Question about Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground
Timer clock not running correctly
I have reset the clock and pins three times and it appears not to be operating correctly
  • Malibu Master
  • 5,089 Answers
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    I have the 59017 Mechanical. I set the pins and turned on in timer mode. It comes on at specified time, goes off after specified time, but then does not come on again the next night.
    I don't have repair for defective timer:
    If Load and Line wires are reversed, that could explain problem. Reverse timer red and timer black wires. Symptom of this problem: the clock dial stops rotating after tripper pin.
    Troubleshoot run-through:
    1) Use fingers and manually rotate timer dial several times and watch if Load turns ON-and-OFF
    This will tell you if load is operational, and pins are set correctly.
    2) Set slide switch to Timer.
    3) Make sure timer is wired correctly. This timer needs neutral wire to operate clock motor. Open following link to see illustration and read about wiring. Line and load wires must be correct.
    http://waterheatertimer.org/images/GE-15070-wiring-1-500.jpg
    http://waterheatertimer.org/Woods-timers-and-manuals.html#59017
    4) Check that wire nuts are attached very tight and there are no loose wires.
    Additional resource:
    http://waterheatertimer.org/How-to-set-timers.html
    Aug 21, 2011 | Woods Mechanical Inwall Timer 59017
    I have installed a new adjustable thermostat unit (E1-BCANRT1W). Temp is set at 91 deg and I am using the timer. Two time periods are set and the switch is set to timer (not ON). The unit comes on at...
    Double check your slide switch.
    For timer: set switch to TIMER
    For thermostat: set switch to ON
    If slide switch does not operate, then Autocirc may be defective
    Laing (800) 554-6853
    http://waterheatertimer.org/pdf/Laing-E1-E3-E10-install-instructions.pdf
    http://waterheatertimer.org/pdf/Auto-circ-manual.pdf
    http://waterheatertimer.org/Water-heater-recirculation-system.html
    1) Household AC wiring will not affect the timer.
    You can check your outlet using cheap circuit analyzer from home center.
    The clock rotates one direction and the pins push small lever down which turns motor on-off.
    When the OFF pins pass, the small lever snaps back and the motor turns ON.
    I cannot immediately find operation manual for the E-1 model.
    Typical ACT303 auto circ manual says following:
    2) If timer controlled operation is desired, set timer and move slide switch to TIMER:
    Manual says: tabs/pins are outward for ON times.
    Another sentence says UPWARD, so I don't know which way the pins are set for sure.
    So if you want timer ON for 2 hours, you would set 4 consecutive pins outward or upward.
    ON for 6 hours, set 12 consecutive pins outward or upward.
    If the timer turns ON in reverse of instructions, then set the pins that way.
    Autocirc does not make the timer, they buy timer modules from clock-makers like Grasslin, Intermatic, etc.
    3) To operate Autocir thermostatically without the timer, slide switch to ON position.
    The clock dial will continue rotating
    Apr 14, 2011 | Laing Thermotech Autocirc Undersink...
    I want to reset the timer for hours of on-off for out water heater but can't figure out how to push the little white teeth in or out. Model is 265-1.
    1) Open following link to read about re-circulation systems:
    2) Image below show typical FM1 analog timer dial with pins:
    Move pins with fingernail or small tool.
    To test if pins need to be moved in or out, set pins each direction and manually rotate dial clockwise and listen when pump turns on-off.
    How timer operates: clock motor rotates dial continually, pins on dial move lever that turns circuit on-off.
    To set current time, manually rotate dial clockwise until current time lines up with arrowhead located on inner dial.
    Some timers have a selector switch: move switch to Auto, or Timer, or Timer ON. Again you can manually rotate dial and check which setting is correct.
    Add a comment for more free help.
    Also take advantage of fixya phone service.
    For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
    Fixya is always less expensive than a service call.
    Feb 14, 2011 | Taco 265-1 / 563-2 Combination Analog 24...
    A FRIEND OF MINE HAS A T103 TIMER FOR HIS OUTDOOR SIGN. I RECENTLY INSTALED A NEW CLOCK MECHANISM, HOWEVER IT WILL NOT KEEP CORRECT TIME TO TURN THE SIGN ON OR OFF AT THE PRESET TIMES. IS THERE A WAY TO...
    1) There is no speed adjustment on timer clock motors.
    They are manufactured for 60 Hz, which is the controlling factor for motor speed.
    60 is the number of cycles per second that AC electricity oscillates, caused by a turbine spinning inside magnetic field at power plant. This speed is very constant, and so clock motors keep correct time for years or decades.
