Question about Hardware & Accessories
How to wire Lamona hob
Have a lamona 1211 hob and there are no instructions in the manual to assist with wiring. There are 5 terminals in the connection box. These are numbered 1-5, with 5 also marked as earth. 2 and 3 are linked together, but that is all the help there is!! any ideas???
  • 1462 Answers
SOURCE: Hi I have fitted an
yes you must link all live terminals. links usually come with the installation kit but you can make them from suitable size wire
Posted on Jul 09, 2008
jeltey
  • 44 Answers
SOURCE: wiring connections for Kichler 900w transformer
You need to connect one wire from each cable to one of the com terminals. The other wire from each cable has to connect to a tap terminal. The tap terminal you use will depend how many lights and the length of the cable. For short cable runs like 25' use tap 1 50' tap 2 100' tap 3 more than 100' tap 4. you may need to connect all three cables to the same tap terminal. If you turn it on and one string of lights is dimmer than the others move the tap connection from that wire to a higher number. The tap terminals send out a little higher voltage the higher the tap number. The obect is to get the same light output of each light compensating for the voltage drop of the cable. This is a lot of info so I hope this answers your question. If you need more help let me know.
Posted on Dec 04, 2008
SparkyNZ
  • 43 Answers
SOURCE: wiring problem
If they only way to fit your cable is by using the terminal push on connector (which, frankly, i'm not 100% sure what that's describing) and you can easily get that from your hardware store then yes, as long as you can connect up your wires without difficult and without stray copper.
Red wire is live, but white may be live as well during one aspect of operation. Usually neutral is black or blue. If your cable has red white and blue color in it then your using a 3 phase cable. A single phase 3 core cable will have red/brown black/blue green/greenyellow.
Hope this helps. Let me know.
John
Posted on May 09, 2009
SOURCE: Wiring for Neff Hob-not supplied/no wiring instructions
The details of how to wire the T1213 hob are printed on the base of the hob next to the terminal compartment. For a single cable installation, Neutral is connected to terminals 4 & 5 which should already be linked with a copper link. Terminals 1,2 & 3 should be linked together using the links supplied (hidden in the side of the terminal compartment) and Live is connected to any one of 1,2 or 3. The Earth goes to the terminal beside the cable clamp.
Posted on Jun 13, 2009
john224
  • 1378 Answers
SOURCE: Bought an Intermatic T104 Timer for a 120v pool
T104 series intermatic timers are 208/230/277 volt clocks, not 120. I believe you have the wrong model and need a T101 series instead.
Have a neff t1213xo, what does black grey and brown wires stand for?
You have an hob with European three phase at 220volt mains wire connected.
You need to to disconnect from mains connection box on hob and fit conventional British brown, blue and green/yellow.
Inside the connection box you will see three live terminals,(L1,L2 & L3) there are usually some brass links to join them all up and then attach brown core to one of them. If the links are not there then you will need to fit 2.5mm links from a piece of wire.
Nov 24, 2014 | Neff Ovens
Lamona ceramic hob
Ceramic cooktops need the correct type of pots or they leave marks,check your instruction manual.
Mar 11, 2014 | GE Cooktops
How to wire hunter rain clik rain sensor to r8816p101c
1) There are different rain clik model numbers shown in manual
Open 24 volt Rain clik manual:
http://www.hunterindustries.com/resources/pdfs/instructions/domestic/lit358w.pdf
http://waterheatertimer.org/pdf/Hunter-rain-clik-instruction-manual.pdf
2) The rain sensor has two wires.
And two additional wires are needed to run from rain sensor to sprinkler timer. For example, buy thermostat wire from local hardware store if wire is not supplied.
3) The rain sensor has a terminal block where wires are connected. .
Open manual above to identify markings on your terminal block.
For example Figure 1 shows SRC model, and with this model number, the rain sensor wires connect to terminals RS and C, and then two wires going to timer connect to terminals RS and and 1.
4) R8816P101C is 208-240Volt 24-hour irrigation timer.
Timer has two separate terminals for attaching rain sensor.
5) Timer power connections have 4 terminals. Do not connect rain sensor to power terminals.
Connect wires from sensor to the two sensor terminals.
6) Timer slide-switch must be set to ON position for rain sensor operation.
Sensor sends continuous 24Volts to irrigation timer.
When it rains, the rain sensor stops sending 24Volts to timer. Timer responds by not turning on power to irrigation pump.
To by-pass rain sensor, move timer slide-switch to off position.
