Question about Solar Electronics - Others
Stopped working my solar power inverter shut down and has not been able to work. on opening it we found the thermal heat protector element melted and disconnected. We have since replaced that part but it is still not working.
  • 1028 Answers
SOURCE: replacing Kenmore dryer parts
that one is old enough to vote..if filter on top remove back find small hole on right just below top may be hidden by pasted on tech sheet..through hole insert long socket 5/16 or reach up from underneath with short ratchet and socket remove screws and attached wires lift element housing up slightly and pull bottom of housing out and down..5/16 screw on backside holdes element in
Posted on Jun 19, 2008
SOURCE: Tatronic inverter problem
Tightened up battery connections
Posted on Sep 24, 2008
SRF518
  • 232 Answers
SOURCE: I have 46 solar panels which is a 9.2 kwh pv
are your inverters rated at 60 cycle full sinusoidal wave form or 60 cycle square wave. while both will be tolerated in a transformer, the square wave tends to heat up because it isn't a sine wave. the peaks of a standard sine wave are cut off if observed on an oscilloscope.
Posted on Oct 13, 2009
  • 5 Answers
SOURCE: my prosine 2.5 charger inverter intermittent
First try blowing it out the unit with compressed air to see if there is large amounts of accumulated dirt inside, look for black soot on the center of the air outlet side.
Intermittent problems are the hardest to troubleshoot.
If you need more help contact me at sunyout@gmail.com
Thanks.
Posted on Jan 12, 2010
SOURCE: Thermal cut-off blows and high limit thermostat is
in this case we put the lower temp thermostat in the oven at 170 degrees till it was hot and measured with ohm meter and it was open. After it cooled down some it went back to being a short. Now with this part in the dryer and the new high temp thermostat
and it blew shortly after being turned on. A possiblity is that there is a short by passing the 150 degree thermostat and the element keeps being on and causes the 350 degree thermostate to blow.
Posted on Apr 07, 2010
Kenmore dryer blows cold air. I replaced heat element still no luck? model 96263800
It doesn't necessarily mean the heating element is busted when an electric dryer stops heating. The heating circuit is not just composed solely by the heating element, it is composed by the thermal cut-off, high-limit thermostat, cycling thermostat, motor centrifugal switch, and the timer. The first thing to look at when an electric dryer stops heating is the thermal cut-off. It cuts power to the heating element when it blows most likely due to the failure of the high-limit thermostat. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 25, 2011 | Kenmore Dryers
I have a whirlpool LEC6646aq2. Noticed a burning smell inside drum.The dryer baffle inside the drum was completely melted. The timer was stuck on 20 minutes and the heating element was full on . The...
it sounds like one of the coils on the heating element could be touching metal and grounding out constantly running until you shut it down manually,when the heater is on the timer doesn't move until the heat shuts off,then the timer advances,when the machine calls for heat again the timer stops and the heat comes back on,it does this until the timer reaches zero but in your case the heater isn't shutting down and is keeping the timer from advancing.the filter is on the top of your dryer so unplug it,pull it out remove the ventline from the back of the dryer and remove the back panel,you'll see the heating element on the right side,also with a meter check the thermostats on the heater box,when checking any part at least one wire has to be diconnected or you won't get a correct reading,check for continuity on all the parts on the heater box,when the dryer is running correctly say you have a blocked vent line,when the dryer starts running hotter than normal the thermal fuse or the high limit thermostat will pop,the thermal fuse is the white piece to the right of the lint filter duct and the hgh limit is the top thermostat on the heater box,but with the element grounding out nothing will shut it down until you manually cut the power by moving the timer to off,if it melted the baffle you could have damaged other parts like the motor,check the rear end of the drum and see if there's like yellow on it or lint stuck to it where it touches the back wall,if there is then the oil from the motor sprayed out and the motor could last for a week or 5 years but the overheating most likely damaged it,if the dryer is old you might want to think of buying a new dryer instead of repairing it and then you have problems with something else like the motor or changing out thermostats in a month or two but you have to make that call,good luck and let me know what you find
Oct 30, 2010 | Whirlpool Dryers
Dryer stopped working, sounds like timer still running
I suspect it is the thermal fuse. Seen here. You will need to determine what caused it to blow. on these machines the blower wheel is notorious for getting loose and causing the element to over heat. This makes the heating element shut down faster and takes a long time to dry the clothes. 7fc125e.jpg
Apr 10, 2010 | Magic Chef CYE4000AWW Electric Dryer
Whirlpool Duet Washer error code A10
Motor Control Unit (MCU)
Heat Sink Thermal Trip
If the thermal protector on the MCU heat sink gets too hot, it will open
the thermal protector on the heat sink which will stop motor functions
and an “F/10” will be displayed.
