Question about Sewing Machines
Threading bobbin on singer6268
A half screw or plug i found on top of bobber in compartment,and the bobbin won't thread now.
No i just don't know how to place it so that it works. Even the manual doesn't help!_!
Posted on Feb 02, 2008
Have you tried placing that half screw and or plug you found on top of the bobber compartment where it belongs: Normally underneath the bobbin compartment cover , at-top the bobbin case closest to you and your left..normally there will be a screw there to keep the bobbin and the bobbin case where it belongs, while it is doing it job.. at least thats how most of the sewing machines i have used or see or worked on have been.. Good luck.
Posted on Jan 23, 2008
SOURCE:
How to thread a bobber
try this link out and scroll down the page and you should find out how to do it... How to thread bobber Google Search
Oct 26, 2017 | Sewing Machines
Manuel for #1304 bobber thread is to loose,puckering.
Do you mean the Singer 1304 Start? Singer has the manual on their product page: http://www.singerco.com/products/2767/1304-start#type-support . The direct link to the manual is http://www.singerco.com/uploads/download/e280f4dc4898708d9534c5420eb1c9ffe9704c17.pdf .
On this machine, you can check the bobbin tension by removing the bobbin and bobbin case together. Hold onto the thread coming off the bobbin and let the rest dangle. Jerk the thread upwards once or twice. Look at how the thread unwinds. If the thread doesn't move, then the tension is too high. If the thread unwinds more than an inch or two, the tension is too loose. Adjust the tension by tightening or loosening the screw on the side of the bobbin case. See page 13 of the manual (page 30 in the PDF) to make sure that the bobbin is properly positioned in the bobbin case. See page 19 (page 36 of the PDF) for the bobbin thread tension.
I hope this helps.
Aug 04, 2017 | Sewing Machines
Thread is bunching up and it locks. Now needle wont pick up bobbin thread.
if thread is locking up on tension post then its set too tight or is not threaded correctly , this can cause lower thread to miss too having top thread too tight , also ck for a bent needle this is another cause of missing lower thread
Jan 19, 2016 | Sewing Machines
When sewing the bobber thread bunches up underneath, and breaks off. I have tried djusting the bobber tension screw, and upper needle tension to no avail. How often should I oil this machine?
1. Your bobbin should have one drop of oil on the race (little area that the bobbin rides on) around two bobbins that you have emptied.
2. The top tension is way too loose. When you put the pressure foot down pull the thread (top) to see if there is tension. Start at four is a rule of thumb.
3. I have included some rules to follow when you are setting tension.
May 08, 2015 | Sewing Machines
Kenmore 385. 15343600
Remove bobbin, presser foot, needle. Tip machine back on towel gently. Unscrew plate--don't lose screws! Do not service in presence of children and curious pets. Put foot pedal next to you on tabletop. Use Zoom Sewing Machine oil. Any part MOVING that are NOT gears get one drop oil. Any DRY ONLY gears get dab of Singer sewing machine lubricant. Replace screws. Secure screws. Open left front compartment & one drop oil @ top of needle bar. Open race shuttle (where bobbin case fits in). One-half drop oil of on oscillating hook (bottom left - hand corner...smear that oil around! Insert NEW needle all way UP in needle bar groove, flat needle shank toward back. Turn handwheel towards you and raise. Raise presser foot so that threading locates all tension slots a's you pull thread TAUT from spool to each tension slot and left to right through silver, metal take-up lever, and down to tension bracket, pass needle, then pull 6" thread towards you and thread from FRONT to BACK of needle. Place bobbin into case and "thread" it. Set presser foot on DOWN position. Turn handwh towards you, dipping needle into needle plate. Make loop with bobbin thread, pull towards you. Place a good 7" underneath presser foot (both threads). Let machine RUN on 24" scrap to distrubute oil/lube. That's it! Jimmy
Apr 05, 2012 | Sewing Machines
Tension in bobber is to lose
Is the thread clipped into the tension spring correctly and is the bobbin winding in the correct direction? Check your manual to see which way your bobbin winds.
There is good basic information on the www.sewing.about.com pages that are very helpful with threading, bobbins etc.
I always do the "Dangle" test with a bobbin case system, you should be able to suspend the bobbin by the thread and it should dangle in the air, so tension enough to hold it, but you should also be able to gently pull on the bobbin case and the thread should release when you pull. If you adjust the tension screw on the bobbin case, always , only a quarter turn at a time to adjust. Use a small screwdriver to do this adjustment and only change it a very little, test again, until you get it set right.
Feb 26, 2011 | Singer Sewing Machines
Will not sew
Check your bobbin compartment for loose thread and or debris. This often causes the thread not to combine properly. There is also a tensioner screw on the bobbin housing that can be tightened/loosened to adjust the tension, this may be the problem. Most machines have a removeable bobbin housing via clips or screws, to remove the assembly and clean.Or you can direct your queries to:
http://www.husqvarnaviking.com/us/2821_3079.htm
Mar 17, 2010 | Husqvarna Viking 1
I have a morse sewing machine model 4300
Check out this web page for instructions:
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Morse_Sewing_Machine_Threading/Morse_4300_threading_Diagram.htm
Aug 27, 2009 | Sewing Machines
The fabric gets pulled down into bobbin compartment and thread gets all bunched up hard to remove
It sounds like your bobbin compartment might be pulled out of alignment. You might want to take the bottom plate off, clean off any lint and threads, and put the bottom compartment back in. Follow your manual if you have it. With your right wheel, slowly start to sew is the top or bottom thread having problems? You may have to rethread top and bottom. I found that one time, my top thread was not threaded correctly.
Mar 24, 2009 | Singer 6038 Mechanical Sewing Machine
Bobbin won't thread
Sounds like the bottom tension is to slack.
Look at the side of your bobbin case, when you thread the bobbin thread part of the route it runs is under a flat leaf spring. There is usually 2 very small scews on this leaf spring one screw holds the spring onto the casing and will be tight. The other is the tension adjuster screw, turn this screw clockwise half a turn at a time. After each half turn pull the bobbin thread until slight resistance is felt. Then try sewing if bunching/tangles still occur more tension is required, this is trial and error until the tension is corrert.
If you want a new manual try this website if your machine is not listed email them and they will try to help.
www.sewusa.com
Oct 09, 2006 | Euro-Pro 373 Mechanical Sewing Machine
Sewing Machines Logo
156 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