7) Open following link for Intermatic replacement parts:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
8) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 05, 2011 | Intermatic R8816P101C -...
What configuration do the output power wires look like. Do I connect to 3 and 4 , slots etc. What is meant by "load" in the instructions?
1) You posted under ET104C DPST (double pole single throw) 24-hour 4-ON and 4-OFF per-day selectable-voltage timer
DPST means that timer will turn off two wires going to 240Volt Load or two separate 120V Loads
Open following link for example Intermatic ET series wiring diagrams and manual:
http://waterheatertimer.org/How-to-wire-Intermatic-ET-series-timer.html
2) Load means whatever electrical device is controlled by timer. ie fan, light, motor, pump, alarm-bell, water-heater, bowling-ball-machine etc.
Line means cable coming from breaker box.
3) If you have a different timer, then add a comment with photo of inside of timer door for possible identification and complete answer.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
4) Selectable voltage means you have to choose voltage.
Timer come preset for 240Volts.
If you have 120V 208V or 277V, then follow the vague instructions shown on page 2 #2 of manual.
5) Do not apply voltage to this timer before matching selectable voltage setting with circuit breaker voltage.
6) ET104C has 6 terminals and can be wired many different ways depending on Load voltage, etc.
This timer can do a lot of different things.
If you have ET102C with 4 terminals, then add a comment and clearly explain voltage, color of wires, and what breaker you have and what Load you are controlling for best answer.
7) ASSume you have 240Volt cable coming from breaker box, and that you are controlling a single 240Volt Load like a water heater or pool pump.
240Volt cable from breaker will have 2 hot wires called Line 1 and Line 2
Line 1 black wire will attach to both terminal 1 and terminal 3 (use a jumper wire between terminal 1 and 3)
Line 2 red or white wire will attach to both terminal 2 and terminal 5 (use a jumper wire between terminal 2 and 5)
Your 240Volt Load will also have 2 wires.
Load 1 black wire will attach to terminal 4
Load 2 red or white wire will attach to terminal 6
Add a comment for more free help
Also take advantage of fixya expert assistance live.
Apr 23, 2011 | Intermatic INC ET104C 24 HOUR ELECTRONIC...
I am replacting my T103 timer with a GE 15600. The posts on the T103 are marked 1 2 3 4. However on the 15600 they are marked L 1 X 2. How do these map to each other?
1) If you are replacing T103, the T103 can be wired many different ways. Not all wiring diagrams are supported by GE 15600 replacement timer that fits into Intermatic box.
2) Double check your T103 terminals
T103 terminals should be A 1 2 3 4
If terminals 3 and 4 have wires, then GE is not correct replacement.
You can buy repair parts for Intermatic timer
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
3) GE has terminals 1 and L which are connected by brass bridge. If brass bridge is removed, add a jumper wire and connect terminals 1 and L
GE has terminals 1-L X 2
4) Typical GE 15600 wiring shows on following link, in addition to links for parts and manual:
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
White wires on terminal A connect to terminal X
Black wire on terminal 1 connects to terminal 1
Black wire on terminal 2 connects to terminal 2
5) Add a comment for more free help.
Mar 06, 2011 | Garden
Lost wiring instructions for my woods water heater timer. What wires attach to bus bar
Timer model is usually located inside the door panel:
1) Open following link to access manual with wiring diagrams.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Boxtype
2) Example manual shows different wiring diagrams:
http://waterheatertimer.org/pdf/Woods-59396-59399-manual.pdf
If you have timer with 8 terminals, and ordinary 240V water heater, then use diagram on bottom right.
3) Woods timers are wired identically to GE 15207, except your model might not have dip switches.
http://waterheatertimer.org/How-to-wire-GE-15207-timer.html
4) Busbar usually refers to a long metal bar where many wires connect to same pole. For example neutral busbar inside breaker box has 20 or 30 wires connected to it, and all are connected to Neutral wire from power pole.
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/B220C.html
Mar 05, 2011 | Kitchen Ranges
Nov 28, 2008 | Neff T1323 Electric Cooktop
Conecting a lead to an electric hob
the usual method is to link the 3 live terminals together and the 2 neutrals. the links normally come with the hob and are often already in position. make sure the links are present and tightened down. it then doesnt matter which of the three you connect live to and same for neutral
you should connect the double oven on a separate circuit with its own isolator
Jun 23, 2008 | Cooktops
Hardware & Accessories Logo
235 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