    2) A loose wire or loose circuit breaker could cause motor to lose power at times.
    Clock would appear to run slow.
    Check terminals. Make sure no insulation is sitting under the screw-down plate on timer terminals.
    Tighten wires very tight against copper wire.
    Move Hot wire to another circuit breaker and see if problem persists.
    Tighten screw on neutral wire on neutral busbar inside breaker box.
    3) Problem could also be bad clock motor for some reason.
    For $16 replace T100 series 125Volt clock motor
    http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK1?Pid=search
    4) Trippers contact a lever, make sure lever has bit of grease so trippers are not hanging on the lever. Off tripper moves lever one direction, ON tripper moves lever other direction.
    Double check operation of lever by moving override back and forth.
    Override should snap crisp and clean, and not be extraordinarily hard to move.
    For a price, fixya expert speaks with you over phone while you work on timer.
    Jan 05, 2011 | Intermatic T103 Indoor 120-Volt 40-amp...
    I've set the time on/off and ive tried turning on manually but the lights wont turn on on exact time set. y? when i manually turn on the lights come on 2 hrs later or so, y doesnt it turn on right away?
    If I understand correctly, you have an Intermatic timer.
    The timer has a yellow dial that rotates around like a clock.
    Does the manual override work?
    If yes.
    a) then the circuit has electricity
    b) the lights are in working order
    Does the clock rotate?
    If yes
    a) then the timer is probably good
    b) the clock motor could be bad
    c) the gears could be rusty and dirty
    Do you have the current time set correctly?
    Lift and rotate dial until current time lines up with silver pointer.
    Do you have the trippers set on the correct time?
    There are ON trippers and OFF trippers
    Attach trippers to correct time
    Tripper pins wear out
    Suggestion: You sit in front of the timer and watch the trippers as they rotate to the bottom of the dial
    When the trippers get to the bottom, they push a lever that turns lights on and off.
    Look at the photo:
    Here's a website that sells tripper pins and clock motors for Intermatic timers.
    You can buy new trippers or clock motor
    http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
    Answer this post if you still can't figure out the problem, or need more help.
    Oct 23, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
    Pump will run on manual setting but not automatic setting.new pins were put on
    If I understand correctly, this is a timer that has been in place for a while and is not a new installation?
    If timer has operated in the past, then the wiring can be eliminated as a suspect
    You say the manual override works correctly. That eliminates the question if timer has power.
    We have 2 suspects remaining:
    1) The general condition of the timer, whether the gears are rusty and dirty.
    Is the manual override snap over fully. Is manual override sluggish or crisp. The tripper pins have to move the same lever as the manual override, so if override is bad, the timer is bad.
    Turn off power
    Release mechanism using spring located top of box
    Tip out timer mechanism and look at gears for rust and dirt
    Does it look like the timer is too rusty for the trippers to click the on-off lever?
    Look at the back of timer for same problems.
    Spray a little WD-40
    You can buy a new timer of same type and swap insides without replacing whole box
    2) Clock motor
    Is the clock wheel turning as time passes? The clock wheel or dial must rotate for timer to work.
    You can replace the clock motor
    Take mechanism out as described above, clock motor is located on back and has identifying markings
    Order a new clock motor of same type:
    http://www.aplussupply.com/intermatic/timermotors.htm
    Upvote if this information helped. Thanks for the feedback.
    Oct 18, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
    Round soft key OXO Timer I need to change the clock time their model # is 1061978
    Operating functions:
    To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
    To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
    When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
    This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
    Sep 18, 2010 | Microwave Ovens
    My Ge Mechanical Time Switch (Model number 15087) is losing time. Is there any way to adjust the timer so that it keeps correct time?
    There is no adjustment if timer clock is running slow.
    Timer clock motors run slow when the motor starts to fail.
    There are no replacement clock modules this timer.
    Buy a new timer at Home Depot, and swap out insides of timer using 1/4" hex nut driver, and then return defect timer in new box.
    http://waterheatertimer.org/GE-timers-and-manuals.html#15207
    Aug 05, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
    Where can I download instructions for utilitech timer
    UTILITECH - Grounded in Quality
    Digital 2-Outlet Timer (TE06WHBL)
    Instruction Manual & Warranty
    Before using your timer please read the following instructions carefully.
    FEATURES
    - Up to 8 ON/OFF events per day/56 ON/OFF events per week
    - Option to program individual days or 8 different weekday groups
    - Minimum switching period one minute
    - Summertime/wintertime change over
    - Easy to read LCD display
    - Random automatic ON/OFF security feature
    - Countdown feature
    - Manual override button
    - Rechargeable battery back-up (if there is no LCD display, plug
    timer into a wall receptacle, this will recharge the battery)
    SETTING TIME
    Press and hold CLOCK key, then press DAY key to select correct day,
    HOUR key to select correct hour, and MIN key to select minutes. When
    MIN key is released, time will be set with seconds starting from 0.
