Question about Aiwa Audio Players & Recorders
Aiwa turntable PX-E855
I got it today. Tried to play a record and arm just slide accross the record.
djproaudio
  • 515 Answers
SOURCE: Aiwa PX-E860 turntable
Don't understand. If it doesn't turn on, how do you know the electronics are ok? More than likely your transformer shorted, and will need to be replaced.
Posted on Sep 24, 2007
SOURCE: aiwa stereo turntable system px-e860k
how long have you had it? could be that you just need a new belt if it keeps slipping off...
Posted on Oct 20, 2008
arthurroger
  • 170 Answers
SOURCE: turntable arm slides across record, Am. D.J.-1500
See what type of cartridge is installed in the arm. Manufacturers use common cartridges in turntables, such as Stanton, Shure etc. Detach the head shell from the arm (it usually slips right off via a locking ring and four-pin mini plug) Look for the manufacturer and model number on the cartridge. No need to remove it from the head shell. On most modern cartridges, the stylus (as they are called, rather than the needle) simply slips off and on. No need to remove the entire cartridge (via screws) and re-align it. In fact, many DJs bring a set spare cartridges and styli on a gig, already mounted in head shells, and simply interchange them as needed. When you have the make and model of the cartridge, go to Radio Shack or use their website to order a new one...or  two. Or go to Google and enter "phono stylus" as your search term. You will find reasonably priced styli for nearly every cartridge imaginable. I operate 50 year-old turntables and am able to find replacement cartridges and styli on line. Ebay also has a number of listings, by make and model of the cartridge. When the new stylus arrives, observe how easily the old one comes out of the cartridge- usually pull and slide - and slide the new one in. Re-insert the head shell on the arm, tighten the locking ring, and you're good to spin!
Posted on Jan 08, 2009
  • 18 Answers
SOURCE: Aiwa turntable PX E855 squeaking may need oil
lift off the rubber platter, the turntable should just lift off but there may be a circlip to remove around the spindle if so use needle nose plyers.
When the turntable is off you should be able to see where the noise is coming from by using your fingers.
Only use light machine oil very sparingly
Posted on Nov 27, 2009
Testimonial: "Might help to explain what we will see when we remove t'table.Found & oiled driver shaft but band fell off. I figured it out but others might not. Tx!"
  • 396 Answers
SOURCE: how do I attach the turntable belt to the Aiwa px e850
Lift the platter off the turntable. You can identify the motor spindle by using your fingers to turn the round shaft which rotates freely. Remove the rubber mat off the platter. Place the belt around the outside of the drum on the bottom of the platter. From the top of the platter, place your finger in one of the platter holes and tension the belt so it will not fall off or twist. Griping the platter trough the holes while keeping tension on the belt place the platter on the turntable aligning your finger with the belt to the motor spindle. Place the section of the belt on your finger over the motor spindle. Replace the rubber mat on the platter.
Posted on Jul 21, 2010
My Aiwa px e860 record player arm is too heavy how do I adjust it?
If you put the maker and model number into Google you will find a service manual free for the make. That should help you sort out the problem. It's just a question of getting the weight at the other end of the arm adjusted right.
Dec 11, 2016 | Aiwa PX-E860 Turntable
The start and cut switches do not seem to work I have it open and the wires do not seem to be attached to anything
Aiwa lid close control switch Turntables Questions ... - Fixya
www.fixya.com > Forum > Tags > lid close control switch > Turntables
Aiwa turntables lid close control switch related questions and answers. Ask your Aiwa... Ad. Question about PX-E860 Turntable ... aiwa lx 70 turntable needle arm My aiwalx 70 turntable is not working. I can power it up, and when i press the start/cut button the platform rotates, but the needle arm does not move to play the .
Aiwa fusing unit Turntables Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fusing unit > Turntables
the drive belt on my Aiwa px-e860 turntable has come off. how do i put it back on Lift... the start/cut button the platform rotates, but the needle arm does not move to play the . ... will not turn,belt o/k fuse o/k Check any switches to see if they work.
Jan 16, 2016 | Aiwa PX-E860 Turntable
Aiwa PX-E850
Hi, most likely the auto function needs resetting. With the power off turn the platter manually clockwise a dozen or so times. Power up and play. Cheers john.
Apr 08, 2013 | Audio Players & Recorders
Aiwa turntable px-e860: Hi, I've inherited this timetable from a friend and it's worked fine until recently but now here's the problem: if I push start, the arm lifts up, moves to the record...
Hi, I;m not familiar with that exact model however the problem you are describing is commonly caused by the automatic operation at some point not being allowed to complete its full operation. Ie the tonearm has been returned manually to its rest position before reaching the end of the record. Try this. With the player not powered up lift the tonearm across to the record run off groove and sit it there. You may feel some resistance which is normal as the mech has to eswt itself. Now turn on the power and turntable. The arm should automatically return from there to its rest. Try auto operation after that. Let me know how you go. Cheers John. styluscity@gmail.com
Oct 10, 2011 | Aiwa PX-E860 Turntable
Not used the PX-E855 for years. Now I need to
This is an extremely simple unit: a power cord, a power switch, a motor powered at the mains that drives the platter thru a belt, with a small switch attached to the arm and a small electronic board to process the sound and sent it to the outputs.
If the unit is totally dead (the platter doesn't turn and the humming of the motor can't be heard when you move the arm) then it's either a power cable problem (it has a break in it) or one of the 2 switches has failed because its contacts have been corroded by the humidity in the air. Just check them with a simple multimeter and replace the failed one. The switches might be revived if you repeatedly activate them - with the unit unplugged of course.
May 11, 2011 | Aiwa Audio Players & Recorders
Aiwa fully auto turntable the arm just keeps going back and forth and dosent rest
Check your weight's positioning. Moving it towards the record will help it from skipping. Hope this helps
Jan 26, 2011 | Aiwa PX-E860 Turntable
I have an Aiwa PX-E80K turntable. Whenever I start the turntable, the tonearm raises moves across, drops on the outer edge of the vinyl then then turntable stops. The belt is still attached. Anyone able to...
I suspect the belt is that slack that when the arm weight is on the record, the belt slips around the shaft of the motor. Does it start up again when the arm is lifted up? If it does then you need a new belt.
Jan 09, 2011 | Aiwa Audio Players & Recorders
On my Aiwa PX-E860 the automatic mechanism is failing - when i thry to manually place the stylus the platter does not turn - is there a way to by pass the automatic part and just have it manual?
Select the record speed.
Press the 2 down arrows or triangles( placed side by side) - This the same thing you press if you want the styles to lift during play
Place the stylus on the desired spot.
Press the same button again.
The stylus will drop to the desired spot & continue playing
If you have the manual look it up, else download one from this site after becoming a member(its free)
http://www.retrevo.com/support/Aiwa-PX-E860-Turntables-manual/id/1077bh126/t/2/
Nov 30, 2010 | Aiwa PX-E860 Turntable
Can you still get the px-e860 turntable? The one I have won't make any sound thru the speakers
Judging by my own experiences with hifi gear on eBay there is little on the face of the planet that ever really becomes UNavailable.
Wouldn't an attempt to resolve the issue work, too?
Describe your setup (preamp, amp, whatever) and if it has ever or never worked.
This unit can work through its own preamp with any audio equipment or with old-school gear already having an internal Phono Preamp. There's a switch to select which one.
Apr 08, 2010 | Aiwa PX-E860 Turntable
Nov 27, 2009 | Kitchen Appliances - Others
63 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
