Kenmore washing machine top loader 2600-010
Lid lite keeps blinking i try to run it and it hums and stops then lid lite starts blinking again if the drain hose is plugged would that cause it
gittos73
  • 244 Answers
SOURCE: Washing machine does not drain
does the water pour out when you put the drain hose close to the ground if it does then make sure your pump isnt blocked if it isnt then youll need to replace the pump most pumps have 3 little fins in them if you can stop those fins with a screw driver when pump is going then it deffinatley needs replacing as you cannot fix them sorry for the bad news m8
Posted on Sep 12, 2007
onthejob5130
  • 640 Answers
SOURCE: maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Posted on Jan 03, 2009
jsrock516
  • 5911 Answers
SOURCE: My Kenmore Washing Machine wont drain or spin. Only a slight hum.
This problem is commonly attributed to a lid switch malfunction. If the model number you have this listed under is correct, the lid switch is mounted under the washer top casing, on the right hand side. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. The humming sound you hear when the lid is closed may just be the timer motor running. If your washer is not configured in this manner, please post back with your COMPLETE model number (located along the tub rim under the lid) so I can confirm how your washer IS configured. I hope this helps you.
If you determine that your lid switch is broken, please let me know and I will provide you with the steps necessary to repair it yourself (simple repair job). I can also give advice on where to purchase a replacement.
NOTE: Placing heavy objects on the washer lid can cause the lid to bow and also affect the way it contacts the lid switch.
Posted on Jan 27, 2009
Dissolu
  • 221 Answers
SOURCE: I have an LG Fuzzy Logic top loader. it keeps draining water out
If it's really as you described, when draining at the same time filling up, then it's a problem in the main control board. You'll need some electronics knowledge to repair it, or just replace the main board
Posted on Aug 07, 2009
  • 193 Answers
SOURCE: Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Posted on Nov 04, 2009
110 kenmore loader top 23812100
If it is not the lid switch then it is the motor switch. Here is that part to order.
Oct 10, 2013 | Kenmore 22422 Top Load Washer
Kenmore washing machine catalyst stops during rinse cycle
The hum you here is the probably the motor trying to turn, but it is about burned out. If it moves a little with a full load and more with no load, it is probably bad. If you hear a hum and the drum never moves at all you probably have a broken belt.
May 19, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
I have a whirlpool washing machine, M 31062, WTW4950XW0. I am attempting to use it for the first time and the Sensing Light is coming on when I press START. The Lid locks and there is a noise like the...
I have a Whirlpool model WTW4950XW0. Once i push the start button.
The lid locks, sensing lite on, machine goes through its cycle, than lid unlocks
monents later.What wrong. I was doing laundry and notice the machine making some noise on the spin cycle. I push the pause button and remove some clothes.
thats when the sensing lite keeps blinking.
thanks
Rich
Jan 01, 2011 | Whirlpool Washing Machines
Kenmore washing machine 110.22082 does not drain
you probably looking for a new drain pump ( control board also possible)
Sep 05, 2009 | Washing Machines
10 year old top loader, stops midway thru cycle
turns out it was the opening and closing the lid while trying to get it to run again. I placed a screwdriver in the hole on the lid sensor deal and it kept running so I order a new stinger or what ever you call the deal on the lid that goes in to the hole. I was going to order a timer until I read your emails on your web site..saved me a lot of money. THANKS
Sep 05, 2009 | Kenmore Washing Machines
Kenmore Elite (Calypso) Top loader Will start and fill up w/ water, and wash for a while. During the washing process it makes a humming noise and then the display gives a "ob" reading. I have replaced the...
The OB indicates and out of balance condition has been detected by the motor control.
One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 18, 2009 | Kenmore 23822 Top Load Washer
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Cycle stops...
replace the lid switch, or check the connections it might even be your pusing rod for activating the switch
Jun 17, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
