Question about Acer Computers & Internet
Date and time change
Can't change the date and time on the laptop
Change the date and time
Good day!
1. Point mouse to time and click > change date and time settings > change date and time > continue > select appropriate time and date > OK > apply > OK > DONE.
2. Go to bios settings change date and time > save settings
Mar 28, 2014 | Computers & Internet
Tip
Change time and date
Hold down the time or month/date buttons, then press either of the '<< or >>' (by CD controls) to move the time, or month/date. To change the year hold down both time and month/date buttons together to adjusting the year using the '<< or >>' buttons.
on Sep 04, 2013 | Brookstone CKD5810A Clock Radio Smart Set...
Need to change time on my toshiba laptop pc
Windows 7 and below:
Start> Control Panel> Date and time>Date and time will pop-up on the screen>Click on date and time to change the date and time.
Windows 8: Start> Type control and control panel will pop-up on the search list, click on that to open control panel>Date and time>Date and time will pop-up on the screen>Click on date and time to change the date and time.
Feb 07, 2014 | Toshiba Computers & Internet
Date change
Click on time section of your start bar (bottom right of screen). Then choose adjust time and date settings.. Following on screen setups to change it over to correct date and time..
Jan 06, 2014 | Acer Computers & Internet
Restore acer aspire 4730z
Switch On your PC/ Laptop and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click 'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot your problem should be resolved.
May 21, 2012 | Acer Computers & Internet
My driver on my laptop stop working
Nov 07, 2011 | HP Pavilion dv6000z Notebook
My notebook has fixed wallpaper.when i want to change my wallpaper there is no change in wallpaper . i cant understand whats the problem of my notebook.when i click the mouse right key there is no option...
Oct 17, 2011 | Acer Aspire One PC Notebook
My Toshiba Satellite p15-S470 Laptop lost date and time after shutdown. When i start my laptop it will not proper on and show orange light, after closing and out battery from laptop 2 to 3 time then it is...
try accessing your bios on your laptop and change the date on it. To access the bios just press F2 or F10 once you press the power button. Once you are inside of the bios locate the settings for date and time, then that's the time you can change and save it before you exit.
Hope it helps thanks.
Sep 15, 2011 | Toshiba Satellite P15-S470 (PSP10U-0GGPGR)...
Thinkpad R40 find date & time for start-up
Right-click the time in the lower right, select: adjust date and time, select: internet time, select either source, select: apply (if high lighted)--otherwise close. You need to be connected to the internet for the internet time to work.
Sep 18, 2009 | IBM ThinkPad R40 2722 Notebook
Computers & Internet Logo
16 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
