Question about Garden
Twist n edge te475y
I recently pulled the starter cord out of it's casing. Are there any instructions to re-install it? I've take it apart but am not sure how to wind it correclty
panilling9
  • 284 Answers
SOURCE: starter pull cord
take a light and look into the clutch hole
you will either need a torx or star type nut driver or a allen or hex head nut driver to fit in the hole and turn the screw ccw while holding the flywheel.
Make note where all comes off and all goes back in reverse when fixed.also after you remove the clutch housing you will be stareing at the clutch shoes next and it will have markings on which way to turn it for removal.
Posted on Jun 01, 2009
wadembly
  • 513 Answers
SOURCE: First, Im not sure where my air filter is on my
airfilter is a square filter over the carburator if the cord is out its not the clutch its in the shroud the recoil sping is broken or needes to be redone what you can do is remove the string from inside shroud turn the coil like you pulling the rope when the spring is tight you can use a c-clamp hold it place reinsert rope & release c-clamp it should rewind
Posted on Jun 05, 2009
  • 32 Answers
SOURCE: pull cord won't rewind
the shaft isnt attached right.
Posted on Jun 12, 2009
  • 26 Answers
SOURCE: The Pull cord was jamming. I took it apart and
the rope and spring both have thier respective place in the housing for thier mountings they can be rewound by hand and reassembled with success,hint oppisite end of spring has a anchor point on the housing while one end is secured by a cup like screw mounting,to create the retracting force for retrival of the pull start rope its tricky if haven't done it before but you learn by trying Good luck Steve
Posted on Oct 01, 2009
  • 396 Answers
SOURCE: When I pull the starter cord there is no tension.
Ouch. It sounds like the cord rewind spring has gotten out of position. These things can be holy terrors to get back in the cavity in which they rest.
Check on a new rewind spring assembly. This might be more cost effective than trying to get a service person to put the spring back into place.
Posted on Oct 18, 2009
Starter cord replacement of EF 1000IS Generator
Mentioned here and a general video
Search Results
Recoil Starter Assembly - Yamaha EF1000iS Service Manual [Page 39]
https://www.manualslib.com > ... > Inverter > EF1000iS > Service manual Yamaha EF1000iS Manual Online: Recoil Starter Assembly. ... RECOIL STARTER ASSEMBLY. 1. Install: 1. 2. Install: NOTE: Hook the edge of spiral spring to the ... Inverter Yamaha EF6300iSDE - 5500 Watt Inverter Generator Owner's Manual.
How To Replace Pull Start Cord on Honda eu2000i Generator ...
? 7:07
https://www.youtube.com/watch?v=5WAuEW8decY May 27, 2016 - Uploaded by Tula's Endless Summer
http://tulasendlesssummer.com Here is a short video on how to replace the pull cord on a Honda 2000 watt ...
Yamaha EF1000iS Service Manual Recoil Starter Assembly
May 20, 2018 | Garden
Saw starter pulling too hard to start.
Check piston rings. Sounds like you have a seized engine.
Feb 20, 2013 | Husqvarna Chain Saw Models 51, 55
Why is my Tecumseh 6.5 hp engine hard to start after taking blade off.?
When you tilt the mower too much oil will mix with gas. Try taking out the spark plug and cleaning it good in case some oil got on it. If this don't solve it, drain the gas and refill with fresh gas in case oil mixed with it when you tilted the mower.
Aug 04, 2012 | Tecumseh Lawn Boy Push Mowers Insight...
I NEED INSTRUCTIONS TO TAKE APART FOR CLEANING
I have a similar model to this one. It's a little tricky. Everything snaps or twists together. Press a little on the front and back of the fan grills and twist lefty loosy to open. The blades are an easy detachment, just pull them out easily, and take off the back grill. The back grill may have two screws connecting it to the main case of the fan, but mine didn't.
Aug 17, 2011 | Lasko 2506 16" Table Fan
I need to install a new starter in my mitsubishi galant/2000. we need to save money and do it ourselves and need instructions on how to do so.
