Downlod site for sis file
SOURCE: downloading games
.sis are for most nokia phones as well, if the .jar files work you can try those but you should update your firmware.
SOURCE: my nokia n70 is unable to run sis files
try this tricks i have the same problem then:
1. go to tools > application manager > settings > software installation....
2. change it from signed only to all
hope it helped you
SOURCE: .jar files,.nth files,.sis files are unsuppoted
Jar files are compressd in jar format and are not for a particular machine. You can compress any file to jar format. sis files are for symbian OS. could be Jar or any. Samsung is a java phone. So you need jave files to load on your phone. Go to www.getjar.com, specify your phone and download all files that are displayed as compatible with your phone.
SOURCE: what is sis files? or how can we download sis
What is SIS file : Errors in your registry are one of the common causes for incorrect file associations on your windows system. It is highly recommended that you check your registry for file association errors (will also check for any other registry errors).
The SIS file type is primarily associated with 'Symbian' by Symbian. Application installation archive for most any device which uses the Symbian Operating System.
How to install sis file in mobile? : The installation kit (the SIS file) is removed once the installation is completed, or otherwise it would be a waste of memory space to keep it on the phone.
You will have to download it again or download it to PC first and then install it to the phone using the PC software and the USB cable or Bluetooth.
