Model FP-23458 one of my target burners is not working
My unit fell to the floor and the middle burner will not work. It will not retract. Can I order a replacement burner? The model no. is FP-23458.
What 'unit' is this, exactly ? I know of no cameras with 'burners' incorporated in them - have you posted this query in the most appropriate forum ?
Dec 08, 2016 | Cameras
Target disc not empty
Target disc ( this is what you've selected to burn TO) is not empty(is not a blank disc). You should try a different blank disk, or else you have your source and destination backwards.
Nov 16, 2012 | Acard Technology (ARS-2030LD) DVD±RW...
Keep getting "Target Overflow" error message, even
you may have a bad ROM. If you have a multiple target unit, switch the source from the ROM to one of writers and try copying that way, if it copies then it confirms that the ROM is defective.
If you have a Single target unit, check your master disc under disc info, depending on which controller you have it should be under utility or disc info. Once in disc info it should tell you the size of your master disc, for DVD-R it should be under 4488MB, for DVD+R it should be under 4482MB. Then double check the master in the PC just to confirm.
Jun 12, 2011 | EZ Dupe EZDupe Two Target DVD Duplicator...
My burner wont burn it keep saying chec target
You may have to post the make and model of your PC and Burner qnd also OS and type of media.
Feb 18, 2011 | LG Computers & Internet
When I put the disc in to be copies and then the blank discs i press the green start button and it display target drive not ready. How do I get it to copy onto the other discs??
One of the "target" CD-writers is not working -- either the "data" cable is not connected, or the "power" cable is not connected, or the drive itself (either the "spinning" motor, or the "laser") has failed.
Presumably, you don't have to fill "all" the trays, in case you only want to make a few copies of the "source" disk.
So, make a few attempts, with the "source" disk in the "source" drive:
1. put a blank disk into the 1st "target" drive,
leaving the other targets "empty", and press the button.
If it works, then the 1st target drive is OK.
2. put blank disks into the 1st and 2nd "target" drives,
If it works, then the 1st and the 2nd target drives are OK.
3. put blank disks into the 1st and 2nd and 3rd "target" drives,
If it works, then the 1st and the 2nd and 3rd target drives are OK.
... and so on
If you get a "failure", then you now know which of the "target" drives is the "bad" drive. Either replace that bad drive, or change the cabling inside the unit to "bypass" that bad drive, and put a sticky-label on the face-plate of that drive, saying "do not use this tray".
Oct 16, 2010 | MicroBoards Quick Disc QD-123 (QD-123)...
The controller only burns to 4 out of 5 drives and 1 of the 4 working frive keeps making burn errors. Is it time to install new firmware to fix this? or do i have to install new drives? Can i install...
Hi I have this problem with my systor 0-3 target duplicator, the one tray works fine, the middle one keeps making burn errors and the bottom one won't burn at all I can't seem to find a solution
Sep 20, 2010 | Vinpower 16x CD / DVD Duplicator with NEC...
What is Target Overflow
Target overflow mean the file is too big for the target media (here CD/DVD). your ripped file can be just slightly oversized. If you still have problem with this, Let me know.. Good luck
Apr 28, 2010 | MicroBoards (DSRDVDD882) Burner
Target drive is not working
on blank cd's or dvd is nothing to read, With burner software like Nero you can write data or music or other content (burning it) on the cd/dvd. Does this answer your question?
Aug 25, 2009 | Teac (DW-224EA-AM6) CD-RW/DVD-ROM (Combo)...
Trying to burn dvd. It keeps saying Target drive not ready
Hi, assuming the rest of the drives are working there are three probable issues.
1. The cabling for power or data is loose or faulty, check the cabling, remove and reseat it, then try again with new data cable and swap power connectors with one of the other drives. If the results do not vary it's not the cables, If the problem moves with the data cable but is not resolved by replacing the cable it is the logic board at fault.
2. Try cleaning the drive, do not use brush cleaners as they can damage the head, just used a compressed gas can or air compressor on less than 20lbs/in, if this does not work...
3. The second drive may be faulty, check with the manufacturer/manual. Many of these devices require a specific model or one of only a few models for compatibility, replac with an appropriate model.
Hope this helps FixYa,
Chris
Jul 17, 2009 | Telex SpinWise 7-824D (301689000)...
Target Disc not Empty!!!
I have a DVD/CD duplcator, yes I can burn a CD, but when I try to burn a DVD I get this message TARGET DRIVE NOT READY, what can I do?
Nov 26, 2008 | Acard Technology (ARS-2030LD) DVD±RW...
Computers & Internet Logo
338 people viewed this question
David Payne
David Payne
