Question about Kitchen Appliances - Others
Breville Emporia Pasta Maker
I need to get a replacement die locking ring for a Breville Emporia Pasta Maker. Where do I get one and how much would it cost to replace? Wondering if its worth fixing?
4 Suggested Answers
  • 14 Answers
SOURCE: Ronco Popeil Pasta Maker Problems
After using the Ronco Pasta maker for a few times I discovered a couple of problems, the main problems are that it's a bit slow, took as much time as it does for handmade pasta.
The second problems was that cleaning the dies was a pain!
Posted on Jul 16, 2009
SOURCE: i have a pasta del-giorno, pasta maker by
http://lib.store.yahoo.net/lib/partshelf/Maverick-MPM6468-Manual.pdf
Posted on Dec 27, 2009
  • 7 Answers
SOURCE: need replacement table clamp for pasta maker
Have you tried going to the manufacturer's website? I have this pasta maker on my website and you might try one of the links. But you will probably have to get a new machine. You could also go to your hardware store. They might have a clamp that you could use. Good luck.
Posted on Feb 22, 2011
X1000 takka
There are many on eBay. You can pick and choose which one's you want and do not have to buy the one's you will not use. You can also buy any other pieces that you need, break or were missing. Most people do not even know that the machine has sausage and cannoli fillers!
Oct 17, 2013 | Ronco Automatic Popeil Pasta Maker
I need a phone number or web address to order replacement dies for the primo pasta PS101 that I bought second hand and has only 1 die
I have an easier way since they are no longer in business. Measure your diameter of the die. Compare the size online to Popeil or Takka. Then go on eBay and buy any dies for lots of pasta types. There are 2 sizes of dies other than Kitchenaid who has very small dies and the Cuisinart who has very thick. Give it a try and you can return them if they do not fit. Well worth the effort to have what you want.
Mar 30, 2013 | Waring Primo Pasta - Pasta & Dough Maker
I am not getting an answer to my question re: Ronco Pasta Maker Model P400.
You have a short in the motor. You can take it to a appliance repair place or buy just the machine to replace yours unless it is under warranty. You can find the machine on eBay under Popeil or Ronco and they both will use the same dies and parts.
Jan 08, 2012 | Ronco Automatic Popeil Pasta Maker
Need replacement table clamp for pasta maker
Feb 21, 2011 | Atlas Translator Atlas 150 Deluxe Pasta...
I need to know which die is which. I have the manual. But, I'm not sure what each of the die are for.
Most of the models have the die type written along the outer edge. If not, you can look on eBay for people who are selling pasta dies, and compare yours to the ones shown. You can sometimes find pasta maker replacement parts here: http://stores.ebay.com/Lauras-Last-Ditch/Bread-Pasta-Machines-/_i.html?_nkw=pasta&submit=Search&_fsub=360500719&_sid=93311479
Aug 22, 2010 | Ronco Automatic Popeil Pasta Maker
Jul 16, 2009 | Ronco Automatic Popeil Pasta Maker
How to clean the Ronco Popeil Pasta Maker?
The Ronco Pasta maker is a bit of a pain to clean. I normally take the whole thing apart and put it in the dishwasher and that does a good job with most of it. Occasionally I will need to run it in the dishwasher twice. The middle piece has to be cleaned by hand. You can finish it off in the dishwasher after you clean out the junk in the middle part.
The dies are the real problem when it comes to cleaning this unit. You need to get a small wire to flush out the holes otherwise the dough dries inside the dies and they are very difficult to clean out. Just running it through the dishwasher will not work. I either use the wire or I boil the die for 20-30 minutes then put it in the dishwasher.
Breville Die Cast 800ESXL
BrevilleUSA.com has a silicon seal (steam ring) to replace faulty or worn ones. There is no shipping charge, and they are $4 each. To replace the steam ring you'll need to remove the stainless spray disk on the brew head with a phillips screwdriver (one screw) and pull off the old ring (pay attention to the direction and placement of the stainless disk).  Takes about 2 minutes to do.
Part # .800ESXL/192
Also, on mine I noticed that the filter holder was ground down at the factory a bit too much on one side, which causes a slight leak down one side (coffee, not water).  You might check the holder (with the filter removed) for imperfections that could lead to your leak. Good luck.
Feb 17, 2008 | Breville Die Cast 800ESXL Espresso Machine
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
