Question about Electronics - Others
Magnetek gpd 506 manual
Sc short circuit
2 Suggested Answers
  • 4234 Answers
SOURCE: where can i get service manual for my Technics sc eh760/790
I believe that these units use amp-pacs which look like large black ICs with multiple pins. If you can post the model number of the main unit, I should be able to get you the part number and cost. The model you list is the system model and I don't have a cross reference for those.
Thanks,
Dan
Posted on Feb 18, 2009
I can't get the CD player to turn on it is called SuperSonic audio system SC-506
There are a lot of possible failures but if you own tecnical skills look at the power supply first and measure the output votages.
Nov 24, 2016 | Supersonic Audio Players & Recorders
How do I solve problems with my Ricoh sc 506?
Google search Ricoh SC 506 and the words that describe your issue or problem. The search results will give you the information you seek.
Apr 30, 2015 | Ricoh Office Equipment & Supplies
TC-P50GT25 won't turn on
10 blinks check sc board for a short circuit in the mosfet ,replaces SC board
Mar 27, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
There's a problem with my Kenwood vr-506 the power
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
Jul 22, 2011 | Kenwood Audio Players & Recorders
Manual for Magnetek Converter 6300A
MagneTek was purchased by Parallax power
For a list of data and schematics, visit:
http://www.parallaxpower.com/LINEAR%20tech.htm
Jun 02, 2010 | Electronics - Others
F3 error on whirlpool duet front loader
F03 = HEATER SC TO GROUND
The Heater has a internal short circuit.
Short circuit of Heater to Ground.
Measure insulating resistance of heater between contact and housing
(norm. 2 M?).
Replace heater.
Perform test program.
Nov 11, 2009 | Whirlpool Washing Machines
Error
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Jul 08, 2008 | Ricoh Aficio 2015 Copier
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
