Question about JVC KW-AVX730 Car Video Player
Wire diagram so I can be able to get video for dvds to work
How do i watch dvds and drive with a pioneer z2 double din
to watch dvds without you having to be in park you have to rewire the wiring to the deck. not the speakerwires or anything like that there should be a pink or orange color wire that comes from the harnest of the back of the deck anyway that wire is the only single wire in its own color besides (red yellow black) these are the wires that give power to your deck. all u have to do is take that one wire left over i think its orange in color and ground it (connect it with the black wiring. that should bypass the brakes from the deck n ypou can watch dvds as you drive but dont forget to also watch the road. :)
Jul 26, 2011 | Pioneer AVIC-Z2 Car DVD Player
Uv8
It is set up so that you can't you have to do some things with the wiring I believe to get around it. It is technically illegal to do that. If you have any other questions or need further assistance let me know.
Thanks,
Lee
Sep 06, 2008 | Jensen VM9510 Car DVD Player
I can not play dvds in my jensen uv8 not even brand new un-opened dvds, how can i fix this ?
if it has a brake wire in the back of it ground that wire to the radio ground or any where that is a ground
Dec 02, 2010 | Jensen VM9510 Car DVD Player
Hi ive got an eonon e1012 double din dvd player unit for my car (vw golf mk4) I can watch dvds but there is no sound atall when i put a dvd in or a cd, It did have sound when i 1st had it wen i put in a cd...
hi, i bought eonon E1012 on Eonon official, i also changed the wire so as to watch car DVD, but everything turn out to be fine.
I think maybe you have connect the wrong wire and have bum out the built in amp.
Nov 08, 2009 | XO Vision XO9013 Car DVD Player
How to by pass to watch dvds
You need to have your parking brake engaged to watch dvds.
Mar 19, 2009 | Clarion VRX585USB Car DVD Player
Parking brake on a phase linear uv8
pulll the unit out there will be a wire marked park brake or most likly pink (remeber coming from the head unit ) next splice it in to the black wire or to a ground
Jan 30, 2009 | Jensen VM9411 Car Video Player
DP Video car system to play video
look at the install diagram(wiring codes) that came with the unit. if it has a wire that's designated for the parking brake (allowing you to only watch dvds while brake is engage) take that wire and instead of hooking it up to the parking brake, ground it or put an in-line switch between wire and ground so you can turn that function on and off. warning!!! watching while driving is illegal in most states
Dec 30, 2008 | Panasonic CQ-DVR909U Car DVD Player
Legacy LDTSN7 Car Video Player
You should have a wire on the harness labeled Parking Brake (or similar). This wire needs to be connected at the parking brake....or to a toggle switch. It needs to sense a ground after the radio is powered on in order to play DVDs.
Oct 22, 2008 | Legacy LDTSN7 Car Video Player
Parking brake
ground the pink wire that will allow player to play video
Feb 04, 2008 | Car Audio & Video
JVC KW-AVX730 Car Video Player Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
