Question about Sea Doo Boating
How Do I Reset the Maintenance Light on My Seadoo RXP
I have a regular maintenance warning on the display, I am want to re-set the warning.
    New Friend:
What is BUDS
Posted on May 28, 2016
Reset timing belt warning light 2012 cruze
Click menu on the turn signal lever to the left of the steering column until the Vehicle information menu appears. Scroll thru the screens by rotating the lever a few times until the replace timing belt item is displayed. Press and hold the set button on the end of the lever. It will ask are you sure you want to reset? Rotate the lever to select yes and hit the select button again to confirm. Make sure you have changed your timing belt before resetting this. Severe engine damage may occur if the timing belt is not changed on a regular schedule.
Feb 20, 2015 | 2012 Chevy Cruze - 1.8L 4-cyl. engine -...
Reset diesel filter sensor
Switch the ignition to OFF.
Disconnect the fuel filter warning lamp switch connector.
CAUTION: Never depress the brake or clutch pedal.
Switch ignition to ON. and wait for 3 seconds.
Next during the 57 seconds re-connect the fuel filter warning lamp switch connector.
After further 3 seconds the fuel filter warning lamp will go OFF, or the message "Fuel filter maintenance required" will be cleared off from the display and the re-set is complete now.
Switch OFF the ignition switch.
Nov 23, 2013 | Toyota Land Cruiser Cars & Trucks
51,000 miles on my Civic - Service Maintenance light displayed this AM - do I need to rush to my garage?
Maintenance light does not man rush to garage.but having it regular maintenance done at regular specified period is always good for long life of your car.
Jan 28, 2011 | 2003 Honda Civic
My daughter has just text to say the isp warning light is on on her 2008 swift sport is there any known wirring / sensor faults that can be easely checked
Usually, Warning displays from the vehicles requiring regular services. A lightening warning display should least have to do with an electrical circuit. The vehicles only displays a warning with a light that is observable by the driver at the dashboard area. Usually, if nothing is broken, the fluids in the vehicle are insufficient. For example, in cold seasons, the AC consumes alot of antifreeze coolants. Alternately, the hot season consumes a lot of engine oils as lubircants. Which ever be the situation, consult with a mechanic to perform regular servicing of fliud changes to restore the vehicles usual functionality.
Jan 13, 2011 | Suzuki Swift Cars & Trucks
There is a maintenance light on with an exclamation point. What does this mean
It reminds you to do your 'regular scheduled maintenance' of your car.
Example: 50,000-miles, 70,000-miles, 100,000-miles, etc. These warnings are already programmed in your car's computers to simply remind you so the car is kept in top shape, and peak performance.
In some cases, if this maintenance warning is ignored, the car may not keep its peak performance or even break down, having to be towed.
The concerned car's authorized dealer usual performs these regularly scheduled maintenance, but competent independent auto repair shops, such as Midas, are able to do these reagular maintenance as well.
Dec 19, 2009 | 2008 Jeep Liberty
'01 Lexus GS 300,My dash tail lights warning just
check you tail bulbs as you have a broken circuit
Jun 10, 2009 | 1992 Lexus Ls 400
I need the maintenance mode of brother fax 2820
Press Menu/Set * 2 8 6 4 You have to ignore the warning beeps and press this sequence within 2 seconds, or you'll just be in the middle of a menu somewhere. If you're successful, the display will read MAINTENANCE. If not, press Stop and try it faster.
They make the Maintenance mode hard to access, because you can really mess things up in there. I hope you have specific instructions for something.
Jun 10, 2009 | Brother IntelliFax-2820 Laser Fax
2001 Mazda pickup, series B: front air bag warning
go to the dealer as there are air bag recalls out
it could be a sensor or wiring problem
Dec 20, 2017 | 2001 Mazda Pickup Regular Cab
Perform maintenance display
We have a different year but most of these warnings are reset the same way the trp odometer is done; press and hold one or the other buttons related to the display until it changes.
Aug 05, 2008 | 2004 Jeep Grand Cherokee
Sceptre TV Displaying out of Range.
I had the problem on my friends tv.
Switch the cable for the component cables to regular TV rather than HDTV, then start the XBOX
Go all the way to the right blade, and go into display settings. For HD resolution, (don't worry if it warns you you're not in HDTV setting) select 720p, then before it switches back to regular TV settings, go to the cable on the XBOX and switch it to HDTV, and select "Yes, I want to keep this setting." It'll start displaying it right. It's sooo much faster and clearer this way.
I found out it was because the component was set to 1080 setting which I suppose is out of the range of the TV.
Feb 27, 2008 | Televison & Video
Boating Logo
975 people viewed this question
Top Sea Doo Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Sea Doo Boating Expert? Answer questions, earn points and help others
