Question about Canon PIXMA MP160 All-In-One InkJet Printer
I WANT TO RESET MY CANON PIXMA MX374 FAX
CANT RECIEVE OR FAX.POWER LIGTH ON/OFF AND ON AGAIN. TEL ON HOW TO RESET.
websnail
  • 419 Answers
SOURCE: Can't send fax on Canon pixma mx310
There are two buttons on the MX310... one for colour and one for black & white.. Depending on which mode you're using (ie: copy, fax, etc..) these buttons will copy, fax, etc...in either colour or black & white accordingly.
These buttons are located on the far right of the control panel with colour closest to the user, black & white above that and then the stop button above and right.
To fax in black & white (or mono as it's otherwise called) just choose the Fax mod, then press the Black button and you're away...
Hope that helps.
Posted on Feb 13, 2009
old marine
  • 1985 Answers
SOURCE: Cannot recieve or send faxes
Check out the Easy Setup Instructions available here. If you can neither send nor receive faxes, you may not have the phone line connected to the correct port, see page 34 of the guide. Also check what receive mode the machine is set for. Pages 42 and 43 explain the different options and how to change the receive mode.
Posted on Mar 16, 2009
iservice
  • 318 Answers
SOURCE: canon pixma mp 830 on my fax activity report I
Yes,it means the fax did not go through,it will show OK on the report if it was succesfull
Posted on Jul 03, 2009
SOURCE: Canon PIXMA MP190 reset ink?????
I have a canon printer MP190. How do I do the reset after completing my ink cartridge to the syringe?
Posted on Mar 02, 2010
  • 823 Answers
SOURCE: how to recieve a fax
Take your incoming phone line and plug it into the place that says "line" on your fax machine. Plug another phone cord into where it says "phone" and connect this to your telephone. Test to make sure you have chosen the right places by dialing a phone number to fax to and listen for the dial tone. If you get a dial tone, then you have set it up correctly.
On the fax machine look for the button that says "menu". Push it and use the up and down arrows to navigate the options on the display. Look for fax set up and press "ok" or "enter" on the fax machines keyboard to access this area. Look for "number of rings" and change the fax machine to a number of rings that is less then your voice mail box if you have one. Then close and save your choices.
Have someone send a test fax by dialing your phone number for the line connected to the machine. The fax machine will pick up on the number of rings set and automatically begin receiving and printing a copy of your incoming fax.
You cannot use magic jack.
You can also choose to manually answer an incoming fax if you see that your display on the fax machine says "ringing" or incoming" you can push the "start" button and this will start receiving your incoming fax.
Posted on Sep 30, 2010
Hoe do I set up fax functions on Canon Pixma MX452
My incoming fax issue was resolved when I enabled the answering machine function on my phone. All this time my answering machine was turned off. I have yet to send a fax. My model is the Canon Pixma MX452.
Apr 05, 2013 | Canon PIXMA Office Equipment & Supplies
Cant get incoming fax
be sure phone cord is plugged into line port..not tel. Or your machine is in manual mode. Press button under lcd panel that says recieve mode until display reads fax/tel.
Apr 12, 2012 | Canon LaserClass 2050 Plain Paper Fax
Hi, My Canon PIXMA MX350 Allinone, can send faxes but cannot recieve faxes.
Hi
Please check your Canon in fax mode, if its not in fax mode pleas go to the setup and select the mode option and select fax mode. and try again
Jun 21, 2011 | Computers & Internet
When people is sending fax....my fax is not ringing and i can't recieve the fax....printer MX 328
check the phone line that is connected to the fax . plug this line into a phone and check for a dial tone if this is good plug back into your fax machine . power your fax and turn back on . then try again. hope this helps
May 05, 2011 | Canon PIXMA MX310 All-In-One Printer
May fax wount pickup call,i can send out but i can't get in fax
chk the tel/fax switch on the menu button if it is set to tel only, the fax will not pick up a call
Oct 16, 2009 | Canon PIXMA MX310 All-In-One Printer
FAX DOESNT RING WHEN RECEIVEING CANON FAX-L350
These units only ring under two circumstances. First the external phone must be attached. It has a volume slider on the phone. Second. The recieve mode must be st for Fax/Tel not anything else
Jun 20, 2009 | Canon FAX-L350 Plain Paper Laser
Canon faxphone will not recieve fax
Most of my fax mahines I setup,I setup with the fax only mode,and then I change my incomming ring to 7.This give you enough time to answer the phone and minnimize the risk of losing faxes.If a external phone is connected to the phone and you receive a fax call,you press 25 on the external phone and the fax switch to rceive.