Once you have picked up the new starter, You will have it in your hands and be able to recognize the old one on your motor. (I say this "just in case")
1) Disconnect the battery terminals
2) Once you've located the old starter under the vehicle.
3) Unbolt the starter and make a mental note of it's position.
4) Place new starter in same position and bolt it on...
It really is that simple. There are usually only two bolts, I've seen some with three. But really that is all there is to it. Unbolt the old, and bolt in the new
Good Luck to you and Happy Motoring
Respectfully
Jun 10, 2011 | Mitsubishi Galant Cars & Trucks
This still doesn't help. how to you get the rubber off what are flanges. can you show a picture
I've owned this flashlight for years. Ignore the instruction to remove the rubber casing around the lamp area. Simply grasp the whole front of the lamp piece (including the rubber cover), and twist in a counter-clockwise direction to remove. Then squeeze together the two black tabs and pull the battery compartment out to replace the batteries.
Mar 05, 2011 | Energizer Eveready TUF4D1E 4D Cell Lantern
The beater bar doesn't rotate
If you have anyone in your house with long hair you'll probably find that it has hair wound around the shaft that spins. It's possible to take the whole thing apart & strip it down to the bare shaft & you don't need any tools. Turn the head upside down, and slide the flat clip that is at the back of the underside further backwards to unlock the back of the bottom plate. Then turn the two round latches on the back of the cross-arms of the head about 1/4 turn anti-clockwise, this will unlock the front edges. You should now be able to remove the bottom plate of the head. Once you have the head off, remove any hair and dust you can see, and if you hold the two ends of the beater and twist them gently against each other one way or the other, you will hopefully find that the beater comes loose on the shaft and the two black beater sleeves with the brushes on them can be slid outwards & removed. Once you've taken them out, thoroughly clean them (you can wash them in water) and carefully pull out any hair that is wrapped around the shaft, bearing in mind that some could have gone in under the edge of the plastic part that the shafts poke out of. Once you've got everything as clean as you can (I washed all the pieces of the head) and dried it all off you can put it back together again in the opposite order that you pulled it apart.
Dec 30, 2010 | Dyson DC11 All Floors Bagless Canister...
I broke th pull cord on my ryobi ss26 weed wacker.took it apart to restring is there a certain way it must go back together? does the cord through the little hole thats on the spool? if possible can i get...
There should be a hole in the pulley that holds the starter rope in the starter/recoil unit. If you have taken the machine apart to that point, yes, there is only one way to reassemble it.
You will have to wind the starter recoil without the rope installed on itabout 5-6 complete revolutions to "pre-load" tension on the spring-steel starter spring, then lock the pulley in place, insert the pull rope and tie it off so it can come back out and then release the pulley, letting it draw in the new starter cord. Make sure you have the handle installed so it will stop when it gets to the body of the engine cover.
Sep 22, 2010 | Ryobi 15" Electric Factory Reconditioned...
I need a manual for weed eater max te475y twist n edge
http://lawnandgarden.manualsonline.com/manuals/mfg/poulan/te475y.html
I ran across your question when I to was looking for the manual. This is what I found it seems like the right one I will find out when I start working on the thing good luck!
Danielle
Jun 15, 2010 | Garden
Syncmaster 932B need instructions to open the display to check the backlight.
Lay the monitor face down on a padded horizontal surface. I use a thick towel on a table, Remove the pedestal by unscrewing the wing-screw on the bottom. This will allow better access to the slots in the case halves on the bottom of the monitor. Use a screwdriver about the size of the slot, insert and twist. The case should separate with a loud snap. Do this for both slots. Then, using two screwdrivers, one to twist and unsnap and one to hold the gap open, work you way around the edge until you are able to pull the two halves of the case apart. You may want to pad the twisting screwdriver with some tape around the blade. The corners are good places to work since the case is stronger there. Note that the circuit board chassis is not attached to the LCD panel, but is held in place by tabs on the inside of the rear case half. Keep this in mind when you reinstall the case back.
Feb 08, 2010 | Samsung SyncMaster 932B LCD Monitor
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
