Question about HP Pavilion ze5185 Notebook
Car battery charger
Hi my car battery charger is 240 volts in and 12 volts out proble is no power coming out on 12 side
    New Friend:
  • 17 Answers
It is possible that the unit needs to see a battery load before it engages the charge circuit. To test this measure the voltage of the battery without the charger. Then attach the charger and measure the voltage again. If the charger is working the voltage should be 13 to 14 volts.
Posted on Jul 26, 2013
7155 Parallax Power supply 12 volt side problems, all fuses and wiring in good working order.
http://d163axztg8am2h.cloudfront.net/static/doc/b5/84/8f1a1586e9cb74379e85d9136830.pdf
Dec 12, 2017 | Parallax Power Supply PARALLAX POWER 7155...
Jayco Caravan ST -11 Series Power suppy when I disconnect the 240 volt and battery is charged the 12 volt system will not work?
Hi Sue, The links below are YouTube videos showing how to fix a car that doesn't start/cranks but doesn't start, Also there's videos down the right side of the links that may help as well....................CHEERS..
Fixing Car That Does Nothing When You Turn The Key
Fixing Car That Cranks But Doesn Start Up
Car Cranks But Will Not Start
May 01, 2016 | Cars & Trucks
What volt charger do i need to charg mower 12volt battery?
Doug, Any 12 volt automotive charger will work for your lawn tractor, the cheaper no frills chargers will work fine.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Battery Chargers Canadian Tire
Amazon com Battery Chargers Jump Starters Battery Chargers Portable Power...
Car Battery Chargers
Feb 27, 2016 | Cub Cadet Garden
How do i convert a makita charger model DC18RC at 110 volt to 240 volts?
The DC18RC are most likely to charged the BL1830 battery, which is the most popular of 18V Makita power tools. It is a Li-ion battery.
And the DC18RC battery charger has two volt 110 Volt and 240 Volt.
The 240 Volt DC18RC charger can replace model DC18RA & DC18SD because of its improved performance and full compatibility with Makita's NEW 'Star' labelled batteries that communicate between the tool, battery & charger. And, it is a fast charger.
It can charge a Makita BL1830 Battery in approx 22 minutes.
But, I do not recommend to convert a makita charger model DC18RC at 110 volt to 240 volts.
The reason is as below:
1. This will void product warranty ! If you follow this mod, you do it on your own risk !
2. There are several comments that described
same model # but with different design and components.
Please beware that this mod might not work on your charger
or worst, will damage it.
Only perform this mod if you know your way around with electronics !
Sep 20, 2013 | Makita Drills
Can u use a 12 volt charger to charge a 6 volt spot light 1000,000 candle power s800g
obviously not as the 12 volt will fry anything 6 volt. It is like putting 240 volt into 110 volt and wondering why it blew up. Get the right charger for the unit and save yourself heartache and money
Aug 12, 2013 | Camping, Backpacking & Hiking
How do u charge a edelbrock power wheel corvette for kids 12 volt batteries and a 6 volt charger
Hello! Due to Charger Voltage Compatibility: Never use a battery charger unless the battery voltage matches the output voltage rating of the charger...Therefore do not use a 6-volt charger on a 12-volt battery and visa-versa...
guru...........
saailer
Sep 27, 2011 | Cars & Trucks
How do you charge the 12 volt battery with a 6 volt charger
  • A 6 Volt charger will charge a 12 Volt battery, it will just take twice the time to get the 12 Volt battery to full charge as a 12 Volt charger would take. V*I=W. It will take up to 36 hours to get a full charge from near dead but it will work just fine.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 27, 2011 | Electric Kid Trax C6 Corvette Ride On
My batterys not charging
check the battery with a multimeter and see if its showing 12 volts or more, if its not showing any volts the connectors on the battery under the plastic housing have probably come disconnected, you'll then have to pry off one side of the battery and reconnect them, if it is showing volts but not 12 or more then put it on the charger for about 8 hours, then check the battery again if it still hasn't went up check the voltage of the charger with the multimeter and make sure that the charger is putting out 13.8 volts or more, iif it isn't then you need a new charger, if it is then you need a new battery
May 06, 2011 | Peg Perego 12 V Slim Battery Iakb0014
John deere turf tractor has no power, recharged battery for 24 hours but still zero power. Checked all connections, everything is connected. Tractor is approximately 6 months old
Apr 26, 2011 | Peg Perego IGOR0040 John Deere Turf...
Charging Canadian battery tools in Europe
http://www.220converters.com/ GO TO THIS WEB SITE AND YOU CAN FIND ALL THE CONVERTERS YOU NEED ALSO READ THE NOTES ABOUT WHAT YOU NEED TO TAKE WITH YOU BATTERY AND POWER WISE . HAPPY TRAVELS AND HAVE A GOOD TRIP
Jan 12, 2009 | Dewalt 7.2-18.0 Volt One Hour Charger
HP Pavilion ze5185 Notebook Logo
57 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
