Panasonic tc-p42x1x no power 1 blink - Televison & Video
Slinteriors
  • 8617 Answers
SOURCE: Panasonic TC-32lx60
I work for another site that sells service manuals and provides free tech support, and there is nothing in the manual about error codes. The power supplies would need to be troubleshooted. The manual is anew one but if you would like a copy send them an email and they will upload it to the website for you to purchase, they email all manuals that one was scheduled to be loaded to the site this weekend but they will upload it earky if youd like it. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Apr 29, 2008
SOURCE: 4 blinking lights
I fixed it myself!
I bit the bullet and ordered a replacement Power Board for AUS$290 and swapped it out myself.
Only took ten minutes, most of that time was removing and replacing the 101 screws holding the back panel on!
Working fine again now.
I did sit the two boards side by side and noticed the new one had moved some of the micro components from the back of the board to the front plus some other small component changes.
If your handy with a screw driver and have some technical knowhow I recommend having a go at fixing it yourself as it wasn't hard and probably saved $200 in service charges (all this assuming you are out of warranty!)
Posted on Oct 27, 2008
  • 23 Answers
SOURCE: My panasonic TC-L32X1 has the power light blinking
its a new t.v, send it back and get another one, or contact the Manufacturer for 1year fac and lab warrenty.
Trust me i am the flat pannel guru :)
Posted on May 02, 2009
  • 8457 Answers
SOURCE: I turned on power and red light is blinking but tv
Tries unplug,replug the tv back like an hour later.The tv now,should resetting itself back to the factory setting.The tv should work now.Not,than the tv power supply board have problems,not giving the tv it wright voltages anymore.The tv power supply board that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Nov 06, 2010
  • 12 Answers
SOURCE: Panasonic TC-P54G25 plasma hdtv won't
Perhaps an easy fix. Remove the back of the flat screen. There will be a main circuit board visible. There will be several capacitors, cylinders with a cross hatch on the silver top. Do any of them look like they have a dimple created by expansion of the internal capacitor material over heating? If you see an expanded top...that's probably your problem. Get your solder gun out and replace that capacitor. You can order a new one off of Amazon. If yours is a 10 volt capacitor, consider replacing it with a 16 volt unit. Generally the electronics companies under design the size of these units. When you replace the capacitor take note of the silver band on the unit and where its placed in the two socket holes....there is a positive and negative hole placement.
Posted on Jan 03, 2011
Panasonic TC-P50X1 don't come on, red light blinks 9 times what is the problem
1) try doing a RESET.
2) if that does not work. with most flat TV today. There three circuit boards - an input, a power and a video. Usually, it is the power supply and specifically, the capacitor(s) that goes wrong. It has high voltage (400 volts) but low current.. Replace this capacitor or could be capacitors.
Oct 26, 2017 | Panasonic Televison & Video
Panasonic Plasma TC-P42C1 10 light blink code, then the light came on and then no light at all-nothing! Power Suppy board?
By blinking led its shows where is exactly the complaint. You have to count the blinking. How much time its blinks in one sequence. the only it will be possible to say is it power supply or any other boards.
www.electro-medical.blogspot.com
Sep 03, 2015 | Panasonic Televison & Video
Screen not showing
Does the power led blink and what's its pattern ( 1 blink, 3blink...)
If power led does not appear it could be a power supply failure but it's not common for Panasonic brand.
Nov 27, 2014 | Panasonic Viera TC-P54S2 54" Plasma TV
Panasonic TC-P54Z1 flashing image
Please remove all HDMI cables from the TV and test a different power outlet. If the problem persists then we recommend you use the below link to locate an authorized service center.
www.panasonic.com/repair Welcome to Panasonic Online Repair
Apr 21, 2014 | Panasonic VIERA TC-P54Z1 54 in. Plasma TV
Tv. TC-P42X1X. in protecction.
Might be a problem with bulged capacitors - its one of the most common faults on any electrical item - best take it to an electrical repair shop.
Unusual on a Panasonic television as they are the best you can buy for a reason they used to use the best capacitors and internals.
Apr 11, 2014 | Panasonic TXN/A1EQUUS TNPH0800 Main Board...
Tc-p50g20 4 blinks
My panasonic TC-P50G20 does not power on, just I have 4 blinks on my powericon1.png indicator light. What error does that mean?
Jul 24, 2013 | Panasonic Tc-p50g20 Viera G20 Series 50"...
My TV just turned off and the power light flashes 8 times. what is the flash code for 8 times on a panasonic TC-50PS14
thought I would post this here for everyone.
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
May 14, 2010 | Panasonic Televison & Video
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