Feb 27, 2009 | Canon FAXPHONE L80 Laser
Need to find printer part
From http://www.canon-europe.com/Support/Consumer_Products/services_locator/index.aspx
Electroversal
Photo Printers, Inkjet Fax, Scanner, InkJet Printer, Laser Printer, InkJet MFP
Electroversal provides a return to base service for A4 Bubble Jet Printers, PIXMA iP90/iP90V, Selphy, CP, DS & PIXMA Mini Printers, the Fax B820 & B840, JX200/500, PIXMA MP110, MP130, MP140, MP150, MP160, MP170, MP180, MP210, MP220, MP450, MP460, MP470, MP510, MP520, MX300 & MX310, the LBP2900, LBP3000 and Scanners (except the dedicated 35mm Slide Film Scanners 2700F, FS2710& the FS4000US – Canon UK RCC).
Unit 2
Sedgwick Road
Luton
LU4 9DT
Tel: 01582 582023
Fax: 01582 582 087
Web: www.electroversal.com
To obtain a repair quote for products serviced by Electroversal, please call Electroversal Customer Service department on 01582 582023 or email sales@electroversal.com
CRC (Tasktron Ltd)
Photo Printers, Inkjet Fax, Calculator, Scanner, InkJet Printer, Laser Printer, InkJet MFP
CRC Tasktron Ltd provides a return to base service for Calculators, A4 Bubble Jet Printers, PIXMA iP90/iP90V, Selphy, CP, DS & PIXMA Mini Printers, the Fax B820 & B840, JX200/500, PIXMA MP110, MP130, MP140, MP150, MP160, MP170, MP180, MP210, MP220, MP450, MP460, MP470, MP510, MP520, MX300 & MX310 the LBP2900, LBP3000 and Scanners (except the dedicated 35mm Slide Film Scanners 2700F, FS2710& the FS4000US – Canon UK RCC)..
Unit 3 Wintonlea
Monument Way West
Woking
Surrey
GU21 5EN
Tel: 01483 776 060
Fax: 01483 721 389
Web: http://www.crc-tasktron.co.uk
Cura Technical
Personal Copiers, Laser Fax, Inkjet Fax, InkJet Printer, Laser Printer, InkJet MFP, Laser MFP
CURA Technical provides on-site service for A3 and PIXMA iP90/iP90V, laser Beam Printers, PC/FC Copiers, Multifunctional Printers and Fax machines. On-site service can be arranged by dialing 0844 369 0100.
Please note that Cura Technical do not service the following products: Selphy, CP, DS & PIXMA Mini Printers, Fax B820, B840, JX200/500, PIXMA MP110, MP130, MP140, MP150, MP160, MP170, MP180, MP210, MP220, MP450, MP460, MP470, MP510, MP520, MX300 & MX310 and the LBP2900 & LBP3000. These units are repaired at our Return to Base Agents, Electroversal or CRC Tasktron Ltd.
Cura Technical
Uniter House
3 Radford Way
Billericay
Essex
CM12 0DX
Tel: 0870 400 2080
Web: http://www.curatechnical.co.uk
Dec 17, 2008 | Canon PIXMA MP610 InkJet Printer
Cant recieve fax
please help me how to switch my machine Brother MFC440cn to fax/tel mode.
Oct 26, 2008 | Brother MFC 420CN All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
old marine
old marine
