Question about Hunter 90021 Century Table Fan
Parts Fan will no longer turn on. It just stopped. No obvious breaks.
  • Cheryl Dale Aug 11, 2013
    This is my problem with the 90021 Century Fan as well. Although once in a while when fiddling with it high speed will turn on. I love this fan and want to fix it.
How do you remove the fan from 1998 f150 4.2 liter
how do you remove the fan and fan clutch from 1998 f150 4.2 liter engine. i am trying to replace the water pump but i cannot get the fan to break loose . i cannot figure how to stop pump from turning while trying to loosen the bolt or nut that holds the fan clutch on the water pump shaft . is there a special tool to help me with this
Jul 15, 2010 | 1998 Ford F150 Regular Cab
Our Hunter Fan and Light with remote has been installed for over 1 year. It has always had the 'ghost' problem where it will randomly turn itself on or off but we have been able to live with that. Last...
Your ghost problem was probably due to a loose connection. The wire has probably come completely loose or the heat from the loose connection has damaged the relay.
Jun 20, 2010 | Hunter 52" Ceiling Fan With Light And...
Fan Blower Makes noise
Sounds like the fan needs to be replaced. But first, to check for obstructions, remove the carpet liner from the underside of the dash on the passenger side and you'll see the blower motor under the dash held in with three screws. If there's something obvious blocking it, remove it and reinstall the fan. If there's nothing blocking it, then you'll probably need to replace the fan. Any auto parts store, Rockauto.com or E-Bay will have the correct fan for your Grand Prix.
May 26, 2010 | 1998 Pontiac Grand Prix
Acer Aspire L100 will not power up
Power supply is bad. Replace the power supply.
Dec 30, 2008 | Acer Aspire L100 PC Desktop
1990 Lincoln continental fan will not work manual or auto
check your temperature sending unit. this is the one that triggers the fan once the engine is in hot condition.
hot condition would be the needle just past the middle of the gauge.
BUT, if you have your air conditioning on, these fans should run at the same time the compressor is on.
this fan is waiting for two things. A/C is on, and engine is hot.
tnx 4 using fixya,
drcool
Oct 19, 2008 | 1990 Lincoln Town Car
Hunter 90021 Century Table Fan Logo
47 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
