bad or out of adjustment safety kill switch that engages and stops the engine as the cutters are engaged.
Posted on Sep 06, 2011
Makita 2012 planer, bought in 1990. a 12 inch board comes out thicker on one edge than the other by about 1/32 inch; maybe 1/16" is there a way to fix this? thanks
the cutter roll/blade is not parallel to the cutting deck so one end needs adjustment
it could be from the cutters being blunt at one end and that will produce extra pressure at the other end or is not cutting as efficiently as the other end resulting in the problem
Aug 05, 2017 | Makita Saws
Im having trouble with my Andis Master clippers. I tried doing a cut with a 1 1/2 and they wont cut. If I use just a one or any other size they are fine, only when I raise it to a half they don't cut.
get a small shallow dish and put in a small amount of kerosene
turn the clippers on and place the cutter blades( just the cutter blades ) in the kerosene so that any gunk , hair etc is washed out
change the cutter head to a newly sharpened set
Mar 10, 2017 | Andis Health & Beauty
Have a Cox Stockman ride-on lawnmower that wont cut. Just added 2 new blades (using 4 high lift blades) and still have to go over 100mm grass 3, 4 or more times to cut it down.
check for slipping drive belts
check that the cutter spindle bearings are in good condition as they may be failing and slowing down the cutter blade speed
Dec 16, 2016 | Garden
Machine wont cut
Sounds like the blade didn't go in all the way. Try to reingage it. You should feel/hear a click when it is where it needs to be. Good luck
Jun 28, 2014 | Brother 1034D Mechanical Sewing Machine
I need to adjust my scag mower deck
The mower deck can be adjusted from a height of 1.0 inch to 6.0 inches at 1/4-inch intervals. To adjust the cutting height:
1. Disengage the power to the cutter blades.
2. Push the cutting height adjustment foot pedal all the way forward using your right foot until it locks in place
3. Insert the lanyard pin into the cutting height index at the desired cutting height. Push forward on the deck lift foot lever, hold in place and pull back on the deck release lever. Slowly release the foot pedal. A deck height decal is located on the cutting height index as an aid in adjusting the deck to the desired height.
Aug 18, 2013 | Scag STT61V-27CH Hydrostatic, Gas Turf...
Toro 50" time cutter when engaging blade loud
I would remove the deck and belt, then spin each blade to isolate the loud noise. Also, make sure the blades are not bent hitting the deck. I always balance my blades after sharpening as well. By isolating the bearings spinning them one at a time, this will tell you where your problem lies. Hope this helps!
Aug 10, 2013 | Garden
Ride on Mountfield Lawn mower 1228H - engine cuts out
roundo4
Aug 08, 2009 | Garden
Stalls when engaging cutter blades
Jul 09, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
