Question about Magellan RoadMate GPS
How to enter coordinates into GPS - RoadMate Magellan GPS
  • 504 Answers
SOURCE: gps coordinates
If you are asking to put latitude and longitude information into the C330, no, the unit is not designed to accept that type of information.
Posted on Feb 10, 2008
  • 638 Answers
SOURCE: eTrex Legend, GPS Coordinates from Google Earth Don't Match Basemap
Are you sure you're using the exact same format on GoogleEarth and your GPS?
GoogleEarth: save the waypoints in a KML file (NOT KMZ) to your computer, naming it appropriately.
Go to http://www.gpsvisualizer.com/gpsbabel/ and convert the KML file to a GPX file, using their converter. They will present you with a file to download. Download it and send those waypoints to your unit and you'll be set to go.
Posted on Apr 01, 2008
  • 638 Answers
SOURCE: Converting GPS coordinated to google earth coordinates
  • 638 Answers
SOURCE: How do I enter gps coordinates into my Etrex H
Mark a waypoint, and then edit the waypoint's co-ordinates. You can also create a waypoint in Mapsource and then transfer the waypoint(s).
Posted on Oct 09, 2008
SOURCE: GPS Coordinate Conversion
Just take the last 2 pairs of numbers and divide them by 6.
Example if it is 37 38 it would then be 623.
Posted on May 01, 2009
Can gps coordinates be used with TomTom go live 750
If you mean, can you enter latitude and longitude coordinates on your GO 750 LIVE GPS device .... yes.
First you'll want to set your unit to accept coordinates. From the main menu, tap Change Preference, then select "Set Units" and select a Latitude and Longitude format in the "Coordinate display" screen, and then tap Done.
To navigate to a location using latitude and longitude coordinates, follow the steps below:
  1. From the Main menu, tap Navigate to...
  2. Tap Latitude Longitude.
  3. Enter the coordinates and tap OK.
May 09, 2013 | Tomtom GO 750 LIVE GPS Receiver
How to put in coordinates
Coordinates can be entered by marking the waypoint and editing it.
From the map screen, press the joystick down for 2 seconds to mark the waypoint. Toggle up to the coordinates and press the joystick to enter the edit mode. Make the changes to the coordinates to the new coordinates and toggle to OK, press the joystick to enter the coordinates.
Dec 10, 2011 | Garmin eTrex Venture Cx 2.1 in. Handheld...
Can I enter GPS coordinates into a gamin zumo 550
Turn on Zumo. Select WHERE TO. Depress ARROW DOWN beneath ROUTES icon. There, revealed, are 5 additional icons, one of which is COORDINATES. There are more different choices of ways to enter coordinates than you're likely to learn what they are in a lifetime.
Happy motorcycling. Keep the shiny side up.
Patrick
Nov 05, 2011 | Garmin zumo 550 GPS Receiver
How do i insert a coordinate to find a spesific fishing spot
The Garmin nuvi's were designed as automotive navigators and not really designed to be used as marine or outdoor GPS units with the exception of the nuvi 550 which is an all around GPS.
The Garmin handhelds are recommended for marine and off road recreational use but it is possible to navigate if you know the coordinates of your fishing spot.
To enter coordinates: Touch Where to? > Coordinates and touch a box to enter a coordinate.
You can also refer to the manual for more information. nüvi® 215
Sep 22, 2011 | Garmin nuvi 215 GPS Receiver
Cant enter the coordinance to go to reefs offshore how do these things work
User Manual open the above link and go to page 22. It explains how to manually enter a waypoint if you know the coordinates. It also explains anything else about your GPS receiver. Good Luck, Have Fun, and be safe!
Feb 28, 2011 | Garmin GPS 126 GPS Receiver
Entering coordinates
When you press on your Where to? graphic a menu will come up that will give you a number of choices including
Address, Go Home, Points Of Interest, and 3 others. There should be an arrow point down in the lower right corner of the screen. When you press that the screen will scroll down a page and you should then see the Coordinates Globe. Press this and the screen should change to the Enter Coordinates screen. This will allow you to enter two sets of coordinates for your destination.
May 29, 2010 | Garmin Nuvi 350 Car GPS Receiver
How do i insert a negative (-) deg co-ordinate into my nuvi 200
Positive Lat Lon coordinates are for the eastern and northern hemispheres respectively. If you have a negative coordinate, they indicate a location in the western or southern hemisphere.
To enter a Latitude coordinate of, for example, -31 degrees, you would enter 31 degrees, but specify S (for South) rather than N (for North)
Negative Lon coordinates would use W (for West) instead of E (for East)
Jan 08, 2009 | Garmin Nuvi 660 GPS Receiver
Entering coordinates into a etrex yellow
Mark a waypoint, then edit the waypoint, entering the new co-ordinates.
Oct 04, 2008 | Garmin eTrex GPS Receiver
Jun 29, 2008 | Garmin eTrex GPS Receiver
Plotting Waypoints
Here's the link to the user manual if you need it; http://www8.garmin.com/manuals/GPS60_OwnersManual.pdf Garmin says; To manually enter in the coordinates for a waypoint on the 60 or 76 -series units, use the following steps: Press and hold the 'Mark' button. Use the up arrow to scroll up to the "Location" field and press 'Enter'. A new box pops up to enter in the new coordinates. Go to "OK" and press 'Enter'. Select "OK" at the bottom right corner to save all changes. Hope this helps :)
Jul 17, 2007 | Garmin 60 GPS Receiver
GPS Logo
49 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
