Question about Intel Essential DG41WV Desktop Motherboard - Intel Chipset BLKDG41WV
Display off after some time
My brother uses DG41WV desktop board with Intel Dual Core 3.0GHz E5700 processor & 2 GB DDR3 RAM. The PC has SMPS of 450 Watt ATX-P4. When turning on the machine by pressing Power Switch, the processor fan, on-board LED & HDD LED of chasis is turned on but there is no beep sound in in-built speaker & also there is no video in Monitor whether it is connected to VGA port of the board or to the VGA Card. I found all other components like HDD, RAM, Processor, VGA Card & SMPS are in ok condition. The PC was running till last Monday. I checked the parts in different machines. Then, I cleared the CMOS but the problem still exists. Now, what should I do to solve this problem? Please help...
  • Intel Master
  • 3,799 Answers
As you have checked all of the removable components. That only leaves one bit left. The motherboard. Check the capacitors around the CPU socket and the Power connector. There is a common problem with Socket 775 CPU it is that the contacts on the CPU socket can be badly connected even when the CPU is fitted and locked in.
Posted on Jul 27, 2013
SOURCE: Intel D850MV motherboard
This is Old problem with this mother board, Check u r dummy ram stick, if its fixed properly, and if possible get bios upadates, Check u r smps, it should be above 400watts. this can probably solve your problem.
Posted on Aug 16, 2007
  • 44 Answers
SOURCE: No video & 3 beep sound
Hi Sharang -
Here are the steps to take for that specific motherboard according to Intel
  • Reseat the memory.
  • Make sure that the contacts on the memory and the socket are clean.
  • Try removing one bank of memory modules at a time. Note: Some systems might need to have a memory module in Bank 0.
  • Try using RAM chips from the same manufacturer with the same part number and speed.
  • Check for a faulty memory module by trying the memory in a known good system.
  • Trying known good memory in the system.
  • Check the power supply and check for power fluctuations.
  • Swap the motherboard.
Hope that helps,
Take care,
Michael
Posted on Nov 14, 2008
SOURCE: new asus m3n72-d motherboard bios will not post
If you don't already have a case speaker hooked up to the board, you might want to connect one since there isn't an on board speaker and you will not hear error beeps otherwise.
Also, if you have another non-phenom AM2 processor handy you should really update the BIOS to latest release. Many late model Phenoms will not work on motherboards that have earlier BIOS releases and you will not be able to post. You should then choose "Set Optimized Defaults" and save the bios without any changes then shut down (not reset). When you power on again it should post and you should be able to get into the BIOS.
A third thing you can try (after you get a case speaker hooked up) is using a cheap pair of ddr2-6400 RAM to get the board to post so you can get into BIOS and change the voltage to the correct settings for your RAM if it requires a higher voltage than the bios expects.
Posted on Nov 17, 2008
Dissolu
  • 221 Answers
SOURCE: Nothing happens when I press the power button. No
What about the power supply? I bet it's supply's issue. Otherwise make sure that PWR button wires are connected properly and to the correct terminals of the motherboard
Posted on Jun 29, 2009
SOURCE: i dont't get display in my moniter my board is
check the ram to know if it is actually working or sitting properly.......check the VGA port...........try another monitor on your board........lastly try the monitor on another board and if it works you board is bad
Posted on Feb 01, 2010
Lenovoh520 series 2 no sound
buy an external sound card will solve your problem.
Dec 25, 2012 | Lenovo H520s Desktop Computer; Intel...
Which is the best graphic card for intel DG41RQ mother board
I have a motherboard intel dg41rq and intel core 2 duo E7200 and nvidia geforce 9500 GT and 4gb ram (DDR3).It will work with call of duty black ops 2 and FIFA 13.So your done.
Oct 02, 2012 | Intel DG41RQ Motherboard CPU Bundle - ...
