Question about Maytag Dryers
Maytag LDG5005AAE Gas Dryer won't heat
The flame on my gas dryer will stay lit for about 15 seconds and then shut off. I've replaced both gas solenoid valves and no change. I've checked the following items for continuity: flame sensor, thermal sensor, high limit switch and cycling thermostat and everything checks out fine. I've cleaned out the vent and there are no obstructions in the vent line. I'm at a loss on what to try next.
  • 61 Answers
SOURCE: Kenmore Dryer only lights gas sporaticly
replace the igniter. The ignitor is the most comon problem with gas appliances checking continuity does not tell you if it is bad or not it has to draw a certain amount of amps to open the gas safty valve and the is no safe way to check this on most gas dryers
Posted on Jan 19, 2009
TheMobilian
  • 8220 Answers
SOURCE: Inglis gas dryer heat loss
Replace these solenoids on the gas valve. Feel them if you can. They get hot and quit.d910ca8.jpg
Posted on Feb 04, 2009
Maytag317
  • 1136 Answers
SOURCE: mdg2300bww dryer, flame is large hitting high
Hi, A couple of things to look for. Check the 4" vent going to the outside and make sure there is clean. If that is ok, check to see if the blower duct inside the dryer is clean and make sure the blower wheel is turning properly. This model has a problem with the blower wheel coming loose on te motor shaft.
The flame is large because it is not being sucked past the limit switch.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 17, 2009
delpolito54
  • 44 Answers
SOURCE: check continuity on a flame sensor
flame sensor is closed when dark, open with the ignitor light. Thermostat is closed when cold, open when reach temperture. Ignitor is a closed circut but high resistant value, put your meter on 10k. Also to the gas valve 110volts be carefull.
Posted on Sep 01, 2009
  • 1891 Answers
SOURCE: Maytag gas dryer ldg7314aae my flame will not stay
you have done a lot . try running the dryer off the vent . when the burner is short cycling it a air flow problem . if off the vent does not solve problem ck the fan for a bad center . very common problem . and clean vent . ck outside for air flow and condition of vent hood .. hop this helps ..
Posted on Dec 03, 2009
What do I do when error code reads E 15 . Dryer runs for a few seconds than shuts down. I've tested micro switch and i'ts fine.
Post some pictures of your pilot assembly. I think this might be one of them spark sensor deals where the pilot lights and then detects flame then relays that back to the control for igniton verification. OR just try and clean up the electrode with steel wool and see if the flames stays lit is what I would try.
Jan 07, 2013 | Wascomat Parts Wascomat 231754 Dryer...
Ignition works but doesn't stay on long enough to heat dryer
its either the hi-limit switch is weak on the burner tube,or the gas valve coils on the gas valve are weak and can no longer keep the gas valve open to supply gas,if they appear warm after operation they are most likely bad
May 24, 2012 | Maytag Dryers
The igniter heats and the flame lights, but it shuts off after just a minute or two. It won't go back on until the dryer has cooled down completely. Could it be the high-limit thermostat? With the...
What your describing sounds pretty much like the sympthons of weak coils that open the gas valve. It is a fairly common thing that happens with gas dryers so i have written a tip that explains in detail what happens when gas valve coils are weak.
http://www1.fixya.com/support/r10174506-gas_dryer_starts_off_hot_but_after_while
I hope i have helped you to fix your dryer,
GENE
Oct 09, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Flame won't stay lit more than 15 seconds
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 07, 2011 | Dryers
Maytag LDG7400 gas dryer does not stay lit long enough to heat the drum. Can see flame turn on for about 10 seconds then back off for 20 to 30 seconds. Continues cycle of on and off until end of time....
Light sensors detect when burners are lit. If they become blocked with lint, dust, etc., they will not detect the flame and, for safety purposes, automatically shut off the gas flow.
Dust and lint are a dryer's worst enemy. Be sure that all sensing devices (particularly optical sensors) are clear of dust and lint so that light can pass unobstructed into the lens.
If they sensors are all clean, they might be defective. Something is erroneously telling your dryer's control that the burners are not lit and thus the gas supply is shut down.
Jan 01, 2010 | Maytag Dryers
Maytag gas dryer ldg7314aae my flame will not stay lit. Heats up flame kicks on then goes for about 20 seconds then shuts off. The dryer runs for about 20 more seconds and then the same thing happens...
Dec 03, 2009 | Dryers
Have a Maytag gas dryer, model#:LDG7314AAE, flame wont stay lit.
Clean/repair your dryer vent. The flame when it exits the funnel should not touch or just barely touch the funnel end. This indicates good airflow. A good test for the clogged/damaged vent is to disconnect the vent hose from the dryer and run it as is. If the flame stays - clean vent. If not - clean air path inside the dryer
Nov 17, 2009 | Refrigerators
Gas dryer not heating properly
This sounds like the flame sensor is bad to me.
If it does not work properly, the unit will shut off for safety. The machine assumes that the burner did not light and rather than run gas into your house, it shuts off. It may try to start a certain number of times and then shut off.
You may be able to remove and clean it (flame sensor) lightly with a scotch brite pad and it may work properly again.
Otherwise it will need replacement.
This is a very common problem and the part is probably in stock.
Post a comment on your progress as this solution is likely to be useful to many people.
Thanks,
Tim
The problem is not the gas valve.
May 06, 2009 | Whirlpool LGR5636L Gas Dryer
Maytag LDG5914AAE Gas Dryer gas shuts off after 15 seconds or so
The coils can be replaced, also I would check your dryer vent and make sure that the vent is clear and ffree from any blockage
Apr 13, 2009 | Dryers
Maytag gas dryer - model unknown - gas wont stay lit
Yes does sound like blockage in the exhaust vent causing the high limit switch to stop the dryer.
Mar 26, 2009 | LG DLG5932W Gas Dryer
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
