Question about Air Tools & Compressors
Wiring diagram for pressure switch on a craftsman 919.152911
Craftsman 917289101 wiring diagram
The diagram will not be of much help. Try a an ohm meter for continuity, wire by wire with ground.
Jul 06, 2015 | Craftsman Garden
HOW DO I RECONNECT THE SWITCH
manufacturer will provide wiring diagram if requested. If it's just the kill switch it doesn't matter-just put them on the switch. As long as you're not shorting them to ground, the wiring isn't crucial in a little motorised unit like this-that is: if you get it wrong, no harm but no go/ get it right and your going.
Nov 18, 2014 | Craftsman Crafstman 2,500 PSI, 2.3 GPM...
I have a Craftsman compressor Model # 919-15292 2. The compressor stopped building pressure because air was continually being released through the unloader valve. I have replaced the unloader valve,...
you must have wired the new pressure switch incorrectly .when the pressure switch opens it will release the head pressure so your compressor must be running with the pressure switch contacts open should be 4 connections 2 marked motor which is from your compressor and 2 marked line which is your power coming in
Jun 15, 2011 | Craftsman 33 gal Air Compressor 6 hp...
Aircompressor 1hp. 106-174541.how to hook up wires for motor and pressor switch
Unless the wiring has been removed, the pressure switch to motor wiring should be ok. The input AC 115 volt line connection goes directly to the pressure switch. Be sure to connect the line ground connection (green or bare wire) directly to the pressure switch box (green screw). Hope this helps!
Jan 17, 2011 | Craftsman Garden
Need a new pressure switch for Craftsman model 919152920 compressor, but that part is no longer available. The switch doesn't function to even turn on the compressor.
You can purchase a generic/ universal pressure switch from www.grainger.com or ebay. Just look for the correct fittings and pressure cutout. Cost about $20. Before you order a new switch you should test that motor and pump are ok. Jump the wires on the pressure switch temporarily so line-in is connected to motor line. When you connect cord to wall plug the compessor should start and begin to fill. If function ok then order switch. If the motor does not start, may not be switch. Good luck
Nov 09, 2010 | Craftsman Air Tools & Compressors
Motor will not stop.
The wiring for the limit switch assembly is:
Yellow wire to the up limit contact
Gray wire to the center contact
Brown wire to the down limit contact
Nov 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a 33 gallon Craftsman compressor that won't start. It's plugged in. There's power, but the switch seems to be dead. I tried unplugging it and letting it cool but it won't start up again. Any ideas?
Idea 1: your breaker/fuse is tripped/blown in the electrical panel, reset/replace and check the compressor again.
Idea 2: you may have a bad electrical cord with a break in it going to the pressure switch.
Idea 3: The pressure switch isn't closing the contacts when pressure is low. (bad pressure switch)
Idea 4: Wiring from switch to motor has a break in it. (test the at the motor for proper voltage) If proper voltage:
Idea 5: Bad compressor motor.
Oct 29, 2009 | Craftsman Air Tools & Compressors
I need a wiring diagram for the ignition switch on a model#917255691 sears riding mower Thanks for any help rcwebster72@hotmail.com Carlton Webster
Go to www.partsdirect.com. This is Sears website for equipment information. Put the model number in and it should find the model you are working on. A diagram should be available there.
Sep 25, 2009 | Craftsman Garden
Automatic shut off craftsman 1.5 hp compressor
It sounds like the pressure switch is defective or the unit is miss-wired . If you have the owners manual check for a wiring diagram and follow the chart to try and locate the problem. If it is new return it to the place of purchase and have them fix or replace it.
Sep 03, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
