Question about Bernina Sewing Machines
How to change plate needles?
Point has broken off left hand needle in plate. I know they must be glued in...how to get them out? Well, only one of them.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 73 Answers
You are talking about a serger / overlocker ?? Yes, needles are glued in. If you get a grip on what is left(eg with long nose pliers) and carefully lift, it should come out.
Posted on Apr 29, 2014
bargainbox
  • 1388 Answers
SOURCE: Janome Needle plate and needles hitting something underneath
The broken pins are called chaining pins and are tricky for the home user to replace without risking damage to the needle plate as they are difficult to remove and the tiny burr used to hold them firm can easily open up and no longer grip the pin.
There are only a couple of things under the needleplate that are likely to collide with the needles. 1. Lower looper - with the needles 2. Both Loopers colliding with each other - not with the needles 3. Needle guards attached to lower looper - with the needles 4. Fixed Needle guard - with the needles
If you remove the needleplate and VERY gently turn the handwheel you should be able to see and feel where the collision is occuring and have a better idea of the issue.
I would strongly advise that you do not try to operate the machine until you are sure that the colliding components are adjusted. Broken loopers are approx $65 AUD and guards, tho' only about $20 AUD require some finesse in adjustment. Chain Pins approx $6 AUD
My recommendation is to speak with your local Janome dealer for advice and an approximate price to repair, replace or adjust as the case may be.
Your country's Janome website is certain to have a Dealer Locator page to list the nearest to you.
This is one occasion where it is sensible to call on the people who do these things routinely rather than try to DIY and make a more expensive hash of it.
www.bargainbox.com.au
Posted on Nov 22, 2008
Michaelle
  • 65 Answers
SOURCE: Replacing needle on Elna Pro 905 DCX serger
Try and loosen the screw, and use a magnet to pullout the broken piece. It likely slightly bent in there so you may need a pair of tweezers as well
Posted on Jan 24, 2009
  • 6 Answers
SOURCE: Viking 6020 kicks the bobbin case out
Check with allbrands.com - they have LOTS of resources and if you can't find it - you can call and they have lots of great ideas.
Also - ebay has a seller who owns and LOVES sewing machines. He is located in California - so he has a wealth of population base to help you search.
His SELLER NAME on ebay is craigthecat - just do a search and you will find him.
EBAY also has many "for parts" machines - I sure "stick and brick" sellers also have lots of old machines they just sell out the parts.
Glad it was just the thread - happy sewing
Posted on Feb 18, 2008
bunnydawg
  • 5158 Answers
SOURCE: My sewing machine needle is hitting the top of the needle plate
basically have to bend it carefully back by hand.... if you have a straight edge or even a small leveler (the kind with a bubble) you can check which direction it is bent and gently bend it back a little each time.
Posted on Mar 29, 2009
Zenqi
  • 208 Answers
SOURCE: which way to put the needle in the Juki, The
The indent is called the scarf.
The scarf will be at the 3 o'clock position and, if you look closely, you will see the hook pass the needle at the scarf.
Posted on Oct 01, 2009
Can I just change the needle plate on my janome overlocker been told I need to have loopers reset
Sergers are funny things. You can certainly try just replacing the needle.... make sure you thread correctly. upper looper, lower looper, right needle left needle... etc.
Before you take off sewing... run the machine by hand a few revolutions if it seems to be moving with no more clunking etc. try to sew. If it breaks the needle again. Stop immediately and take it in.
Dec 02, 2012 | Sewing Machines
Needle keeps breaking when quilting
the machine needs to be taken to a sewing machine shop & be
checked to see if it has jumped time,, a sewing machine shop
technican has the tools to retime the machine & the foot needs
to be filed to get rid of the burr on it.
Aug 11, 2012 | Bernina Artista 180
While sewing, the needle suddenly hit the side of the foot-plate which bend the needle, but now the entire machanism is stuck and won't move up or down. How can I fix it and what is the cause of the...
hi there
1- how old your machine ? please check needle par play left and right or no? maybe lower needle bar bushing need to change.
2- maybe ur presser foot played need to change it but check firist.
3- sometimes when needle is broken there is small metal goes insaide the hook and make it dosn't move up or down, if you can adjust timing for hook please remove the hook and check your machine by hand move or not?
