Question about Hardware & Accessories
Rainbird ESP-Me Controller
I have 4 zones, 2 heads per zone. Just installed a new ESP-Me controller. Got everything hooked up correctly, set the time/date and manually ran the system. Everything worked fine in the manual mode. Then ran "test all stations" for 2 minutes - zone 1 ran for two minutes - shut down and zone 2 ran for two minutes - shut down and zone 3 ran for two minutes - shut down and zone 4 ran for two minutes and shut off. Set the watering start time for 3:00 p.m. for 30 minutes a zone and set the clock for Auto. At 3:00 p.m., zone 1 comes on and runs for 30 minutes - shuts down AND THAT IS IT. Zone 2, 3 or 4 never come on. I only have time on Program A (B-C-D are empty). What did I do wrong??? Steve
2 Suggested Answers
  • 8 Answers
SOURCE: Sprinkler control box appears fine, but sprinklers to not open
If all zones do not open, I would check the water supply first. Verify that the water is indeed on. If you have water at each valve location, then I would check at the wiring at the controller. Use a Multi-meter & check the resistance (ohms) between the common wire terminal and the wires at the terminal for zones 1 through 6. If you get an open loop (O.L.) reading on all zones, I would think the common wire is cut or disconnected. Also look for a rain sensor that could be wired into the common wire. If it is faulty or stuck, it could cause an O.L. in the wiring. If a rain sensor is wired in at the controller, disconnect it from the common wire path and connect the common wire directly back to the common terminal. If it works now, then you have a bad rain sensor.
A normal reading should be 20 – 60 Ohms from the common terminal to any zone wire. If you are in that range, the only other thing it can be is the output voltage from the controller to the valves. Use a Multi-meter & check the voltage at 24VAC terminals where the external transformer is connected. You should have 24-30VAC. Next, open zone 1 and check the voltage between the common wire terminal and the terminal for zone 1. You should have the same reading as you got for the transformer. If you have nothing or a large difference, then I would suspect the controller might be damaged.
Remove the power & 3 volt lithium battery and wait 2-3 minutes, then reprogram the controller and try again. Good luck!
Posted on Jul 28, 2009
Rainbird esp modular controller will not operate system -
Make sure that the transformer is supplying the 26 volts ac required by the pump relay and zone solenoids. If the voltage is there and unit still will not operate then the electronics are to blame.
Jul 22, 2016 | Rainbird Rain Bird Esp-4mi Esp Modular...
When on auto mode, the system just keeps repeating the zones.
I don't feel you can repair system by yourself. Excuse me if you can; so do it.
You should take it to an authorized Rain Bird repair service. Look for it on some listing they might have given you when you bought your stuff or contact them from here:
http://www.rainbird.com/corporate/contact.htm
Sep 20, 2015 | Rainbird Rain Bird ESP-4ME Modular Outdoor...
Rainbird troubleshooting
Check to see if the wiring is crossed.
Jul 18, 2014 | Rainbird Rain Bird Esp-lx 4-station...
Check to see what the codes refer to. It could be a zone solenoid going bad.
Jul 13, 2014 | Garden
They shouldn't be working all at once. Check the wiring. Each zone should be on it's own terminal in the controller. Also check the boxes outside to see the wiring wasn't done incorrectly.
Jul 06, 2014 | Garden
Using a volt-ohm meter check the voltage in the wires connecting to the troubled valve, with the station on. You should be getting about 24-28 volts AC. If not, check for this voltage back at the controller/timer. If present at the controller but not at the valve look for a broken or corroded wire. If you have the proper voltage at the valve you will need to check the selenoid for resistance, which should be 18-25 ohms. Or, you can just replace the selenoid in the valve for about 10-15 dollars.
Jun 20, 2014 | Garden
Zone 1 stays on all the time even while other zones go
Sprinklers and valves can get clogged. First turn off your controller, then remove Zone 1's valve... see if you can determine if it is clogged. Then clear the clog or replace the valve.
May 25, 2014 | Rainbird Rain Bird Esp-sm3 3-station...
Jul 27, 2009 | Hardware & Accessories
Hardware & Accessories Logo
41 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
