Question about Ingersoll Air Tools & Compressors
H253X5 IR compressor manual - Ingersoll Air Tools & Compressors
I have an old IR 30 T that needs repair where do I find a manual for this
You may find your parts manual for your compressor here http://www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Just scroll down the page, the manual for an IR 30 is there, also on that website, you may find the problem to your compressor
Sep 29, 2012 | Ingersoll Rand - Rand Type - 30...
Hard starting does this model have an unloader
There are two types of unloaders used on IR compressors. One is oil pressure controlled, and second is manually activated for starting. According to the photo and model number provided, yours is manually operated. Follow air line from compressor to tank. The pilot valve (brass valve) between airline and tank is a multi-function component. There is a flip leaver or pull ring w/ hold that unloads the compressor by venting air thru small muffler. The valve also contains the check-valve holding pressure in the tank, a means of adjusting pressure and controlls throttle for engine. For easy start, flip leaver upright and start; to run, flip leaver to right angle of stem.
Nov 19, 2010 | Ingersoll Rand 2475F13GH Ir Stationary...
Ingrsoll rand air compressor repair manual
Most manuals are available from Ingersoll-Rand, I am not sure they sell a repair manual. however they do have owner and parts manual for the pumps that show breakdown of the pump and can be very handy for reference when working on one. Contact your nearest IR air center and ask for a copy of the manual, and most times they can provide you a copy for little or no cost.
Jan 08, 2010 | Ingersoll Rand Air Compressor Maintenance...
My IR 2340 air compressor wonr drain with the auto
its most likley to be blocked with muck take it off and give it a good clean
Oct 22, 2009 | Ingersoll Rand 2340/2475 Electric Air...
LOOKING FOR A MANUAL ONLINE THAT I CAN DOWNLOD AND PRINT.
best way to get manuals is to notify grainger with the model # of I.R
Jul 10, 2009 | Ingersoll Rand Air Compressor Maintenance...
Trying to get an operations manual for an 1000 cfm and a 1300 IQ series, but cant download from anywhere?
Best solution for this is to call I.R with model # and serial # to get manual , they may charge you.
Jul 07, 2009 | Ingersoll Rand Air Compressor Maintenance...
Where can I find the owner's manual for an IR Type 30 model 25T
IR has not made their owner's manuals available online. You have to contact your nearest dealer in order to get one. If you do get one, could you please consider uploading the manual to fixya.com to help other people who a looking for the same thing.
May 13, 2009 | Ingersoll Rand Type 30 Reciprocating Air...
Need manual for IR ss3-e compressor
I have worked on many IR compressors with the SS3 pump. A parts list can be faxed to you from grainger, use part #1WF72 for the pump only. Or try this address : http://www.capsaust.com.au/Uploads/Downloads/ss3-parts-breakdown.pdf
Order pump parts from grainger. The other parts can be replaced with generic grainger parts such as the pressure switch, check valve, capacitors etc. for the motor. If you are having a specific issue with your unit please detail the problem on your next post or email me. I will be glad to work thru the problem or modification. Good Luck!
Feb 20, 2009 | Ingersoll Rand Type 30 Reciprocating Air...
Air Tools & Compressors Logo
32 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