1. Check for proper installation, verify the unit is not located
near a source of heat and has proper ventilation.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the MCU, the motor,
and Central Control Unit (CCU).
4. Check the drive system for any worn or failed components.
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
Feb 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore dryer no heat?
Sounds like the terminal block shorted. This was caused most likely by a broken element. It's located in a pan on the inside back panel of the dryer. It's a coil type, meaning that it comes in a bag and you have to stretch it out and string it. It's not hard and the bag has the instructions. It will even tell you how far to stretch the coil before you string it. The thermal limiter fuse is a normally closed switch that opens on the rise. When the heat at the element gets 220 degrees, it cuts power to elements. There is also a thermostat that is located on the vent housing that is the same kind but looks a little different, when the temp reaches 260 degrees inside the vent, it opens.
If it were mine, I would replace the element and the terminal block. I would also check the thermostat and the thermal limiter fuse and see if they have continuity. If so, it's ready to go and should be fine for years in theory. Good luck
Oct 19, 2009 | Dryers
Maytag Performa PYE2200AYW Dryer Heats intermittently
i had the same problem with my dryer and i installed the wrong thermal fuse for gas dryer which calls for a pink thermal fuse in which i installed and it works fine also check the lint in the front of your dryer. also my dryer which is the same make as yours seems will run on the fluff cycle until i replaced the right thermal fuse. my dryer run exceptionally hot and eventally shut down and it only run on the fluff cycle for any length of time.
Aug 03, 2009 | Maytag Dryers
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Dryer doesnt work but i hear the timer working
Change your cycling thermostat. When your cycling thermostat fails, then the reponsibility of your heating element to shut down goes to the high-limit thermal shut off (closest to heat element) and the thermal fuse. Your cycling thermostat should shut down heat element when it detects about 140* air in the blower housing. Yours can't detect that anymore so it lets your dryer heat up and up till you blow the thermal. new cycling thermostat and thermal
Jan 18, 2009 | Kenmore 60172 Electric Commercial Dryer
Whirlpool Electric Dryer Model LER8858EQ1 TYPE NO. 180-0
Based on the information that you provided, if you open the door in mid-cycle and the motor shuts off, but the element stays on, this will stop the air flow through the dryer and the element. The element temperature will rise drastically because it is not being cooled. Subsequently, to prevent a fire, the thermal fuse will open, shutting the element, and in some cases the motor, down.
A heating element gets its power from the timer, through the cycling thermostat(s),and to 1 side of the element.
When the motor starts, power is passed through the centrifugal switch in the motor, through the hi-limit thermostat and the thermal fuse to the other side of the element.
There is no ground wiring involved in the heat side of the dryer.
1. An element can stay on because it has broken and fell against the metal tube where it picks up a ground. Solution is to replace the element.
2. The centrifugal switch mounted on or in the motor can fail to open when the motor stops and allow current to flow through it
until the points in the timer open up, breaking the circuit.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 23, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer
First make sure you have power to the unit through the plug. If power is present, then you most likely have an open Thermal Safety Fuse. The Thermal is a Safety feature that shuts off the power to the Heat Element in the event the Blower is not blowing or the Lint Vent becomes clogged not allowing air to flow over the Heat Element. NO air flow, Heat Element over heats, Thermal Safety Fuse opens, power shuts off. If the Thermal Safety Fuse is open find out why. Was the blower not working? Was the Lint Filter clogged? ( Lint Filter should be cleaned after each use to assure continued air flow.) Was Lint Vent Clogged? This is the Vent Hose that goes from the Dryer to the outside of your house. It should be checked for free air movement. The next thing-- Could be a defective Timer or Control Module.
Find where you lost power and WHY!!
Jan 27, 2008 | Dryers
Electronics - Others Logo
26 people viewed this question
Top Solar Electronics - Others Experts
J.D. Browning
J.D. Browning
cwradio73
Are you a Solar Electronics - Other Expert? Answer questions, earn points and help others