4- maybe some thread goes insaide the finger ( stopper for hook ) check this earia .
Best regards
ashraf abozid
aabozid@hotmail.com
Aug 28, 2010 | Sewing Machines
My needle keeps hitting the throatplate, (I have broken 2). It was working fine. I don't know what I have done to cause this! e.
First, check the position of your needle.Machines with zigzag capability allow you to adjust the position of your needle left, right,or center. If your needle is not in the correct position, it may be hitting your needle plate. If that doesn't work,change your needle plate.
If you've been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
I hope this helps.
Mar 22, 2010 | Sewing Machines
I have broken 2 needles and now the new needle (foot) will not move up and down. i have double checked all settings and nothing has helped. any suggestions
Here are several solutions for you to try.
* Your broken needle may have been too thin for your fabric. Make sure your replacement needle
is appropriate for the weight and type of your fabric and thread. You may also need a thicker needle if you’re sewing through bulky layers of fabric. When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot to make sure it’s attached securely.
* Change your pressure foot. Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins. A needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate to make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle, right,left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
I hope this helps.
Dec 23, 2009 | Bernina Artista 180
I have a Bernina 1130. It is not picking up the bobbin thread. The hook is clean and oiled. the needle has been changed. It was last serviced November 2008.
Make sure you have the correct needle and it is in with the long groove pointing towards you. If the hook shuttle is rotating and you feel a tight spot when turning the machine by hand it means one of the nylon gears has cracked. If a needle has been broken it is possible the needle bar has been knocked up a little, try dropping your needle down about 3mm and turn the machine over by hand to see if it picks up the thread.
Failing that the timing is out, remove the top cober on the arm and loosen the clamp on the hook drive shaft, when the machine is turned over and the needle is at bottom dead centre the point of the shuttle hook should be about 3mm to the left of the needle.
Jul 01, 2009 | Sewing Machines
Mar 29, 2009 | Kenmore Sewing Machines
Mock safety stitch
Sounds like the timing is a little out.
If you remove the needle plate and turn the handwheel manually watch for the lower looper as it swings behind the Left needle....the needles ought to rise by only about 2mm before the looper passes......the looper must pass the needle above the eye to catch the thread, and be so close as to be barely touching the rear of the needles......if the left needle thread is not picked up, it may be the timing, or the distance between needle and looper.
For the uninitiated, there are a myriad of variables in correctly timing an overlocker (serger), and without the manual to refer to the correct parameters, you will rapidly descend down a road of despair....if you move a looper to advance or ****** the timing, you risk looper collision and a broken looper is almost as much as a service, so my advice is do the test to see if the timing is the likely culprit, and if so, take the opportunity to give the old girl a treat.
If you need to save for a while to do it, just use the 3 thread option for the time being.
Apr 26, 2008 | Singer 14SH654
Singer 7442 - Needle hitting bottom
FIRST DETERMIN NEEDLE BAR POSITION TURN STITCH REGULATOR TO LARGEST STITCH, THEN TURN HAND WHEEL TIL' NEEDLE IS ABOUT TO ENTER NEEDLE PLATE.
AT THIS POINT THE FEED DOGS SHOULD BE JUST AT OR JUST UNDER PLATE. IF SO NEEDLE BAR IS, IN CORRECT POSITION,AND TIMING WILL BE SET AT THE HOOK.
TO SET TIME REMOVE NEEDLE PLATE TURN HAND WHEEL SO NEEDLE IS IN LOWEST POSITION. USING A SMALL RULE RAISE NEEDLE BAR 3/32 OF AN INCH ( OR 3 MM FOR A METRIC RULE) .HOOK POINT SHOULD BE IN CENTER OF NEEDLES WIDTH. LOOSEN THE 2 SHAFT SCREWS
SLIGHTLY,TURN HOOK TIL CENTER OF NEEDLE. TIGHTEN SCREWS. IF NEEDLE BAR IS OUT OF TIME. BRING HOOK TO CENTER OF NEEDLE AND LOOSEN SCREW IN LEFT COVER. RAISE OR LOWER NEEDLE BAR TO SET 3/32OF AN INCH. THE 3/32 MUST BE VERY VERY CLOSE.
Nov 26, 2007 | Singer 7442 Mechanical Sewing Machine
Sewing Machines Logo
60 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