How much
Hi jaygomez_13,
Please check this, You can also click this link: http://www.acer.com.ph/ac/en/PH/content/series/aspire to check the price, specifications, models and other details. aspire_11_350x250.jpg Aspire AS4745G-352G32Mnks ( LX.PSM0C.037 ) 28000 PHP
Linpus™ Linux® - Intel Core i3-350M (3MB Cache, 2.26GHz) - 2GB DDR3 RAM - 320GB SATA HDD - ATI Mobility Radeon HD 5470 with up to 3579MB of HyperMemory - Screen Size 14" HD 1366 x 768 resolution - Battery 6-cell Lithium Ion (Li-Ion) 4400mAh - Up to 6hours battery life
AS4745G-352G32Mnks LX.PSM0C.037 aspire_11_350x250.jpg Compare energy_star.jpg Intel® Core™ i3 Processor
  • Operating System Operating System Linpus™ Linux®
  • Processor & Chipset Processor Manufacturer Intel Processor Type Core i3 Processor Model i3-350M Processor Speed 2.26 GHz Processor Core Dual-core Cache 3 MB 64-bit Processing Yes Hyper-Threading Yes Chipset Manufacturer Intel Chipset Model HM55 Express
  • Memory Standard Memory 2 GB Maximum Memory 8 GB Memory Technology DDR3 SDRAM Memory Standard DDR3-1066/PC3-8500 Number of Total Memory Slots 2 Memory Card Reader Yes Memory Card Support Memory Stick PRO
    xD-Picture Card
    Secure Digital (SD) Card
    MultiMediaCard (MMC)
    Memory Stick
  • Storage Hard Drive Capacity 320 GB Hard Drive Interface Serial ATA Hard Drive RPM 5400 Optical Drive Type DVD-Writer Optical Media Support DVD-RAM/±R/±RW
  • Display & Graphics Screen Size 35.6 cm (14") Display Screen Type Active Matrix TFT Colour LCD Display Screen Technology CineCrystal Aspect Ratio 16:9 Screen Mode WXGA Backlight Technology LED HDCP Support Yes Graphics Controller Manufacturer ATI Graphics Controller Model Mobility Radeon HD 5470 Graphics Memory Capacity 512 MB Graphics Memory Technology DDR3 SDRAM Graphics Memory Accessibility Dedicated TV Card No
  • Network & Communication Wi-Fi Yes Wi-Fi Standard IEEE 802.11b/g/n Ethernet Technology Gigabit Ethernet Bluetooth Yes Bluetooth Standard Bluetooth 2.1
  • Built-in Devices Webcam Yes Microphone Yes Finger Print Reader No
  • Interfaces/Ports HDMI Yes Total Number of USB Ports 4 Number of USB 2.0 Ports 4 VGA Yes Network (RJ-45) Yes
  • Software Operating System Linpus™ Linux®
  • Input Devices Keyboard Yes Pointing Device Type TouchPad
  • Battery Information Number of Cells 6-cell Battery Chemistry Lithium Ion (Li-Ion) Battery Capacity 4400 mAh Maximum Battery Run Time 5 Hour
  • Power Description Maximum Power Supply Wattage 90 W
  • Physical Characteristics Colour Black Height 29 mm Width 342 mm Depth 245 mm Weight (Approximate) 2.20 kg
  • Miscellaneous Package Contents
  • Aspire AS4745G-352G32Mnks Notebook
  • Lithium Ion Battery
  • AC Adapter
  • Security Features
  • Kensington Lock Slot
  • BIOS Passwords :
    • User
    • Administrator
    • Hard Drive
    Green Compliance Yes Green Compliance Certificate/Authority Energy Star
  • Warranty One-year International Travellers Warranty (ITW)
    Hope it helps.
    Thank You for using Fixya.
Sep 07, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have installed new DG41WV motherboard with New inter processor 3 GHZ, 2 GB kingston Ram. When i start PC, there no beep & no display in the monitor
I have the same problem few days ago and found my solution on Fixya Expert Sources website. Here you will get all the top sources of your problem. All the sources of this site provided by top Fixya Gurus. Have a good look at the sources of the page. Go through the sources to find your solution. Hope it will help.
View Count:2
Aug 18, 2011 | Intel Essential DG41WV Desktop Motherboard...
Which laptop for 3d animation .use softwares maya,max ,video editing dell's config: Intel® Core™ i5-460M Processor (2.53GHz, 2Core/4Threads, turbo up to 2.8GHz, 3M cache) 1GB NVIDIA®...
dell\'s config: Intel® Core? i5-460M Processor (2.53GHz, 2Core/4Threads, turbo up to 2.8GHz, 3M cache) 1GB NVIDIA® GeForce® GT 420M graphics with Bluetooth (with WIDI) 4GB 1333MHz DDR3 SDRAM (1 x 4G) (operates at 1066MHZ for Core i5 processors) with increased RAM will work fine
Dec 16, 2010 | eMachines M6811 Notebook
I have 9600 gt Graphics Card on Intel DG31PR with dual core processors & 2 GB Ram. While I starting My PC after 2-3 days then PC started but there will no display at all, hdd led not blink but pw led...
It's the motherboard, the BIOS forgets that there are components attached to the board and can't detect them.
Time for a new motherboard, this one is unfixable and it you wait too long it will fail while you use it with who know what consequences.
Oct 04, 2010 | Intel DG31PR Motherboard
I want to buy a laptop. Please suggest me which processor is best? ie. Intel pentium processor or intel pentium dual core processor? Will intel pentium dual core processor overheat easily?
hello,,,,,,,,,,,,,
First you need to be clear that dual core is the family of Pentium series. so there is no processor called Pentium.............. now regarding your question i would suggest you do not go for dual core... Take core 2 duo or I3 /I5/I7 series of processor..............
I am giving you a configuration in a good budget
Rs 50,800/-
Intel 3 GHZ Core2 Duo Processor,3 GB DDR2/DDR3 RAM, and a 250/320/500 GB HDD. DVD writer, 15.4-inch display with a resolution of 1280 x 800 dpi. integrated Intel Graphics Media Accelerator X3100 video card, integrated modem and sound card, Wifi, Touchpad mouse and in-built speakers. It has interfaces like Express Card slot, S-Video port, 4 USB ports, Firewire port, bluetooth and a 6 in 1 Digital Media Reader. The laptop comes with an inbuilt camera .
It would be better if you can tell me your budget ............... So that i can give you a good configuration ......................
Jun 14, 2010 | Computers & Internet
Intel Essential DG41WV Desktop Motherboard - Intel Chipset BLKDG41WV Logo
67 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
