Question about Dishwashers
Midea wqp12 9240a
Stops at second flashing light and beeps, does not go further
2 Suggested Answers
SOURCE: Midea dishwasher WQP12-924OA wont go
I had the exact same problem with the exact same model. It sounds unlikely, but I couldn't get it to work until I clipped the drain hose into one of the clips 2/3rds of the way up the back.
There was a sticker there that said "the drain hose must be attached to the left or the right clip"
Posted on Jul 30, 2008
Washer stops and fills more than normally during wash and stops after a few seconds and just continuously beeps and it flashs constant where it says wet on the cycle . It is a whirlpool duet 4.0 front...
Christina Johnson, we're sorry to learn of your concern. We'll be glad to further review. Please send us an email with your name, contact number, address, model and serial number at Whirlpool_Reviews@Whirlpool.com.
Oct 14, 2017 | Whirlpool Washing Machines
My Midea Split Air Conditioner displays EC on the indoor unit after working for 10 - 15 minutes. What does that mean and how do I go about it?
Turn off the circuit breaker to the Midea A/C unit. I found mine outside. My unit has It's own breaker. It's in a metal case covering. I opened the door to the metal case and inside was a black box with 2 led lights that were not lighted. I pulled the metal pull on the black box and the black box popped out. On the back were 2 fuses that look like batteries. I replaced the black box and heard a beep from the A/C unit indicating power was back on. I used the remote to turn on unit and now it works like a charm!
May 08, 2016 | Midea Heating & Cooling
Frigidaire electric dryer (FEQ1442CES) keep flashing and beeping even after cleaning lint filter.
Good Afternoon Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, keeps beeping and flashing lights. I also see that you have cleaned all the lint out and your appliance will not run more than about 10 seconds. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance, determine what is causing the lights to flash and the beeping, and repair your dryer. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Frigidaire FEQ1442ES Electric Dryer
The Drying light flashes and the unit beeps about once per second. At the same time the unit acts like it is washing (sounds of water washing insiide. The bottom is oompletely full of water.
so its beeping and flashing once per second correct this beeping and flashing is an error code that your unit is giving blinking lights or beeping sounds may indicate a problem with the dishwasher caused by power surges. To correct the problem, try pressing the "Start/Reset" pad to reset the dishwasher. If the problem persists, reset (reboot) the control by turning off the circuit breaker supplying the dishwasher for 30 seconds. Turn the circuit breaker back on and the dishwasher should function normally if you still have the flashing and beeping message me back Im going through the error code book as I type this if it still persists after you turned off the power then back on message me back with the number of beeps within 60 seconds as well as the number of flashing lights for instance if it does it every second or once every 5 seconds also if you have any further questions message me back them as well and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to help others in similar situaitons Thanks Rick
Feb 04, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
It washes then it stops, then it read err
The control board has detected an error. Press any button to wake the machine then wait for 5 seconds. Press and hold the START/PAUSE and CANCEL buttons simultaneously then the failure code will appear in the display as an "E" followed by two numbers, a number and a letter or two letters as long as the buttons are held. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. Post back the code for further assistance.
Dec 29, 2010 | Frigidaire ATF6000ES Front Load Washer
The cooling unit outside is not working. Its a Midea split system and the indoor fan unit works for a bit until all the lights flash together and it stops responding. The external unit (that does the...
your compressor may have seized up or burned up or blew a fuse. you may want to call an ac tech cause you cant really do much yourself with it. if the compressor is seized you may be able to unstick it by taking the back off the ac unit and hitting the compressor which is the black thing. dont hit it to hard just give it a few firm hits all around with something like a rubber hammer or something else like it. if this doesnt work it may have burned up or you may have blown a fuse. the lights flash probley because the unit is trying to tell you something is wrong with it and the way it flashes may be a error code for a tech. hope this helps.
Jul 07, 2009 | Midea MWB-05CM1 Air Conditioner
Fails to start Midea dishwasher WQP12-9240AS
Thankyou Loopyloolisa! you just helped me fix my unresponsive midea dishwasher! Great help
Jan 17, 2009 | Hotpoint 24 in. HDA3400G Built-in...
The flashing light on phone
Press down the "find handset" button until the paging beep stops (about 5 seconds) and this will reset the indicator lights on the handsets.
Dec 11, 2008 | Uniden 5.8GHz Cordless Phone
Frigidaire Tumble Action Washer - lights flash, beeps, does nothing else...
If you have had a lightning storm or power surge it may have fried the electronics panel. That is what happened to mine. Once it is fixed you should put a surge suppressor on it that is rated for major appliances.
Oct 17, 2007 | Frigidaire 14 Cycle Tumble Action Washer
Dishwashers Logo
15 people viewed this question
Top Dishwashers Experts
