Question about Onkyo Audio Players & Recorders
How to remove hdmi board from TX-SR805
How do I disconnect right side of the hdmi board. I want to repair the board, but it's not obvious how to unplug the board from the right end connectors. rdogs
3 Suggested Answers
  • 69 Answers
SOURCE: The left front channel is
Is this new? it could be a bad amp channel.
Posted on Aug 13, 2008
  • 899 Answers
SOURCE: where can I buy circuit boards for Onkyo Receiver TX-SR805.
have you checked these out , also you can contact the seller for other parts.
check it out !
http://shop.ebay.com/items/_W0QQ_nkwZonkyoQ20partsQQ_armrsZ1QQ_fromZQQ_mdoZQQ_sopZ12
Posted on Mar 15, 2009
Cant get new HDMI board for Onkyo TX-SR604
It's usually the hdmi switching IC that goes bad on these. Not something you can really replace without the right equipment and knowledge.
Jul 10, 2013 | Onkyo Tx-sr604 7.1 Channel A/v Receiver...
Tip
ONKYO TX SR804 DISPLAY, SUB VOLUME AND SUDDEN SHUTDOWN FIXES
The Mainboard on the TX SR804 is falty and i just fixed two units with this solution and it bullet prof un der the HDMI board you will find the mainboard stating up right with its back facing the preamp board and it has 3 screws that secure the mainboard to the system 2 on the middle top of the receiver and one on the right side just under the screw you removed for the HDMI board that secures it to the Audio processor board.
Once the screws have been removed pry the board back going from left to right and slowly disconecting the board. THE FIX. once infront of you clean all of the ribom connectors and the and bend the pins on the connector P954A, P959A , P2005A and P2004A THESE CONECTORS ARE THE REASON THE SYSTEM WILL SHUT DOWN SPECIALY THE FIRST TWO. I ALSO RECOMEND PUTING A INTERNAL FAN POINTING TO THIS BOARDS KEED THE HEAT DOWN. the reason the SUB is low or the HDMI does not seem to work well they are related to the SIF connectors on the the are 4 on this board and i used a thin bud hard plastic and inserted bering each sif cable to push the pins againt it. this is a 20 minute job and you amp will be fixed. i fixed many like this. Have a wonderfull holiday. Mvianna
on Dec 21, 2008 | Onkyo TX-SR804 7.1 Channels Receiver
How to fix the HDMI board on Onkyo TX-SR608
If you look on the internet HDMI board failure on these Onkyo's seems quite a regular occurence.
Time to scrap the Onkyo and buy something with a better name - like Yamaha, Denon or Marantz.
Dec 12, 2011 | Onkyo TX-SR608 Receiver
Onkyo TX-SR805 Amp isnt projecting the picture through my Sony kdl46xbr. i am recieving sound but no picture. Reconnecting direct from source to TV and no issue so the problem is with the amp. HDMI symbol...
I have a 607 by Onkyo and you have to assign imputs to the imput selector. I don't know if your model uses the same, but if it does press setup and select input assign then select HDMI imput to see what it is set to.
Mar 06, 2011 | Onkyo Audio Players & Recorders
Display Panel Problem.... my Onkyo TX-SR805 AV receiver works properly except No Display on the front panel. I follow the instruction troubleshooting on the manual by resetting the unit but to no...
I follow the instruction troubleshooting on the manual by resetting the unit but to no avail. It's beyond warranty period.
please help, thank you
Sep 27, 2010 | Audio Players & Recorders
TV will not Power Up / Blinking Green Light on Power Button
May be the same problem Magnavox is having with their 27MF231d. I found the fix on this site and it took care of the same problem with my set. Not the easiest thing to do, but it worked. If you do not know how to solder, get some help with this one. If you take it to a Magnavox Authorized repair location, they will just replace the bad capacitor with another bad capacitor of the same type and voltage. The problem is they have a 25w capacitor where a 35w capacitor should be. Mine was bulging, with black tar looking stuff coming out of it. It was obviously bad. Follw the instructions below.
1. Remove all screws around perimeter, one screw at the lower right at (Side A/V), and 2 1”round plastic knob s.
2. Remove back cover
3. At lower left side remove 2 screws for On/Off switch cut tie wrap that holds wire down for free movement.
4. Disconnect wire connector to side A/V at lower right side
5. Disconnect wire connector to right side circuit Board
6. Disconnect wire connector to left side circuit board
7. Remove the 2 mounting brackets upper left and upper right 2 screws each.
8. Remove 3 screws each side of the metal box in the middle
9. Fold back metal tape off bottom and top of metal box
10. 1 wire connector at top of box I left connected
11. Flip metal box over towards top of Tv. Be careful of wire at top thats still connected.
12. On left side in box is power supply board
13. Towards bottom of board you should see the numbers C2081 and C2074
14. Remove the six screws holding down power supply board
15. Flip board down towards bottom of Tv.
16. Unsolder capacitors replace with new 1200uf 35v and 2200uf 35v 105°C radial capacitors
17. Capacitors should be around 1/2” to 5/8” dia. X 1.25 long appox. 2 Wires come out of one end should be .030 dia.
18. Reassemble in reverse order and enjoy
Nov 26, 2007 | Philips Magnavox 52MF437S/37 52 in. LCD TV
22 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
