Question about Lincoln Roosevelt Popcorn Maker
Roosevelt popper switch replacement - Lincoln Roosevelt Popcorn Maker
I need a new switch that turns the kettle. model np08001
That brand does not sell replacement parts. Your best chance to find one similar at a hardware store, or general restaurant parts company. Bring the old switch to the store to match up.
Sep 09, 2013 | Lincoln Roosevelt Popcorn Maker
How was President Taft's foreign policy different from President Roosevelt's?
http://kapush.files.wordpress.com/2008/03/foreign-policy-of-roosevelt.doc
May 08, 2011 | Video Game Consoles & Games
The plastic gears in the gear motor are stripped out where can I find parts for it Its a model ue40010
These gears are used in many of the 8oz poppers: http://www.keepitpoppin.com/popcorn-machine-parts/motor-gearbox-8oz.html
Feb 10, 2011 | Lincoln Roosevelt Popcorn Maker
I CANNOT FIND INSTRUCTIONS HOW MUCH OIL AND POPCORN DO I PUT IN AND WHERE? THANKS, ARLENE,///
I have the same popper and the instructions. You do not need any oil. There is a circle lid piece at the top of the popper. You put the pop corn seeds in that lid and then pour the seeds in through the hole at the top. The popper needs to be off while you do this. Once you've added the popcorn you can then turn on the switch located on the back of the popper. It looks like a small light switch. The popcorn will start popping and it may smell funny at first if you haven't used it or used it properly. You have to monitor it and turn it off yourself- using that same switch. And per the manual you need to wait 15 minutes before you use it again.
We use ours all the time and love it. Hope this helps.
Aug 21, 2010 | Nostalgia Electrics OFP501 Old-Fashioned...
Good afternoon, I purchased a Roosevelt 8 ounce corn popper about 1-1/2 years ago. It is used once a week for approximately 1 hour. The heating element has failed and I am trying to purchase either a new...
Hi Roy,
Here is a toll free number to DTX International. With the model and serial info, I'm sure they can assist you in a replacement part:
DTX International
9855 North Front St Mancelona, MI 49659
1-800-665-0728
Hope this helps... Good luck!
Sep 22, 2009 | Lincoln Roosevelt Popcorn Maker
Trunk "popper" quit working, but "pull down" still works
can you still open it through the key? does the pull down motor not work at all? if the pull down still works it sounds like the popper has just gone weak/bad . they need to be replaced after so long. seeing as you should have a keyfob and a button in the car. im assuming that means its the solenoid switch for the trunk release which is a 30 dollar part.
Jun 13, 2008 | 2000 Cadillac Eldorado
Lincoln Roosevelt Popcorn Maker Logo
118 people viewed this question
Top Lincoln Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Lincoln Kitchen Appliances - Other Expert? Answer questions, earn points and help others
