Question about Food Mixers
Nutri bullet cup stuck
Cup stuck on base, won't budge
Why won,t it start
Make sure you have power at that outlet. If so, unplug and look for damaged cord. Then open and look for blown fuse.
Jul 22, 2014 | Farberware 12-Cup Food Processor w/ 4-Cup...
My bowl gets stuck. It is extremely difficult to unscrew from the base. It's like it is getting tighter and tighter while it mixes
Well you will be happy to know that it is only a matter of "Wear and Tear" The culprit can be one of two possible things. The screw cup on the mixer or the bowl itself. Understand that...the metal on the bowl or mounting cup are pressed or what you might call metal stamping. When you use the bowl and the mixer over time the metal wears down and or compresses and it takes more pressure from you when you seat the bowl for use and the pressure created by the use of the mixer when the bowl is in place is caused because the locking cup and bowl screw together the same way that the mixer turns and cookie batters or bread dough help to lock the bowl tighter and tighter. Now that you know the reason how do you fix it?? Well the screw cup is the easiest and least expensive. Just order one off the internet and when it arrives unscrew the three retaining screws and put the new one on. If that doesn't fix it then you may have to consider a new bowl. Hope that helps.
Jun 28, 2014 | KitchenAid K45SS Classic Stand Mixer
Motor spins but blade doesn't
If there is a shaft sleeve available from Kitchen Aid you will need to replace that and most likely the chopping blade if there is any damage up inside it.
May 01, 2013 | KitchenAid 3.5-Cup Food Chopper KFC3511
Food processor assembly
I'm going to take a guess that you can't get it to work....tell me if I'm wrong. The biggest mistake people make when assembling their food processors is putting the bowl on backward. It will not run if the bowl is on backward. The handle on the bowl should face the front of the base. Once you click that into place, put the blade on, then lid and lastly the pusher. For safety reasons, all of that has to be in place for it to work.
Jul 18, 2012 | Cuisinart DFP-3 Handy Prep 3-Cup Food...
Black and Decker Spatula Smart Hand Mixer
1990? Dump it and purchase a new one
Mar 17, 2017 | Food Mixers
Lubricant leaking from planetary gear
use a lithium based gear grease
May 24, 2009 | Food Mixers
Hamilton Beach Model 27 (antique milkshake blender)
First off, check the supply cord. They usually dry out and the insulation crumbles, particularly at the point where they enter the body or motor. They short out. I've replaced cords on antique stand mixers I own. It can be a tricky operation.
Is the motor seized? Can you turn it by hand? (NOT plugged in, of course.)
If all else fails, send it to me and I'll fix it for a reasonable fee, if it is fixable at all.
dudeboy
Sep 07, 2008 | Food Mixers
Planetary ring
ok im going to take a shot at this its been a while since ive been in a school kitchen
with the planetary ring its supposed to be tapped in make a jig by getting a 2x6 board and 2 2x4s they dont have to be long screw the boards together with the 2 2x4 standing 4 inch up across from each other about the size of the blender head
the wood is to support mixer while on its head and to keep from teetering around
put down down a piece of foam
put the mixer on its head upside down
now you have to find an old plastic sturdy made cup the size of the ring its gotta be able to take a beating (the cup)
but not a hard beating this will help in seating the panetary ring
now get another piece of foam
glue to top of cup let dry then trim around the cup evenly out side and on the inside leave a little foam over the inside edge
place ring on planetary drive where it goes put cup over ring make sure the cup matches size of ring
now get a wood rubber or small pin hammer and tap lightly on the cup till the ring sits itself back into position this is the safest way to place the ring
use a little appliance greese on inside ring lightly to help ease into place
now if any part of the ring is bent i dont recommend placing of old ring i would suggest buying a new ring for mixer
Jun 11, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
HOW to remove the lower oil seal on the agitator shaft?
Here is the parts catalog. Other than some of the sub-assemblies, your unit is the same.
Page 14-15 item #25 depicts the seal. It just presses in. (From bottom)
http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/57866D624A678E7385256CB0007232DA/$File/F-19357%20(05-95).pdf
If you need more detailed help, let me know. Good luck - Mike
Jun 02, 2008 | Hobart A200 Stand Mixer
Drip cup
Try placing a small piece of wire under the drip cup, where it won't be seen, so that it will take up some space and cause a tight fit.
Feb 10, 2008 | KitchenAid K45SS Classic Stand Mixer
Food Mixers Logo
110 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
