How to disable touchpad on thr aspire e1-522
Trying to turn off touchpad
3 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: How to disable mousepad?
normally the Fn and F7 key, it's the key with a finger on a square icon, or right click on the touchpad icon in taskbar>pointing device properties and select device settings and then dissable.
Posted on Sep 15, 2008
SOURCE: acer aspire one netbook touchpad
If possible try to connect a USB mouse and use that to enable the touchpad...
After that reinstall the drivers for the touchpad the issue should be fixed... Even if you still have the issue then call the computer manufacturer.
If you dont get a USB mouse.. Then turn on the computer get into safe modem by tapping F8... Try to check in safe mode whether the touchpad is working.. If its working reinstall the drivers the issue will be fixed
Posted on Oct 15, 2010
Touch screen not working
The touchpad on the Acer Aspire is built into the notebook itself, which makes the device much harder to troubleshoot or replace. While you can connect a universal serial bus mouse to the notebook if the touchpad becomes unresponsive, attaching any external device reduces the notebook's portability. Although hardware failure can cause the touchpad to stop working, most device-related problems are due to software settings or other conflicts.
Hardware Conflict
Peripheral devices connected to the Aspire can interfere with the integrated touchpad. Disconnect all of the external devices, except for the power adapter, that are connected to the Aspire; then restart the computer. Test the touchpad after booting into Windows. If the touchpad responds, a hardware device is interfering with the pointing device. Reconnect each device one by one to the notebook, testing the touchpad throughout. If the pointing device stops responding after connecting a particular device, the component is interfering with the touchpad. Go to the device manufacturer's website and look up the product model. Check the bulletin board to see if the manufacturer has posted a notice or update addressing issues with device conflicts. If no such update is available, download the latest driver for the component and install it on the computer. b> Disabled Touchpad b> The Acer Aspire 5516 comes with a preset group of keyboard combinations, called hotkeys, that are used to enable or disable devices, configure sound volume and screen brightness, and control the notebook mode. The hotkeys "Fn" and "F7" turn the touchpad on and off. If the integrated mouse is unresponsive, hold down "Fn" and press "F7"; then test the touchpad to see if the device reactivates. If the touchpad still doesn't work, open Device Manager from within the Control Panel. Expand "Mice and Other Pointing Devices," then right-click the touchpad device. If the touchpad is disabled in Device Manager, you'll see the "Enable" option in the context menu. Click it to turn the touchpad back on; then restart the computer. Corrupt Driver b> Windows Vista talks to the touchpad through a program called a device driver. The driver enables Windows Vista to "see" the touchpad and send it instructions. Once the driver communicates these instructions to the touchpad, the touchpad informs the processor that it needs to perform a task, and a specific set of code is performed. If the driver for the touchpad is outdated or corrupt, or if the driver isn't compatible with the OS -- Acer offers touchpad drivers for Windows XP and Windows 7, but these drivers won't work with Windows Vista -- the touchpad becomes unresponsive. Expand the "Mouse and Other Pointing Devices" section from within Device Manager; if Windows detects a problem with the driver, it places a yellow exclamation point or red "X" next to the device. Double-click the touchpad driver to see the error message; then look up the message on the Microsoft Support website for further assistance. b> Touchpad Settings b> Mouse Properties, accessed through the Control Panel, contains several different configuration settings that can alter how the touchpad behaves on the Aspire 5516. On the "Device Settings" tab is the option "Disable Internal Pointing Device When External USB Pointing Device Is Attached." As the option states, if an external mouse is connected to the Aspire 5516, the touchpad will stop working; disable this option if you're using an external pointing device. Clicking the "Settings" button opens the "Properties for Synaptics Touchpad" window. On this screen are the "PalmCheck" and "Touch Sensitivity" options. If PalmCheck is set too high, or Touch Sensitivity too low, the touchpad won't respond to normal touch, making the device seem unresponsive. Hope this helps.
b>
Dec 31, 2012 | Acer Aspire Z3801 All-In-One Desktop Pc...
I turned off my touch pad to my acer aspire 5733z and it wont turn bk on
Locate the "Fn" key in the lower right or left corner of the laptop keyboard.
The "Fn" key typically has different colored text on it or the key itself is a different color.
Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works.
Press the combination at any time to disable the touchpad again.
hope this helps
Sep 16, 2012 | Acer Aspire 5733z-4851
How do i turn on the scrolling on my acer laptop
To fix an unresponsive touchpad on your laptop, reactivate it by using the Function key on the keyboard and the Fn key.
This process is different for each computer manufacturer.
If unsure which Function key enables and disables the touchpad, try each one at a time and then
attempt to use the touchpad after each one.
A...Locate the "Fn" key of the laptop keyboard.
The "Fn" key has different colored text or the key is a different color.
B...Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
C...Press both the "Fn" and touchpad Function key at the same time to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again
May 13, 2012 | Acer Aspire 5100 Notebook
The touchpad is not working
Hi Asmorr,
Chances are, the touchpad was accidentally turned off.
Try pressing Fn, which is at the bottom of the keyboard near Ctrl and Alt, and F7 at the same time. This is the shortcut to enable/disable the touchpad on an Aspire One
Mar 06, 2011 | Acer Aspire One PC Notebook
Hi there my acer Aspire 5732Z touchpad is not functioning properly and when I type text in word the cursor jumps all around
turn off the touch pad by pressing icon_touchpad.pngor press Fn+ F7 then try typing , actuall thing is your hand is touching the touchpad while you are typing
Jul 03, 2010 | Computers & Internet
How do I turn the synaptic touch pad off on my acer aspire
This should be an easy fix...after many months of trying to disable touchpads on machines that did not have the one button disable feature either in the control panel or on the touchpad itself I discovered it was one of the function keys.
Press function (FN) and the "F7" key...press again to re-enable. Good luck!
Dec 21, 2009 | Acer Aspire 5100 Notebook
Disable touchpad
Click start, ccontrol panel, right click mouse, click on properties and disable. If that does not work then try updating that driver. If it still does not work then go to MSCONFIG and disable it on startup and this will disable it permentaly
Feb 22, 2009 | Acer Aspire 4315-2490 Notebook
Switch off touchpad?
right click on the touchpad icon in your task bar and then click pointing device properties, then click device settings and choose disable
Sep 21, 2008 | Acer Aspire 3610 Notebook
Sep 14, 2008 | Acer Aspire 3000 Notebook
Acer aspire 5610 touchpad stopped working
On my acer it is the fn and f7 button pushed together.. that turns the touchpad on and off
Nov 20, 2007 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
172 people viewed this question
David Payne
David Payne