    Either holding down or repeatedly pressing appropriate button can
    advance days, hours and minutes.
    Do not set ON and OFF for same time.
    PROGRAMMING EVENTS
    The timer has the capacity for 8 ON/OFF events per day.
    Save program capacity by using available blocks of days.
    Blocks of days are:
    1. M,T,W,Th,F,S,Su
    2. Individual days of the week
    3. M,T,W,Th,F
    4. S,Su
    5. M,T,W,Th,F,S
    6. M,W,F
    7. T,Th,S
    8. M,T,W
    9. Th,F,S
    For each ON time and each OFF time--DAY, HOURS and MIN must
    be set. Press PROG key onceto set first ON time--"ON" and number
    "1" appear to left of LCD display indicating to enter first ON time.
    Press DAY button to choose required day or blocks of days, then set
    hour and minutes using HOURS and MIN buttons. After setting required
    ON time, press PROG button to validate entry and move onto first
    OFF time--"OFF" and number "1" appear to left of LCD display
    indicating to enter first OFF time by using DAY, HOURS and MIN
    buttons as above. Press PROG button to validate this entry. Repeat
    remaining 7 ON/OFF settings as required. After setting required
    ON/OFF settings, press CLOCK button to return display to clock. Timer
    is now ready to operate. Check programmed settings by pressing
    PROG button repeatedly--each setting will appear on screen.
    MANUAL OVERRIDE
    To choose permanent Manual ON, permanent Manual OFF,
    Auto ON or Auto OFF, press Manual button. Each mode will be
    displayed on screen. When choosing Auto ON, timer turns ON until
    next programmed OFF time. The programmed settings will only work
    on Auto mode. When Auto mode OFF is chosen, timer is OFF until
    next programmed activity. (Inverted black triangle on LCD points
    to either AUTO or MANUAL indicating which is selected)
    COUNT DOWN FEATURE
    To enter count down feature, press CLOCK and PROG buttons
    simultaneously. Using HOURS and MIN buttons, set count down time.
    (Maximum selection is 9 hours 59 minutes, minimum is 1 minute.)
    Press MANUAL button to start countdown. Output will turn ON until
    end of count down. Count down may be paused at any time during
    period by pressing MANUAL button. To re-start, press MANUAL button
    again. To review time during count down period, press and hold
    CLOCK button. Release CLOCK button to return to count down display.
    Note: To return to timer mode, press CLOCK and PROG buttons
    simultaneously.
    RANDOM AUTOMATIC ON/OFF SECURITY FEATURE
    With this option selected, timer will switch ON and OFF in a random
    pattern at least once in every 8 hours. (This may mean timer will
    switch OFF within a set ON period, or vice versa.) Ideal for use with
    a light--switching it ON and OFF automatically gives appearance of an
    occupied home, but not at exactly the same time every day. To enter
    Random mode, press DAY and HOURS buttons simultaneously.
    An "R" will appear on display and unit will start random switching.
    If no programmed times are set, timer will switch ON or OFF
    approximately 1 minute after entering Random mode, then continue
    randomly. To turn Random mode OFF, press DAY and HOURS buttons
    together again.
    SWITCH OVER SUMMERTIME/WINTERTIME ZONE CHANGE
    To change from wintertime to summertime, press HOURS and MIN
    buttons simultaneously. Clock will be set forward one hour and
    "S" will appear on display. Repeat same procedure to return to
    wintertime.
    Note: if unit is purchased during summer, set clock time for one hour
    less than correct time, select Auto mode and press HOUR and MIN
    keys simultaneously. The unit will then adjust to correct summertime
    and "S" will appear on LCD.
    RESET
    To reset unit for time and programmed ON/OFF settings,
    press RESET button.
    IMPORTANT SAFETY PRECAUTIONS and
    RATINGS
    [Contact the manufacturer; I've already wasted too much time typing
    this in:
    AmerTac
    Saddle River Executive Centre,
    One Route 17 South, Saddle River, NJ 07458
    800-777-0802
    www.amertac.com
    Made in China
    May 05, 2010 | Kitchen Appliances - Others
    Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground Logo
    183 people viewed this question
    Top Malibu Hardware & Accessories Experts
    Gene Haynes
    Scott Jelt
    Scott Jelt
    jdthefixer
    Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
