Question about Garden
Troy Bilt TB-25-CS Won't Start
Troy Bilt TB-25-CS Won't start. I took out the spark plug and it has plenty of gas in fact it seems flooded. I put in a new spark plug but can't seem to get it to fire.
  • 10865 Answers
SOURCE: Troy-Bilt Chipper Shredder won't start
It takes good gas, good spark, and good air for a gasoline engine to run well. The next thing I would do is put a new air filter in it.
Posted on Apr 23, 2009
  • 4 Answers
SOURCE: Troy Bilt Rotor tiller, won't start
lac spark plug on motor pull cord if no spark take the pull start cover off and sand rust off fly wheel
Posted on May 05, 2009
#1 Taper
  • 1040 Answers
SOURCE: Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
Posted on May 26, 2009
dontbother10
  • 2220 Answers
SOURCE: 353 husqvarna chainsaw, floods during start process
Husqvarna says the initial carburetor needle valve settings are from lightly seated 1 turn CCW for both H & L.
Your Operator's Manual can be downloaded here:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2004/HOUS2004_1140204-95.pdf
Once flooded Huskys are very hard to start. This works well on my 359.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close - sets fast idle) pull starter and listen for an attempt to start. once heard (usually two pulls)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually the next pull)
Warm:
  3. Pull (close - sets fast idle) choke, - Don’t pull with choke closed.
  4. Push (open - fast idle maintained) choke, pull starter until it starts. (usually first pull)
Hope this helps
Lou
Posted on Oct 03, 2009
witserv
  • 144 Answers
SOURCE: troy bilt 5550 generator no start please help
fuel, fire, mechanical. Miss one and she won;t run. Are you sure the gas was good? Not some old can laying around that may have turned or become water contaminated? If it was fresh gas, then take off the air cleaner and spray a little wd-40, or ether, or brake cleaner whatever is flammable into the carb throat. Just a 1 second shot is all it should need. Try and start with that. If it starts and then dies quickly, still a fuel problem. maybe a gasket is damaged, or the jet is clogged. When you said you checked for fire, you acutally took the plug out and had it grounded while spinning the motor and saw spark? If you saw a hot spark then you have eliminated fire. Mechanical not likely if it was running well a short time before. If a valve was damaged, it would still run but not too well. My gut feeling is it is related to fuel.
Posted on May 26, 2010
Testimonial: "thanks for the great help i did try fresh fuel and drained the carb bowl but still same prob its a head scratcher i really thank you for your input."
String trimer
Sounds like air in the system, take spark plug out, pump bulb 3 or 4 times, replace spark plug and try to start. Repeat.
Apr 17, 2014 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Whats the gap on the spark plug on troy bilt tb20cs
Hello, Johnny -
The correct gap is .020" (0.5mm).
Link to specification page in owner's manual attached.
Troy Bilt TB20CS Operator Manual Specifications
Mar 06, 2012 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Troy built tiler won't start!!
What is the method your machine uses to decide when to fire the spark plug? Does it have a magneto, and/or ignition points under the flywheel, or a crankshaft postion sensor?
Apr 18, 2017 | Computers & Internet
Will not start...cleaned carb...new spark plug...seems to have plenty of compression but how do I check that from home?
Some people use an actual compression testing tool that measures psi and some people just put their thumb over the spark plug hole and pull the rope quickly and see if it pushes their thumb off the hole.
Feb 02, 2011 | Troy-Bilt 31cc 2-Cycle Gas Powered...
Jim
May 24, 2009 | Troy Bilt Tb70ss Gas Trimmer
May 05, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Apr 23, 2009 | Troy-BiltĀ® Briggs and Stratton Chipper
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
